  3. Home Assistant
  4. Can't see my nodes on HA web interface
20 Posts 6 Posters 7.5k Views 6 Watching
  • maverickM
    maverickM
    maverick
    Hi guys.
    I am new to mysensors and homeassistant. I've recently finished my gateway and my first relay node for switching lights on/off. Everything looks good, but I can't see my nodes on the HA web interface. What can I be doing wrong?
    I've made this for the serial gateway: https://www.mysensors.org/build/serial_gateway
    And for the node I've followed this: https://www.mysensors.org/build/relay (same code shown on the video)
    this is my configuration.yaml:
    homeassistant:
      latitude: NONE
      longitude: NONE
      temperature_unit: C
      time_zone: UTC
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
      debug: true
      persistence: true
      version: '1.5'
      optimistic: false
    history:
    logbook:
    discovery:
    frontend:
    conversation:
    updater:
    First I've started my homeassistant and I see this logs:
    Starting Home-Assistant
    INFO:homeassistant.core:Starting Home Assistant (16 threads)
    INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
    INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
    INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
    INFO:homeassistant.core:Timer:starting
    INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
    INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
    INFO:netdisco.service:Scanning
    WARNING:homeassistant.components.recorder:Found unfinished sessions
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
    then connect my node to the power and I've got this logs
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.4
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-19-19 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=255,c=3,t=11,pt=0,l=12,sg=0:Relay Outlet
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=0,c=0,t=3,pt=0,l=0,sg=0:
    WARNING:mysensors.mysensors:child_id 0 already exists in children, cannot add child
    after that i don't see any nodes on the web interface.
    Thanks for your help and patience.
    • maverickM maverick
      Hi guys.
      homeassistant:
        latitude: NONE
        longitude: NONE
        temperature_unit: C
        time_zone: UTC
      mysensors:
        gateways:
        debug: true
        persistence: true
        version: '1.5'
        optimistic: false
      history:
      logbook:
      discovery:
      frontend:
      conversation:
      updater:
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @maverick
      Hi!
      You need to send an initial value for the relay.
      https://home-assistant.io/components/mysensors/#presentation
      https://home-assistant.io/components/switch.mysensors/#example-sketch
      • maverickM
        maverickM
        maverick
        @martinhjelmare
        Thanks for your quick reply! I've made those changes to the sketch and uploaded again, now logs looks better without any WARNING.
        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=1,c=1,t=3,pt=2,l=2,sg=0:0
        What's the next step? I'm still not seeing nodes on my web interface... Where it's supposed to be located?
        Thanks.
          @martinhjelmare
          Thanks.
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @maverick
          The last log line shows a set message of type 3 which is V_DIMMER or V_PERCENTAGE. That type should not be used for a simple on/off switch. You should use V_STATUS instead.
          • maverickM
            maverickM
            maverick
            @martinhjelmare
            Hi Martin, I've been reading a lot and still no lucky, can't see my node on the HA. Take a look to my sketch and logs. There's something wrong?
            Thanks again!
            Sketch:
             * Version 1.0 - Henrik Ekblad
            #include <MySigningNone.h>
            #include <MyTransportNRF24.h>
            #include <MyTransportRFM69.h>
            #include <MyHwATMega328.h>
            #define SN "Relay Outlet"
            #define SV "1.0"
            #define NODE_ID 19
            #define RELAY_PIN  3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            #define RELAY_CHILD 1
            //MyTransportRFM69 radio;
            //MySigningNone signer;
            MyHwATMega328 hw;
            MySensor gw(radio, hw);
            MyMessage msg(RELAY_CHILD, V_STATUS);
              gw.begin(incomingMessage, NODE_ID);
              gw.sendSketchInfo(SN, SV);
              gw.present(RELAY_CHILD, S_LIGHT);
              pinMode(RELAY_PIN, OUTPUT);
              gw.process();
              if (message.type==V_STATUS) {
                 // Change relay state
                 digitalWrite(RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                 // Store state in eeprom
                 //gw.saveState(message.sensor, message.getBool());
                 // Write some debug info
                 Serial.print(message.sensor);
            Logs:
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read and forward: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
            WARNING:mysensors.mysensors:Error decoding message from gateway, bad data received:
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
            WARNING:mysensors.mysensors:child_id 1 already exists in children, cannot add child
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              You need to add this to the end of setup function:
              gw.send(msg.set(0));
              The warning in the log is due to the node and child is already loaded from the persistence file, when you start the node and present the child to the gateway. This doesn't matter, as long as you haven't changed the child type. If you want to start with a clean sheet, you can delete the persistence file, restart hass and start the node.
