  3. [Branch][beta 2.0] GW with dallas temp not sending data to domoticz
6 Posts 2 Posters 2.3k Views 2 Watching
  • A
    A
    afick
    Hello i have problem with dallas temp sensor on my GW with LAN.
    GW read data from dallas but is not sended to domoticz
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
    //SET POWER
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #if !defined(MY_W5100_SPI_EN)
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN 15
      #define MY_SOFT_SPI_MISO_PIN 17
      #define MY_SOFT_SPI_MOSI_PIN 16
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    //#define MY_RF24_PA_LEVEL RF24_PA_MIN
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,0,11   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    //DALLAS
    #include <OneWire.h>
    #define ONE_WIRE_BUS 22 // Pin where dallase sensor is connected
    #define MAX_ATTACHED_DS18B20 2
    //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    OneWire oneWire(ONE_WIRE_BUS);
    DallasTemperature sensorsDallas(&oneWire);
    int numSensors = 1;
    #define CHILD_ID_DALLAS 9
    MyMessage msgDallas(CHILD_ID_DALLAS, V_TEMP);
    int temperatureDallas = -300;
    void presentation() {
      //DALLLAS
      sensorsDallas.begin();
      numSensors = sensorsDallas.getDeviceCount();
      present(CHILD_ID_DALLAS, S_TEMP);
      //DALLAS
      sensorsDallas.requestTemperatures();
      Serial.println("reading from  dallas");
      int16_t conversionTime = sensorsDallas.millisToWaitForConversion(sensorsDallas.getResolution());
      sleep(conversionTime);
     Serial.println("in dallas loop dallas");
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensorsDallas.getTempCByIndex(i):sensorsDallas.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
      Serial.println("sendign data from dallas");
         Serial.println(send(msgDallas.set(temperature,1)));
          lastTemperature[i]=temperature; }
        Serial.println(temperature);
    any idea why ?
    • A afick
       * LED purposes:
      //SET POWER
        #define MY_SOFTSPI
      // Enable to UDP
      //DALLAS
      int numSensors = 1;
        //DALLLAS
        //DALLAS
          #else
      any idea why ?
      @afick the send call is wrong.
      From the example:
      send(msg.setSensor(i).set(temperature,1));
      • A
        A
        afick
        wrote on last edited by afick
        Thanks for help, but after change to
        send(msgDallas.setSensor(i).set(temperature,1));
        Still not working ... ;(
          The serial debug output would help immensely. Could you post it?
          • A
            A
            afick
            HELLO,
            serial debug is poor....
             data from dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            gn data from dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
            0;255;3;0;9;Radio init successful.
            IP: 192.168.0.11
            0;255;3;0;9;Init complete, id=0, parent=0, distance=0
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.00
            reading from  dallas
            25.50
            reading from  dallas
            25.00
            reading from  dallas
            25.50
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.00
            reading from  dallas
            25.50
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.50
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.00
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            25.50
            reading from  dallas
            26.00
            reading from  dallas
            26.00
            reading from  dallas
            26.00
            reading from  dallas
            26.00
            reading from  dallas
            26.50
            reading from  dallas
            26.50
            reading from  dallas
            26.50
            reading from  dallas
            26.50
            reading from  dallas
            27.00
            reading from  dallas
            27.00
            reading from  dallas
            27.00
            reading from  dallas
            27.00
            reading from  dallas
            27.50
            reading from  dallas
            27.50
            reading from  dallas
            27.50
            reading from  dallas
            27.50
            reading from  dallas
            27.50
            reading from  dallas
            27.50
            reading from  dallas
            28.00
            reading from  dallas
            28.00
            reading from  dallas
            28.00
            reading from  dallas
            28.00
            reading from  dallas
            28.00
            reading from  dallas
            28.50
            reading from  dallas
            28.50
            reading from  dallas
            28.50
            reading from  dallas
            28.50
            reading from  dallas
            28.50
            reading from  dallas
            28.50
            reading from  dallas
            28.50
            reading from  dallas
            28.50
            reading from  dallas
            29.00
            reading from  dallas
            29.00
            reading from  dallas
            29.00
            reading from  dallas
            29.00
            reading from  dallas
            29.00
            reading from  dallas
            29.00
            reading from  dallas
            29.00
            reading from  dallas
            29.00
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            29.50
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.00
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            0;255;3;0;9;Eth: connect
            0;255;3;0;9;Eth: 0;0;3;0;2;
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
            30.50
            reading from  dallas
            30.50
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            0;255;3;0;9;Eth: 0;0;3;0;18;PING
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.00
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            31.50
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.00
            reading from  dallas
            32.50
            reading from  dallas
            32.00
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            33.00
            reading from  dallas
            32.50
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            33.00
            reading from  dallas
            32.50
            reading from  dallas
            33.00
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            0;255;3;0;9;read: 2-2-0 s=10,c=1,t=13,pt=2,l=2,sg=0:98
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            reading from  dallas
            32.50
            All what i get is all what i send to serial...
              1. You are missing
              sendSketchInfo
              in presentation().
              1. In presentation(),
              sensors.begin();
              is run. In the example that line is in setup().
              3. This:
              is missing.
              Not sure how much any of it matters, but maybe they are important.
