  3. BME280 temp/humidity/pressure sensor
31 Posts 13 Posters 37.2k Views 17 Watching
  • E
    E
    emc2
    Was modified in 2.1.1, you need to change
    to
    metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
    Y 1 Reply Last reply
    • A
      anno
      wrote on last edited by anno
      Still a lot of errors in this sketch, did take some out but this is still in it:
      In file included from C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino:48:0:
      C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
      #ifndef __BME280_MOD-1022_H
      C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
      #define __BME280_MOD-1022_H
      In file included from C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:40:0:
      C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
      C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
      C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp: In member function 'BME280Class::readCompensationParams()':
      C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:276:45: warning: iteration 20 invokes undefined behavior [-Waggressive-loop-optimizations]
      compParams.compArray[count] = Wire.read();
      C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:275:3: note: containing loop
      for (count = 0; count < 28; count++) { // first 28 bytes we can process like this
      C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino: In function 'loop':
      • E emc2
        to
        Y
        Y
        yoshida
        @emc2 Thanks! With this modification the sketch compiled successfully. Today I had time, so put everything together, and the BME280 works with the 2.4GH radio, temp/hum/pressure all reporting like they should.
        Using arduino pro mini, bme280, nrf24, 2XAA Batteries. It reports to the mysensors serial gw, and then shown in domoticz.
        Z 1 Reply Last reply
        • Y yoshida
          Z
          Z
          Zbigniew Ko
          @yoshida Hello
          You can share your sketch.
          Please
          I can not make modifications.
          I still have a lot of errors.
          • A
            anno
            • Z Zbigniew Ko
              @yoshida Hello
              Please
              Y
              Y
              yoshida
              Zbigniew Ko:
              (2.1.1 mysensors compatible, but first you need to install the BME280_MOD-1022.h library in arduino IDE)
               * Version 1.0 - Henrik Ekblad
               * Pressure sensor example using BMP085 module
               * http://www.mysensors.org/build/pressure
              // BME280 libraries and variables
              // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code
              // Written originally by Embedded Adventures
              // https://github.com/embeddedadventures/BME280
              #include <BME280_MOD-1022.h>
              #define BARO_CHILD 0
              #define TEMP_CHILD 1
              #define HUM_CHILD 2
              const float ALTITUDE = 184; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
              // Sleep time between reads (in ms). Do not change this value as the forecast algorithm needs a sample every minute.
              const unsigned long SLEEP_TIME = 60000;
              const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
              enum FORECAST
                STABLE = 0,     // "Stable Weather Pattern"
                SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
                CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
                UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
                THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
                UNKNOWN = 5     // "Unknown (More Time needed)
              float lastPressure = -1;
              float lastTemp = -1;
              float lastHum = -1;
              int lastForecast = -1;
              const int LAST_SAMPLES_COUNT = 5;
              float lastPressureSamples[LAST_SAMPLES_COUNT];
              // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
              // get kPa/h by dividing hPa by 10
              #define CONVERSION_FACTOR (1.0/10.0)
              int minuteCount = 0;
              bool firstRound = true;
              // average value is used in forecast algorithm.
              float pressureAvg;
              // average after 2 hours is used as reference value for the next iteration.
              float pressureAvg2;
              float dP_dt;
              boolean metric;
              MyMessage humMsg(HUM_CHILD, V_HUM);
              MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
              float getLastPressureSamplesAverage()
                float lastPressureSamplesAverage = 0;
                for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                  lastPressureSamplesAverage += lastPressureSamples[i];
                lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                return lastPressureSamplesAverage;
              // Algorithm found here
              // Pressure in hPa -->  forecast done by calculating kPa/h
              int sample(float pressure)
                // Calculate the average of the last n minutes.
                int index = minuteCount % LAST_SAMPLES_COUNT;
                lastPressureSamples[index] = pressure;
                minuteCount++;
                if (minuteCount > 185)
                  minuteCount = 6;
                if (minuteCount == 5)
                  pressureAvg = getLastPressureSamplesAverage();
                else if (minuteCount == 35)
                  float lastPressureAvg = getLastPressureSamplesAverage();
                  float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                    dP_dt = change * 2; // note this is for t = 0.5hour
                    dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                else if (minuteCount == 65)
                    dP_dt = change; //note this is for t = 1 hour
                    dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                else if (minuteCount == 95)
                    dP_dt = change / 1.5; // note this is for t = 1.5 hour
                    dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                else if (minuteCount == 125)
                  pressureAvg2 = lastPressureAvg; // store for later use.