              You can also try the example sketch that I linked to above. I added the example sketches to the mysensors documentation at home-assistant.io to make it easy to get going and test each mysensors component. When you see that the example sketch is working, you can modify it to your preference.
              • maverickM
                maverickM
                maverick
                @martinhjelmare
                Martin, I've added that line and now i can see the sensor as a switch on my HA web interface. The thing now is, when I trigger the switch from OFF to ON, the serial gateway sends the information to the node but the switch come back to OFF state. This is what i'm seeing on logs
                INFO:homeassistant.components.mysensors:No sketch_name: node 19
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 19-19-0 s=1,c=1,t=2,pt=2,l=2,sg=0:1
                INFO:homeassistant.components.mysensors:Adding new devices: <Entity Relay Outlet 19 1: off>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state switch.relay_outlet_19_1=unavailable; friendly_name=Relay Outlet 19 1 @ 2016-06-06T13:53:25.968979-03:00>, entity_id=switch.relay_outlet_19_1>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state group.all_switches=unknown; auto=True, friendly_name=all switches, hidden=True, order=0, entity_id=[] @ 2016-06-06T13:53:25.981643-03:00>, entity_id=group.all_switches>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state group.all_switches=unknown; auto=True, friendly_name=all switches, hidden=True, order=0, entity_id=[] @ 2016-06-06T13:53:25.981643-03:00>, new_state=None, entity_id=group.all_switches>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state group.all_switches=unknown; auto=True, friendly_name=all switches, hidden=True, order=0, entity_id=('switch.relay_outlet_19_1',) @ 2016-06-06T13:53:26.018724-03:00>, entity_id=group.all_switches>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state switch.relay_outlet_19_1=unavailable; friendly_name=Relay Outlet 19 1 @ 2016-06-06T13:53:25.968979-03:00>, new_state=<state switch.relay_outlet_19_1=on; V_STATUS=on, battery_level=0, child_id=1, device=/dev/ttyUSB0, friendly_name=Relay Outlet 19 1, node_id=19 @ 2016-06-06T13:53:26.042212-03:00>, entity_id=switch.relay_outlet_19_1>
                INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state group.all_switches=unknown; auto=True, friendly_name=all switches, hidden=True, order=0, entity_id=('switch.relay_outlet_19_1',) @ 2016-06-06T13:53:26.018724-03:00>, new_state=<state group.all_switches=on; auto=True, friendly_name=all switches, hidden=True, order=0, entity_id=('switch.relay_outlet_19_1',) @ 2016-06-06T13:53:26.070897-03:00>, entity_id=group.all_switches>
                this is what i see when i press the switch from HA web interface
                INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, service_data=entity_id=switch.relay_outlet_19_1, service=turn_off, service_call_id=3055117168-3>
                INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=switch, service_data=entity_id=['switch.relay_outlet_19_1'], service=turn_off, service_call_id=3055117168-4>
                INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=3055117168-4>
                INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=3055117168-3>
                INFO:homeassistant.components.http:"POST /api/services/homeassistant/turn_off HTTP/1.1" 200 -
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-19-19 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                Thanks!
                • Dave DanD
                  Dave DanD
                  Dave Dan
                  I had the same issue but adding this in the sensor config will make it work:
                    optimistic: true
                  I think is related to the fact that your node is not sending confirmation after assigning the new value (activating /deactivating the relay).
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    Yes, @Dave-Dan is correct. Look at the example sketch, in the end, you'll see that the node sends confirmation of the updated state back to the gateway and controller.
