  3. ESP8266 Unexpected Crash or Reset
5 Posts 3 Posters 4.3k Views 3 Watching
  • AffordableTechA
    AffordableTechA
    AffordableTech
    I had problems with the ESP8266 Gateway crashing and resetting every few minutes with an "Exception(28)".
    After lots of searching, I found it was a problem in the 'core driver' in the MySensors library (1.51).
    The Fix:
    • Open the "MyMessage.cpp" file in your "...\Arduino\libraries\MySensors" folder.
    • Search for the "MyMessage& MyMessage::set(const char* value)" function (WARNING: there are several similar names).
    • Comment the existing code out and add replacement as illustrated below.
    /*  COMMENT OUT THE OLD FUNCTION
    MyMessage& MyMessage::set(const char* value) {
    	uint8_t length = min(strlen(value), MAX_PAYLOAD);
    	miSetLength(length);
    	miSetPayloadType(P_STRING);
    	strncpy(data, value, length);
    	return *this;
    /*   INSERT THE FOLLOWING IN ITS PLACE   */
    	uint8_t length = value == NULL ? 0 : min(strlen(value), MAX_PAYLOAD);
    	if (length) {
    	// null terminate string
    	data[length] = 0;
    	return *this;
    If you compile any MySensors ESP8266 project, the library will be rebuilt and with a bit of luck the crashes will vanish.
    Paul
    YveauxY 1 Reply Last reply
    • AffordableTechA AffordableTech
      The Fix:
      	return *this;
      	if (length) {
      	data[length] = 0;
      	return *this;
      Paul
      YveauxY
      YveauxY
      @AffordableTech So, concluding, the set-method will crash when called with a null-pointer.
      Does your sketch call it with a null-pointer, or does the MySensors library pass it somewhere along the road?
      AffordableTechA 1 Reply Last reply
      • YveauxY Yveaux
        AffordableTechA
        AffordableTechA
        AffordableTech
        @Yveaux
        Yes, I believe it happens when a client connects with no message, it causes a memory fault (loss); after several such connections the stack is exhausted and the ESP8266 crashes (and reboots).
        This cured my crashes, but I'm sure there are many other possibilities for an Exception(28).
          This has been fixed in development branch. It was never backported.
            AffordableTechA
            AffordableTechA
            AffordableTech
            @hek
            Yes, as I gathered, but I have too many sensors on 1.5.1 and don't want to upgrade them to 2.0 while its not an official release.
            I posted it because there are probably others on 1.5.1 with the problem, but can't find a fix.
            Cheers...
