  3. RFM69 gatway problem
5 Posts 3 Posters 2.2k Views 3 Watching
  • C
    C
    csnij
    I wil start with a simple humidity sensor and a rfm69 gatway in my vera.
    Now i wil program the seriel gatway. but he gifs a error.
    I have disabled some things in myconfig.h
    This is the error:
    WAARSCHUWING: Categorie '' in bibliotheek UIPEthernet is niet geldig. Wordt gewijzigd naar 'Uncategorized'
    In file included from C:\Users\chris\AppData\Local\Temp\arduino_modified_sketch_351535\SerialGateway.ino:46:0:
    C:\Program Files (x86)\Arduino\libraries\MySensors/MySigningAtsha204.h:40:3: error: conflicting declaration 'typedef struct whitelist_entry_t whitelist_entry_t'
    } whitelist_entry_t;
    In file included from C:\Users\chris\AppData\Local\Temp\arduino_modified_sketch_351535\SerialGateway.ino:45:0:
    C:\Program Files (x86)\Arduino\libraries\MySensors/MySigningAtsha204Soft.h:44:3: error: 'whitelist_entry_t' has a previous declaration as 'typedef struct whitelist_entry_t whitelist_entry_t'
    SerialGateway:67: error: conflicting declaration 'MySigningAtsha204Soft signer'
    MySigningAtsha204Soft signer;
    SerialGateway:66: error: 'signer' has a previous declaration as 'MySigningNone signer'
    MySigningNone signer;
    SerialGateway:68: error: conflicting declaration 'MySigningAtsha204 signer'
    MySigningAtsha204 signer;
    exit status 1
    What do i wrong,
    chris
    • C
      C
      csnij
      I found the problem. I have severol times reinstold the arduino software and the liberys. now its uploading working.
      gateway is finist.
      now i traid a humedity sensor, but i have a message radio init fail
      I have check the voltage. he is ok
      Check the wire, is also ok.
      What can i check more.
      chris
      chris
      • C csnij
        gateway is finist.
        chris
        chris
        @csnij check the wiring again :) If possible, try the radio on another node and another radio on this node.
        • C
          C
          csnij
          I order New rfm69 i think that they not working.
          Is here somebody, they can some firmware wrote to check of the radio' s communicating.😁
          Thanx chris
          • FleischtorteF
            FleischtorteF
            Fleischtorte
            Hi Chris,
            You can test the RFM69 communication with the example sketchs from LowPowerLab (https://github.com/LowPowerLab/RFM69/tree/master/Examples), you only need the two libarys (SPIFlash, RFM69).
