  3. Where do I set the sensor ID?
6 Posts 3 Posters 3.1k Views 2 Watching
  • mark_vennM
    mark_vennM
    mark_venn
    I am going to use openHAB as my controller and as for as I can tell I need to manually set sensor IDs for each bit of kit in my network. I am using a serial gateway, well, was but am currently faultfinding it, and I have a motion sensor that seems to have picked up id 105, I am assuming from the sketch. I can't find 105 anywhere in the sketch for the moion sensor so where is this likely to have come from and how do I set the id for other sensors?
    Cheers
    • sundberg84S
      Use gw.begin(NULL, AUTO, true) change auto to nodeID and true to false if you have battery sensor
      1 argument if incoming messages
      2 argument is node id
      3 argument is repeater mode
      Above is for 1.5.x
      mark_vennM 1 Reply Last reply
      • sundberg84S sundberg84
        Above is for 1.5.x
        mark_vennM
        mark_vennM
        mark_venn
        @sundberg84
        Thanks. I don't know where the motion sensor is picking up 105 then as the gw.begin() is just that with no parameters at all. :unamused:
          Try resetting the node with the cleareeprom sketch (available in the examples folder). Then re-flash your sketch and hopefully it will be back to normal.
            mark_vennM
            mark_vennM
            mark_venn
            @mfalkvidd
            Thanks! I have now set a value of 1 and lo and behold sensor 1 is now talking to the gateway. I vaguely remeber testing eeprom storing values by using a button that advanced a value by one and then stored it. It must have been this Uno I did it on and I must have hit the button 105 times :-)
              Great that it worked. Thanks for reporting the result :)
