  3. 2.4" TFT: does it work with MySensors?
13 Posts 5 Posters 5.9k Views 5 Watching
  • jsiddallJ
    jsiddallJ
    jsiddall
    I noticed on the store in the Displays section a cheap 2.4" LCD screen. It is a bit tricky to find any details on this thing but one eBay seller who appears to be selling this model states:
    Uses digital pins 5-13 and analog 0-3. That means you can use digital pins 2, 3 and analog 4 and 5. Pin 12
    That does seem to line up with the pin labels on the shield.
    However, the NRF24L01+ radio also uses pins 9-13. It seems to me these two things are incompatible.
    I searched the forum but it doesn't appear anyone has used one of these.
    Can anyone confirm if you can use one of these and a radio on an Uno? It seems strange to put something in the MySensors store that doesn't work so I am hoping I am just missing something.
    alexsh1A 1 Reply Last reply
      All screens can be used with enough effort. I got a screen working that needed 20 pins, see https://forum.mysensors.org/topic/3438/physical-mood-light-color-and-brightness-selector-based-on-lcd-touchscreen-with-demo-video/
      I think the screen in the MySensors store is an ili9341, which should support spi which means you can use 4 pins to connect it. http://www.aliexpress.com/item/2-4-inch-LCD-module-SPI-serial-module-2-4-inch-TFT-module-ILI9341-only-9/32526066165.html might be a better choice since it says which screen it is.
      You can move the radio by using softspi, see https://www.mysensors.org/build/ethernet_gateway for instructions on how to do that.
      jsiddallJ the cosmic gateT 2 Replies Last reply
      • jsiddallJ jsiddall
        alexsh1A
        alexsh1A
        alexsh1
        @jsiddall Yes, it does work. However, you may have to spend some time looking for a screen processor and schematics as Chinese are not providing much information.
        1. Ask for schematics and have a look - there are four digital pins on your Arduino used for the SD card. Disolder these pins (some screens do not have them). These can be used for nrf24l01+ with Soft SPI (you have to enable it in MyConfig.h and change MISO, MOSO and SCK pins to correspond the pins you use).
        2. Please do a bit research on Arduino forum. There is a sketch to help you to define a screen processor, there is a new library etc tons of information available.
        3. It may take a while to do the whole research - there are many-many posts.
        I have tried recently three different screens 2.8-3.2 (one similar to yours with analogue pins) with MySensors and all of them were working. Abeit one was very difficult - took me a while to
        take it work due to lack of documentation.
        I posted some pictures in "Scene Controller" under "Development" - please have a look
        PS @mfalkvidd provided excellent links
          jsiddallJ
          jsiddallJ
          jsiddall
          I think the screen In the MySensors store is an ili9341, which should support spi which means you can use 4 pins to connect it. http://www.aliexpress.com/item/2-4-inch-LCD-module-SPI-serial-module-2-4-inch-TFT-module-ILI9341-only-9/32526066165.html might be a better choice snce it says which screen it is.
          Great info, thanks for pointing me in the right direction.
          Good point about the SD pins and thanks for the info on reassigning the radio pins. Those are the pieces I was scratching my head about.
          • sudo_bash80S
            sudo_bash80S
            sudo_bash80
            Yes it will definitely work . I have a mega2560 with such a tft fitted along with the NRF radio and SDCARD connected. Just define softSPI in myconfig.h at the bottom. Remove // from //define soft spires then choose your pins. Don't forget to reasign the CS and CE pins accordingly to. These are set just above the softSPI definitions. Good luck.
              the cosmic gateT
              the cosmic gateT
              the cosmic gate
              wrote on last edited by the cosmic gate
              i own one of these 2.4" aliexpress screens and trying to get this work with mysensors.
              But at the moment without any result . Could you share the sketch you uses and works ?
              Got the screen running using : this test lib: https://github.com/Smoke-And-Wires/TFT-Shield-Example-Code/tree/master/SWTFT-Shield
              It seems to be that some pin's must be changed , but on the 2.4 inch display this :
              • GND GND
              • 5V -> Step down -> 3V3 (see buying guide for help finding step-down)
              • SCK ??
              • MOSI ??
              • MISO ??
              • CE ??
              • CSN ??
              are not direct on this display visible , what are these
              There's more than meets the eye
              mfalkviddM alexsh1A 2 Replies Last reply
              • the cosmic gateT the cosmic gate
                • GND GND
                • SCK ??
                • MOSI ??
                • MISO ??
                • CE ??
                • CSN ??
                @the-cosmic-gate the sketches are included in the link you quoted.
                  • GND GND
                  • SCK ??
                  • MOSI ??
                  • MISO ??
                  • CE ??
                  • CSN ??
                  alexsh1A
                  alexsh1A
                  alexsh1
                  You do not need any sketches for now. Did you identify the chip model and number? I would suggest you go on Arduino forum and start reading about it - there are many threads over there depending on your screen make and model. You need to get the correct
                  pinout diagram and library, which you may need to correct.
                  I did spent a few days trying to make a cheap Aliexpress TFT screen work. It took me hours and hours. That screen was returned and now I have the screen from Itead Studio guys. It works like a charm as all pins are standard, i.e. used by libraries like UTFT.
                  Additionally, you may want to try this library:
                  https://forum.arduino.cc/index.php?topic=366304.0
                  There are some example sketches included including a possible screen pinout.
                  the cosmic gateT 1 Reply Last reply
                  • alexsh1A alexsh1
                    the cosmic gateT
                    the cosmic gateT
                    the cosmic gate
                    yesterday late in the evening got this lib ( https://github.com/Smoke-And-Wires/TFT-Shield-Example-Code/tree/master/SWTFT-Shield ) running, and displayed the rotation and graphic test ( touch doesn't work :S )
                    Try to find out the right pin's for this mysensors scene controller
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @the-cosmic-gate First things first. You need to sort out the problem with touch. Basically, you need to load the 'paint' sketch and be able to draw or paint on your screen. If it does not work, there is no point moving to softSPI/MySensors as you won't have a working scene controller (touch is important). Additionally, I'd suggest you try to stick to UTFT library.
                      You may spend a lot of time on this as these cheap screens normally have zero documentation. You can contact the seller and ask about schematic - this would help you to identify pinout. My first cheap TFT screen had pins A2-A6 used for touch if I remember correctly
                      • the cosmic gateT
                        the cosmic gateT
                        the cosmic gate
                        Then it should be faster/ easier to order some working/ approved screens for some quick solution, and take some extra time to get this screens team work
                        • sudo_bash80S
                          sudo_bash80S
                          sudo_bash80
                          My first attempt at using a screen like this was on a mega2560! This makes things even more complicated with these cheap screens as the internal port mapping is completely different on the mega2560. However I did eventually get it working using the superb SWtft library which has #defines for the Uno/Mega2560 pinouts . Still takes a lot to get going though!
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @the-cosmic-gate There are so many manufacturers! Generally, as a rule of thumb the cheaper you pay for the screen the more difficult it is to get it working. Besides, anything to do with Arduino does require some DIY skills :-)
                            Above I recommended Itead Studio screen, but it does cost more though works out of the box.