                    • D
                      D
                      drock1985
                      I've got an updated relay+button script at home that fixes this issue. I'll post it after work for anyone else who may need it.
                      My Projects
                      2 Door Chime Sensor
                      Washing Machine Monitor
                      A 1 Reply Last reply
                      • maverickM
                        maverickM
                        maverick
                        @Dave-Dan @martinhjelmare
                        Guys, I've changed that configuration and it perfectly works !!!
                        Now I'm going to automate all the house... ;-)
                        Thanks for all the support and patience.
                        • D drock1985
                          A
                          A
                          anarro
                          @drock1985, please can you share it?
                          Thank you.
                          Antoni.
                          D 1 Reply Last reply
                          • A anarro
                            Thank you.
                            Antoni.
                            D
                            D
                            drock1985
                            @anarro
                            I looked for the sketch the other night and I must have not backed it up on my laptop. I'll see if I can find it in a backup on the weekend/recreate it.
                            My Projects
                            2 Door Chime Sensor
                            • maverickM
                              maverickM
                              maverick
                              Guys, I'm adding this info to the thread just in case that someone may get this useful.
                              This is my final sketch:
                              #define SN "Living Foot Lamp"
                              #define SV "1.0"
                              #define NODE_ID 19
                              MyHwATMega328 hw;
                                gw.process();
                                    // debug info
                              I'm not finished my board, but here are some pictures showing how I assembled all the pieces
                              Video: Show how is The Relay is Working
                              • D
                                D
                                drock1985
                                @anarro
                                Hey, I am going through and upgrading my nodes to 2.0 Beta; the same 'bug' exists there so I had to patch it to work with HA.
                                Use this code from the 2.0 Beta. Basically all you have to do is tell the node to broadcast its state on receipt of message. This works from both the button and the HA web interface.
                                 * Example sketch for a "light switch" where you can control light or something
                                 * else from both HA controller and a local physical button
                                 * (connected between digital pin 3 and GND).
                                 * This node also works as a repeader for other nodes
                                // Enabled repeater feature for this node
                                #define MY_REPEATER_FEATURE
                                #define MY_NODE_ID 4
                                #include <Bounce2.h>
                                #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
                                #define BUTTON_PIN  6  // Arduino Digital I/O pin number for button
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                Bounce debouncer = Bounce();
                                int oldValue=0;
                                bool state;
                                MyMessage msg(CHILD_ID,V_LIGHT);
                                  // Setup the button
                                  pinMode(BUTTON_PIN,INPUT);
                                  // Activate internal pull-up
                                  debouncer.attach(BUTTON_PIN);
                                  debouncer.interval(5);
                                  state = loadState(CHILD_ID);
                                //  send(msg.set(1));
                                void presentation()  {
                                  sendSketchInfo("Lamp", "1.0");
                                  present(CHILD_ID, S_LIGHT);
                                  debouncer.update();
                                  // Get the update value
                                  int value = debouncer.read();
                                  if (value != oldValue && value==0) {
                                      send(msg.set(state?false:true), true); // Send new state and request ack back
                                  oldValue = value;
                                  if (message.isAck()) {
                                     state = message.getBool();
                                     send(msg.set(state?RELAY_ON:RELAY_OFF));
                                     saveState(CHILD_ID, state);
                                My Projects
                                2 Door Chime Sensor
                                adrianA 1 Reply Last reply
                                • maverickM
                                  maverickM
                                  maverick
                                  @anarro
                                  Awesome! Thanks mate
                                  • D drock1985
                                    @anarro
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValue=0;
                                    bool state;
                                      // Setup the button
                                      debouncer.update();
                                      oldValue = value;
                                    adrianA
                                    adrianA
                                    adrian
                                    @drock1985
                                    I tried your sketch mate but I still can't see my relay node in the webif.
                                    Binary sensors work great but I can't get the the relay node to work.