                    dP_dt = change / 2; // note this is for t = 2 hour
                    dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                else if (minuteCount == 155)
                    dP_dt = change / 2.5; // note this is for t = 2.5 hour
                    dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                else if (minuteCount == 185)
                    dP_dt = change / 3; // note this is for t = 3 hour
                    dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                  pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                int forecast = UNKNOWN;
                  forecast = UNKNOWN;
                else if (dP_dt < (-0.25))
                  forecast = THUNDERSTORM;
                else if (dP_dt > 0.25)
                  forecast = UNSTABLE;
                  forecast = CLOUDY;
                  forecast = SUNNY;
                else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                  forecast = STABLE;
                  forecast = UNKNOWN;
                // uncomment when debugging
                //Serial.print(F("Forecast at minute "));
                //Serial.print(minuteCount);
                //Serial.print(F(" dP/dt = "));
                //Serial.print(dP_dt);
                //Serial.print(F("kPa/h --> "));
                return forecast;
                Wire.begin(); // Wire.begin(sda, scl)
              void presentation()  {
                sendSketchInfo("BME280 Sensor", "1.6");
                // Register sensors to gw (they will be created as child devices)
                present(BARO_CHILD, S_BARO);
                present(TEMP_CHILD, S_TEMP);
                present(HUM_CHILD, S_HUM);
              // Loop
                // need to read the NVM compensation parameters
                BME280.readCompensationParams();
                /* After taking the measurement the chip goes back to sleep, use when battery powered.
                // Oversampling settings (os1x, os2x, os4x, os8x or os16x).
                BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient, higher numbers avoid sudden changes to be accounted for (such as slamming a door)
                BME280.writeOversamplingPressure(os16x);    // pressure x16
                BME280.writeOversamplingTemperature(os8x);  // temperature x8
                BME280.writeOversamplingHumidity(os8x);     // humidity x8
                BME280.writeMode(smForced);                 // Forced sample.  After taking the measurement the chip goes back to sleep
                // Normal mode for regular automatic samples
                BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
                BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
                BME280.writeMode(smNormal);
                while (1) {
                  // Just to be sure, wait until sensor is done mesuring
                  while (BME280.isMeasuring()) {
                // Read out the data - must do this before calling the getxxxxx routines
                BME280.readMeasurements();
                float temperature = BME280.getTemperatureMostAccurate();                    // must get temp first
                float humidity = BME280.getHumidityMostAccurate();
                float pressure_local = BME280.getPressureMostAccurate();                    // Get pressure at current location
                float pressure = pressure_local/pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255); // Adjust to sea level pressure using user altitude
                int forecast = sample(pressure);
                if (!metric)
                  // Convert to fahrenheit
                  temperature = temperature * 9.0 / 5.0 + 32.0;
                Serial.println();
                Serial.print("Temperature = ");
                Serial.print(temperature);
                Serial.println(metric ? " °C" : " °F");
                Serial.print("Humidity = ");
                Serial.print(humidity);
                Serial.println(" %");
                Serial.print("Pressure = ");
                Serial.print(pressure);
                Serial.println(" hPa");
                Serial.print("Forecast = ");
                Serial.println();
                if (temperature != lastTemp)
                  send(tempMsg.set(temperature, 1));
                  lastTemp = temperature;
                if (humidity != lastHum)
                  send(humMsg.set(humidity, 1));
                  lastHum = humidity;
                if (pressure != lastPressure)
                  send(pressureMsg.set(pressure, 2));
                  lastPressure = pressure;
                if (forecast != lastForecast)
                  send(forecastMsg.set(weather[forecast]));
                  lastForecast = forecast;
                sleep(SLEEP_TIME);
              • Z
                Z
                Zbigniew Ko
                wrote on last edited by Zbigniew Ko
                #22
                @yoshida Thank you very much.
                As soon as I find time I will check it out.
                Yes checked, sketch works.
                Thanks yoshida.
                Please note that the library BME_MOD-1022.h consists of two parts: file-h, and file cpp.
                  I am using the one from adafruit : what's the difference with this other library?
                  alexsh1A 1 Reply Last reply
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @gohan I have been using both libraries with a chinese module I bought from Aliexpress. I did not notice any differences apart from size and maybe a module address, which you can change in either library.
                    • B
                      B
                      bluezr1
                      I used the last sketch posed by Yoshida and for some reason whenever the temp and humidity goes through a stretch where there isn't any change, it's as if the node goes into a deep sleep and doesn't come out of it until I hit the reset on a pro mini.
