  3. Signing changes presentation message?
5 Posts 2 Posters 1.5k Views 2 Watching
  • t3chieT Offline
    t3chieT Offline
    t3chie
    Hi all,
    I upgraded a working HomeAssistant setup from version 1.5.4 without signing to use signing.
    Although I can still see message being exchanged, HomeAssistant stopped from autodiscovering the nodes.
    Watching the protocol exchange for a new powered up node reveal a small difference:
    This is what the serial gateway sees with signing disabled:
    97;255;0;0;17;1.5.4
    97;255;3;0;6;0
    97;255;3;0;11;Sensebender Motion
    97;255;3;0;12;1.3.1
    97;1;0;0;6;onboard
    97;2;0;0;7;onboard
    97;3;0;0;1;PIR
    97;1;1;0;0;24.5
    97;2;1;0;1;37
    97;255;3;0;0;101
    97;3;1;0;16;1
    97;3;1;0;16;0
    And this is with signing:
    97;255;3;0;6;0
    97;255;3;0;12;1.3.1
    97;1;0;0;6;onboard
    97;2;0;0;7;onboard
    97;3;0;0;1;PIR
    97;1;1;0;0;23.9
    97;2;1;0;1;38
    97;255;3;0;0;101
    97;3;1;0;16;1
    97;3;1;0;16;0
    The signed version is missing the message where the protocol version used to be. I am quite new to MySensors, so question is if that is an intended behaviour?
    • martinhjelmareM Offline
      martinhjelmare
      Hi!
      Have you confirmed that all sent messages were received by the gateway? Signing maximizes the strain on the radio comms. Signing will expose a not perfect radio environment.
      t3chieT 1 Reply Last reply
        Hi!
        t3chieT Offline
        t3chieT Offline
        t3chie
        @martinhjelmare
        Yes, the two are sitting next to each other. It is consistant that the message with the release (1.5.4) is missing.
        May be my init sub is not correct? I am using this:
          pinMode(LED_PIN, OUTPUT);
          digitalWrite(LED_PIN, LOW);
          pinMode(PIR_SENSOR_DIGITAL, INPUT);
          // Activate internal pull-ups
          digitalWrite(PIR_SENSOR_DIGITAL, HIGH);
          Serial.begin(115200);
          Serial.print(F("Sensebender Motion FW "));
          Serial.print(RELEASE);
          Serial.flush();
          // Make sure that ATSHA204 is not floating
          pinMode(ATSHA204_PIN, INPUT);
          digitalWrite(ATSHA204_PIN, HIGH);
          digitalWrite(TEST_PIN,LOW);
          digitalWrite(OTA_ENABLE, LOW); // remove pullup, save some power.
          digitalWrite(LED_PIN, HIGH);
          gw.begin(NULL, NODE_ADDRESS, false);
          humiditySensor.begin();
          Serial.flush();
          Serial.println(F(" - Online!"));
          gw.sendSketchInfo("Sensebender Motion", RELEASE, REQ_ACK);
          gw.present(CHILD_ID_TEMP,S_TEMP,"onboard", REQ_ACK);
          gw.present(CHILD_ID_HUM,S_HUM,"onboard", REQ_ACK);
          gw.present(CHILD_ID_PIR, S_MOTION, "PIR", REQ_ACK);
          isMetric = gw.getConfig().isMetric;
          Serial.print(F("isMetric: ")); Serial.println(isMetric);
          raHum.clear();
          sendTempHumidityMeasurements(false);
          sendBattLevel(false);
          if (ota_enabled) Serial.println("OTA FW update enabled");
          martinhjelmare
          Having the nodes next to eachother doesn't guarantee good radio comms. You have to verify by connecting a serial monitor to the node, looking at that output, and look at the log from the controller/gateway. Then compare these two lists of sent vs received messages.
          • t3chieT Offline
            t3chieT Offline
            t3chie
            This is output from Serial Gateway with Debug turned on:
            0;0;3;0;9;read: 97-97-0 s=255,c=3,t=15,pt=2,l=2,sg=0:1
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:1
            0;0;3;0;9;read: 97-97-0 s=255,c=3,t=16,pt=0,l=0,sg=0:
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:0171638
            0;0;3;0;9;verify fail
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01C94B5
            0;0;3;0;9;read: 97-97-0 s=255,c=3,t=6,pt=1,l=1,sg=1:0
            97;255;3;0;6;0
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01E5044
            0;0;3;0;9;read: 97-97-0 s=255,c=3,t=11,pt=0,l=18,sg=1:Sensebender Mot
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:0127A06
            0;0;3;0;9;read: 97-97-0 s=255,c=3,t=12,pt=0,l=5,sg=1:1.3.1
            97;255;3;0;12;1.3.1
            And this is with DEBUG and DEBUG_SIGNING turned on:
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01B45E7
            SIM:
            015F593B6382705C14D1165A91896D854A8336D1
            MSG:
            61002E0011FF312E352E34
            CNC:
            01B45E76EEFF4F7F35A50615EBA02F23ECA22B336B6008C39BAAAAAAAAAAAAAA
            HMAC:
            CA16F9C17D683DE7074FEE542CF8B26F41200DCB4AA70072BF96CB6DAE78C5D1
            SNOK:
            0116F9C17D683DE7074FEE542CF8B26F41200DCB
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01E7FED
            SIM:
            010D119CDCF58D40871D2BE7F9DF050CF2D10F956E3D5C69
            MSG:
            61000E2306FF00
            CNC:
            01E7FED0F1F7A2BFC3B8CF302DF6077DA5BC74DF6388C54F8EAAAAAAAAAAAAAA
            HMAC:
            670D119CDCF58D40871D2BE7F9DF050CF2D10F956E3D5C6967D5DA168E46CEAC
            SOK
            97;255;3;0;6;0
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01E5A12
            SIM:
            01B22062689F9E
            MSG:
            610096030BFF53656E736562656E646572204D6F74696F6E
            CNC:
            01E5A122848F72F8A4D2D18F979904FDB389DC6980BD8493AAAAAAAAAAAAAAAA
            HMAC:
            28B22062689F9E3ECC79E3E5CAD58827D1DA38C88C4DE87974C1E05CE8C8068D
            SOK
            0;0;3;0;9;send: 0-0-97-97 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:011B6BD
            SIM:
            017ABA174BDC2555F1A4BB1E2CFE844937C86442
            MSG:
            61002E030CFF312E332E31
            CNC:
            011B6BD4E168AD907C4F8596A93D78FFF19A39E39144BB3DE6AAAAAAAAAAAAAA
            HMAC:
            E67ABA174BDC2555F1A4BB1E2CFE844937C864424509AF34FA335C677A953BE7
            SOK
            The verify fail message is consistent always there which I hardly believe can be from transmission errors?