                                    Node serial
                                    Starting repeater (RNNRA-, 2.0.0)
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSP:ASSIGNID:OK (ID=7)
                                    TSM:FPAR
                                    TSP:MSG:SEND 7-7-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                    TSP:MSG:READ 0-0-7 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    TSP:MSG:PAR OK (ID=0, dist=1)
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:CHKID:OK (ID=7)
                                    TSM:UPL
                                    TSP:PING:SEND (dest=0)
                                    TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                    TSP:MSG:READ 0-0-7 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    TSP:MSG:PONG RECV (hops=1)
                                    TSP:CHKUPL:OK
                                    TSM:UPL:OK
                                    TSM:READY
                                    NODE:!REG
                                    TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                    TSP:MSG:SEND 7-7-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                    TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                    TSP:MSG:READ 0-0-7 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    TSP:MSG:READ 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=11,pt=0,l=4,sg=0,ft=0,st=ok:Lamp
                                    TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                    TSP:MSG:SEND 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                    Request registration...
                                    TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                    TSP:MSG:READ 0-0-7 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    Node registration=1
                                    Init complete, id=7, parent=0, distance=1, registration=1
                                    The sketch is the same I just changed MySensor.h to MySensors.h and the NODE ID to 7,
                                    HA log
                                    16-07-30 11:21:15 homeassistant.components.mysensors: update sensor_update: node 7
                                    • adrianA adrian
                                      @drock1985
                                      Node serial
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=7)
                                      TSM:UPL
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      NODE:!REG
                                      Node registration=1
                                      HA log
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @adrian
                                      No value is sent for the light in the log. Home assistant needs at least one value to show the device in the gui.
                                      In 2.0.0 setup is called before presentation, and the node is not registered on the gateway until after presentation. The node is not allowed to send regular messages until it's registered. This logic flow makes it hard for controllers that need an initial value. You have to make sure to send the value at least once in the loop. I would try to do this specifically and separate from the normal flow of the loop.
                                      In the dev branch of mysensors setup is called after registration, so there you could send the initial value in setup.
                                        @adrian
                                        adrianA
                                        adrianA
                                        adrian
                                        @martinhjelmare
                                        For now I should send the state msg from the loop?
                                        Can you share one of your sketches?
                                        Thanks a lot
                                        • adrianA adrian
                                          @martinhjelmare
                                          Thanks a lot
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @adrian
                                          I would try something like this:
                                          #define MY_NODE_ID 1
                                          #define RELAY_PIN  5  // Arduino Digital I/O pin number for relay
                                          #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                                          #define CHILD_ID 1
                                          #define RELAY_ON 1
                                          #define RELAY_OFF 0
                                          bool state = false;
                                          bool initialValueSent = false;
                                          MyMessage msg(CHILD_ID, V_STATUS);
                                            // Setup the button
                                            pinMode(BUTTON_PIN, INPUT_PULLUP);
                                            debouncer.interval(10);
                                            present(CHILD_ID, S_BINARY);
                                            if (!initialValueSent) {
                                              Serial.println("Requesting initial value from controller");
                                              request(CHILD_ID, V_STATUS);
                                              wait(2000, C_SET, V_STATUS);
                                            if (debouncer.update()) {
                                              if (debouncer.read()==LOW) {
                                                state = !state;
                                                send(msg.set(state?RELAY_ON:RELAY_OFF), true); // Send new state and request ack back
                                                Serial.println("Receiving initial value from controller");
                                                initialValueSent = true;
                                              state = (bool)message.getInt();
                                              Serial.println(message.getInt());
                                          Node serial log:
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSP:ASSIGNID:OK (ID=1)
                                          TSM:FPAR
                                          TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:CHKID:OK (ID=1)
                                          TSM:UPL
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=4,sg=0,ft=0,st=ok:Lamp
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                          TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          Node registration=1
                                          Init complete, id=1, parent=0, distance=1, registration=1
                                          TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                                          TSP:MSG:SEND 1-1-0-0 s=1,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                          Incoming change for sensor:1, New status: 0
                                          TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
                                          TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=2,l=2,sg=0:1
                                          Incoming change for sensor:1, New status: 1
                                          TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=2,l=2,sg=0:0
                                          Btw, message.getBool() always returns 0 in my tests, so I switched to message.getInt() in the sketch above. Can anyone confirm that message.getBool is working in 2.0.0?