                      I have it plunged in and not on batteries, so no need for any deep sleep. Is there anything I can change in the sketch? I'm still fairly new at this, although I'm having a blast.
                      • B bluezr1
                        Y
                        Y
                        yoshida
                        @bluezr1 Interesting... :) I used it with a pro mini as well, and my problem was that it ate up the batteries in 2 weeks... :D So I would need more deep sleep for the same sketch :D
                        But for that 2 weeks, it was working well. Temp/Hum/Baro updated every minute.
                        • Y yoshida
                          #27
                          @yoshida did you do the modifications (remove led and regulator) recommended at https://www.mysensors.org/build/battery ?
                          My storage room sensor (https://forum.mysensors.org/topic/7227/esp8266-wifi-gateway-with-rssi-for-rfm69-and-wifi ) uses the bme280. Not sure if that sketch is any help, but you are welcome to use it. It is much much simpler than the sketch posted above though.
                            Y
                            Y
                            yoshida
                            @mfalkvidd good question, yes I have removed the two leds I found, but I am too lame to remove the voltage regulator :( I have read here that the most consuming part is the LED(s)
                              scalpel
                              wrote on last edited by gohan
                              #29
                              @yoshida said in BME280 temp/humidity/pressure sensor:
                              >  * The MySensors Arduino library handles the wireless radio link and protocol
                              >  * between your home built sensors/actuators and HA controller of choice.
                              >  * The sensors forms a self healing radio network with optional repeaters. Each
                              >  * repeater and gateway builds a routing tables in EEPROM which keeps track of the
                              >  * network topology allowing messages to be routed to nodes.
                              >  * Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
                              >  * Copyright (C) 2013-2015 Sensnology AB
                              >  * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                              >  * Documentation: http://www.mysensors.org
                              >  * Support Forum: http://forum.mysensors.org
                              >  * This program is free software; you can redistribute it and/or
                              >  * modify it under the terms of the GNU General Public License
                              >  * version 2 as published by the Free Software Foundation.
                              >  * REVISION HISTORY
                              >  * DESCRIPTION
                              > // Enable debug prints to serial monitor
                              > #define MY_DEBUG
                              > // Enable and select radio type attached
                              > #define MY_RADIO_NRF24
                              > //#define MY_RADIO_RFM69
                              > #include <SPI.h>
                              > #include <MySensors.h>
                              > #include <Wire.h>
                              > #define HUM_CHILD 2
                              > enum FORECAST
                              > float lastHum = -1;
                              > float pressureAvg;
                              > float pressureAvg2;
                              > float dP_dt;
                              > boolean metric;
                              >   minuteCount++;
                              >     minuteCount = 6;
                              >     else
                              >     else
                              >     else
                              >     else
                              >     else
                              >     else
                              >     forecast = UNKNOWN;
                              >     forecast = CLOUDY;
                              >     forecast = SUNNY;
                              >     forecast = STABLE;
                              >   else
                              >     forecast = UNKNOWN;
                              >   return forecast;
                              > void setup() {
                              >   // Send the sketch version information to the gateway and Controller
                              > // Loop
                              > void loop() {
                              >   while (1) {
                              >   if (!metric)
                              >   Serial.println();
                              >   Serial.println();
                              >     lastHum = humidity;
                              >   sleep(SLEEP_TIME);
                              Added to sketch @yoshida battery state send, but its not sending it, please chek it:
                              #define HUM_CHILD 2
                              int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
                              int oldBatteryPcnt = 0;
                              const float ALTITUDE = 450; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
                              const unsigned long SLEEP_TIME = 300000;
                              enum FORECAST
                              float lastHum = -1;
                              float pressureAvg;
                              float pressureAvg2;
                              float dP_dt;
                              boolean metric;
                                minuteCount++;
                                  minuteCount = 6;
                                  forecast = UNKNOWN;
                                  forecast = CLOUDY;
                                  forecast = SUNNY;
                                  forecast = STABLE;
                                  forecast = UNKNOWN;
                                return forecast;
                                analogReference(INTERNAL1V1);
                                analogReference(INTERNAL);
                              // Loop
                                while (1) {
                                if (!metric)
                                Serial.println();
                                Serial.println();
                                  lastHum = humidity;
                                  // Power up radio after sleep
                                  oldBatteryPcnt = batteryPcnt;
                                sleep(SLEEP_TIME);
                              • S scalpel
                                >  * REVISION HISTORY
                                >  * DESCRIPTION
                                > #define MY_DEBUG
                                > #include <SPI.h>
                                > #include <Wire.h>
