  3. [Solved] Noob question: How to set value to actuator via mqtt
4 Posts 3 Posters 1.7k Views 3 Watching
  • Harry van der WolfH Offline
    Harry van der Wolf
    wrote on last edited by Harry van der Wolf
    I'm using the Gatewayesp8266MQTTClient from the Development repository.
    I'm reading 3 temperature sensors without problem.
    I have now positioned a relay in my network using the default RelayActuator. I only set the node id manually to 15.
    I'm using mosquitto on my RaspberryPi and view the messages with mosquitto_sub -v -t 'mygateway1-out/#'
    When I start the node (on a arduino mini pro) I see the following in mosquitto
    mygateway1-out/15/255/0/0/18 1.5.4
    mygateway1-out/15/255/3/0/6 0
    mygateway1-out/15/255/3/0/11 My Relay
    mygateway1-out/15/255/3/0/12 1.0
    mygateway1-out/15/1/0/0/3 (null)
    Edit (sorry, forgotten)
    The serial output is:
    read: 0-0-15 s=255,c=3,t=15,pt=0,l=2,sg=0:
    repeater started, id=15, parent=0, distance=1
    send: 15-15-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:My Relay
    send: 15-15-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 15-15-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    From mosquitto I can give commands as well with mosquitto_pub. Based on the example in https://www.mysensors.org/download/serial_api_15 (last line actually) I used the following commands to switch off/on
    mosquitto_pub -t 'mygateway1-out/15/1/2/0/2' -m 0 and mosquitto_pub -t 'mygateway1-out/15/1/2/0/2' -m 1
    This doesn't work. Unfortunately, not one single combination I try works. sensor=1? sensor=255?
    What am I doing wrong?
    • Harry van der WolfH Harry van der Wolf
      martinhjelmareM Offline
      martinhjelmare
      @Harry-van-der-Wolf
      Hi!
      There should be two different topic prefixes in the client sketch. One for outgoing messages to which the gateway publishes, and one for incoming messages to which the client gateway subscribes. The last topic prefix is the one you should use to publish updates to the gateway.
      The prefix is called mygateway1-in or similar as default.
      Harry van der WolfH 1 Reply Last reply
      • R Offline
        R Offline
        rollercontainer
        Maybe that helps a bit:
        https://forum.mysensors.org/topic/1467/how-to-deal-with-a-request-for-information-from-controller/19
          @Harry-van-der-Wolf
          Hi!
          Harry van der Wolf
          @martinhjelmare and @rollercontainer
          There are days that I feel less intelligent. ;)
          That mygateway1-in is indeed the reason and exactly as specified in the GatewayESP8266MQTTClient.ino sketch for incoming subscribe messages.
          mosquitto_pub -t 'mygateway1-in/15/1/2/0/2' -m 0 and mosquitto_pub -t 'mygateway1-in/15/1/2/0/2' -m 1 does switch the relay off and on.
          Thanks.
