  3. Weather Station Sketch
4 Posts 2 Posters 2.0k Views 2 Watching
  • maximM
    maximM
    maxim
    Hello everybody,
    I have a question about the weather station sketch:
    https://github.com/windkh/mysensors/blob/master/WeatherStationSensor/WeatherStationSensor.ino
    this sketch is recommended in the forum but the DHT sensor measures no temperature changes or humidity change, during BMP180 to a temperature change responds.
    I have tested the DHT-sensor with the Humidity Sketch of Mysensors under IDE> examples, the sensor reacts immediately to a change in temperature.
    Only when I reboot Arduino, then DHT provides the right temperature !?
    Even the official weather station sketch behaves exactly
    Can someone help me, thanks in advance.
    (Between pin1 and pin2 a 10Kohm resistor is built)
    greeting
    Timo
    • maximM maxim
      Hello everybody,
      greeting
      Timo
      Hi @maxim, welcome to the MySensors forum!
      Whatd does the serial debug output say?
      • maximM
        maximM
        maxim
        Hi, thanks for your reply.
        I see in the serial monitor (debug is enabled) that the temperature and the humidity data are alternately displayed, but no changes are displayed. If I put an ice pack on the sensor, it shows 24 degrees :)
        But after about an hour I see in serial monitor that the temperature goes down to 12 degrees.
        • maximM
          maximM
          maxim
          also the official Sketch with development library behaves the same way, which means there is no temperature change of DHT22 in serial monitor display, after a new start of Arduino I see the right temperature, I do not know what I'm doing wrong?
          Sketch:
          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/WeatherStationSensor/WeatherStationSensor.ino