                                > #define HUM_CHILD 2
                                > enum FORECAST
                                > float lastHum = -1;
                                > float pressureAvg;
                                > float pressureAvg2;
                                > float dP_dt;
                                > boolean metric;
                                >   minuteCount++;
                                >     minuteCount = 6;
                                >     else
                                >     else
                                >     else
                                >     else
                                >     else
                                >     else
                                >     forecast = UNKNOWN;
                                >     forecast = CLOUDY;
                                >     forecast = SUNNY;
                                >     forecast = STABLE;
                                >   else
                                >     forecast = UNKNOWN;
                                >   return forecast;
                                > void setup() {
                                > // Loop
                                > void loop() {
                                >   while (1) {
                                >   if (!metric)
                                >   Serial.println();
                                >   Serial.println();
                                >     lastHum = humidity;
                                >   sleep(SLEEP_TIME);
                                #define HUM_CHILD 2
                                enum FORECAST
                                float lastHum = -1;
                                float pressureAvg;
                                float pressureAvg2;
                                float dP_dt;
                                boolean metric;
                                  minuteCount++;
                                    minuteCount = 6;
                                    forecast = UNKNOWN;
                                    forecast = CLOUDY;
                                    forecast = SUNNY;
                                    forecast = STABLE;
                                    forecast = UNKNOWN;
                                  return forecast;
                                // Loop
                                  while (1) {
                                  if (!metric)
                                  Serial.println();
                                  Serial.println();
                                    lastHum = humidity;
                                  sleep(SLEEP_TIME);
                                sundberg84S
                                sundberg84S
                                @scalpel - works great! Thank you!!
                                Downloaded the library from the link in your sketch and up and running i no time.
                                Here is my sketch, with some modifications:
                                • Lightsensor A0
                                • No sleep (might want to enable repeater function later)
                                • Sends every 5 minute regardless of prevoius value (I use Domoticz and want to avoid red nodes and combined nodes).
                                • Fixed node it
                                //Fixed ID/Parent?
                                #define MY_NODE_ID 20                     //To set a fixed ID for your node
                                //#define MY_PARENT_NODE_ID 100             //To set a fixed parent for this node
                                #define HUM_CHILD 2
                                long interval = 300000;           // interval at which to send (milliseconds)
                                long previousMillis = interval;        // will store last time data was sent
                                const float ALTITUDE = 135; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
                                enum FORECAST
                                float pressureAvg;
                                float pressureAvg2;
                                float dP_dt;
                                boolean metric;
                                //Light
                                #define CHILD_ID_LIGHT 3
                                #define LIGHT_SENSOR_ANALOG_PIN A0
                                MyMessage light_Msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                                  minuteCount++;
                                    minuteCount = 6;
                                    forecast = UNKNOWN;
                                    forecast = CLOUDY;
                                    forecast = SUNNY;
                                    forecast = STABLE;
                                    forecast = UNKNOWN;
                                  return forecast;
                                  sendSketchInfo("WeatherStation #20", "1.0");
                                // Loop
                                if(currentMillis - previousMillis > interval) {
                                    // save the last time sent the data
                                  analogReference(DEFAULT);
                                  wait(500);
                                   readLightLevel();   //Read Light
                                  wait(500);
                                  if (!metric)
                                  Serial.println();
                                  Serial.println();
                                wait(50);
                                wait(50);
                                wait(50);
                                wait(50);
                                void readLightLevel()      {
                                  Serial.println(analogRead(A0));
                                  int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23; //To get a value ranging from 0 (dark) to 100 (bright).
                                #ifdef MY_DEBUG
                                  Serial.print("Light: "); Serial.println(lightLevel);
                                  send(light_Msg.set(lightLevel));
                                • R
                                  R
                                  RickyTerzis
                                  wrote on last edited by RickyTerzis
                                  #31
                                  Hi...i am a new user here. I built a RFM69 gateway and a node.I decided to place the RFM69 node in a basement storage room. The room has been flooded a few times historically, so being able to monitor humidity in the room seems like a good idea.The room has thick brick walls, which the RFM69-433MHz radio is much more capable to handle than the nrf24. Still, I wanted to keep an eye on the signal strength. Because of this, I added code to the gateway to report RSSI from the node.
                                  circuit card assembly
                                  12.5k
