  3. Node sending same value multiple times, why?
7 Posts 2 Posters 1.9k Views 2 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    wrote on last edited by Mark Swift
    Hi guys,
    I'm having an issue with one of my nodes sending the value multiple times (Mostly 3 or 4 times).
    The sketch:
      REVISION HISTORY
      Created by Mark Swift
      V1.1 - Started code clean up
      V1.2 - Cleaned up
      V1.3 - Changed sleep to smartSleep to allow for future developments // Cancelled for now as doesn't work so well!
    #include <OneWire.h>
    //*** MY SENSORS ******************************************
    #define MY_NODE_ID 2
    // #define MY_PARENT_NODE_ID 1 // AUTO
    // #define MY_RADIO_RFM69
    // Channel furthest away from Wifi
    // #define MY_RF24_CHANNEL 125
    // For crappy PA+LNA module
    // #define MY_RF24_PA_LEVEL RF24_PA_LOW
    // Enabled repeater feature for this node
    // #define MY_REPEATER_FEATURE
    //*** CONFIG **********************************************
    // Send temperature only if changed? 1 = Yes 0 = No
    #define COMPARE_TEMP 0
    // Pin where dallas sensor is connected
    #define ONE_WIRE_BUS 3
    // The maximum amount of dallas temperatures connected
    // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    OneWire oneWire(ONE_WIRE_BUS);
    // Pass the oneWire reference to Dallas Temperature
    int numSensors = 0;
    // Define loop time
    #define LOOP_TIME 60000 // Sleep time between reads (in milliseconds)
    // Define sensor children
    #define CHILD_ID1 1 // Dallas temperature sensor
    // Initialise messages
    MyMessage msg(CHILD_ID1, V_TEMP);
      sensors.begin(); // Startup up the OneWire library
      sensors.setWaitForConversion(false); // RequestTemperatures() will not block current thread
      sendSketchInfo("Garage Freezer", "1.3"); // Send the sketch version information to the gateway and Controller
      numSensors = sensors.getDeviceCount(); // Fetch the number of attached temperature sensors
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) // Present all sensors to controller
        present(i, S_TEMP);
      //*** DS18B20 *******************************************
      sensors.requestTemperatures(); // Fetch temperatures from Dallas sensors
      int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); // Query conversion time and sleep until conversion completed
      wait(conversionTime); // Sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater)
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) // Read temperatures and send them to controller
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.; // Fetch and round temperature to one decimal
    #if COMPARE_TEMP == 1 // Only send data if temperature has changed and no error
        if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00)
    #else
        if (temperature != -127.00 && temperature != 85.00)
          send(msg.setSensor(i).set(temperature, 1)); // Send in the new temperature
          wait(500); // If set to sleeping, will still have time to wait for OTA messages...
          lastTemperature[i] = temperature; // Save new temperatures for next compare
      sleep(LOOP_TIME); // Sleep or wait (repeater)
      A serial debug output would be useful for troubleshooting.
      How many connected sensors do you have?
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        Just one sensor...
          Only one sensor is presented, and the same sensor ID is used for all 3-4 messages?
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            Yes, always '0', sometimes it sends twice, sometimes 3, and the odd time 4.
            I've tried clearing the node, uploading a new sketch, it's odd!
            • Mark SwiftM Mark Swift
              How close in time are the messages sent? If it is >500ms between the messages, there is probably something wrong with the loop or sleep (but they look fine to me).
              If the time between messages is <100ms maybe the ACK doesn't reach the sensor node so it resends the message.
              A serial debug output would show what is happening.
              • Mark SwiftM
                Mark SwiftM
                Mark Swift
                I'll try a debug when I'm home, but this is a remote node using MYS firmware...
                See MYS screenshots here: http://postimg.org/gallery/8ynl0jw/c4dcd695/
