  3. Problems with develop branch
3 Posts 2 Posters 1.4k Views
  • dakkyD Offline
    dakkyD Offline
    dakky
    wrote on last edited by dakky
    Hello ;)
    I used the develop branch quite a while and everthing was fine.
    But now i can't get the communication up between controller and node. I didn't change something on the hardware side, so I think there is an error on the software part.
    This is what I can see on the node:
    Starting sensor (RNNNA-, 2.0.0-beta)
    TSM:INIT
    RADIO:OK
    assign node ID=1
    TSM:PARENT
    send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    TSM:PARENT
    TSM:PARENT
    TSM:PARENT
    read: 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    node 0 replied, d=0, _nc.distance=255
    parent=0, d=1
    TSM:ID
    node ID=1
    pinging node 0
    send: 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,st=ok:1
    TSM:PARENT
    TSM:PARENT
    TSM:PARENT
    TSM:PARENT
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    RADIO:OK
    assign node ID=1
    TSM:PARENT
    parent=0, d=1
    TSM:ID
    node ID=1
    pinging node 0
    TSM:PARENT
    TSM:PARENT
    parent=0, d=1
    TSM:ID
    node ID=1
    TSM:PARENT
    TSM:PARENT
    TSM:PARENT
    TSM:PARENT
    !TSM:FAILURE
    TSM:PDT
    On the gateway side i can see:
    0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
    IP: 192.168.100.10
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:OK
    0;255;3;0;9;read: 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;FPREQ from 1
    0;255;3;0;9;GWL ok, FPRES to 1
    0;255;3;0;9;send: 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0
    0;255;3;0;9;read: 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;node pinged by 1, hops=1
    0;255;3;0;9;send: 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,st=fail:1
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;send: 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;MSG:BC
    0;255;3;0;9;MSG:BC
    Any idea whats wrong here? is there a place, where I can read about the "new" output format/messages?
    EDIT: I don't even come the the setup() part of my sketch. the node is looping around with the log messages above.
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    T 1 Reply Last reply
    • dakkyD dakky
      Hello ;)
      TSM:INIT
      RADIO:OK
      assign node ID=1
      TSM:PARENT
      TSM:PARENT
      TSM:PARENT
      TSM:PARENT
      parent=0, d=1
      TSM:ID
      node ID=1
      pinging node 0
      TSM:PARENT
      TSM:PARENT
      TSM:PARENT
      TSM:PARENT
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      RADIO:OK
      assign node ID=1
      TSM:PARENT
      parent=0, d=1
      TSM:ID
      node ID=1
      pinging node 0
      TSM:PARENT
      TSM:PARENT
      parent=0, d=1
      TSM:ID
      node ID=1
      TSM:PARENT
      TSM:PARENT
      TSM:PARENT
      TSM:PARENT
      !TSM:FAILURE
      TSM:PDT
      IP: 192.168.100.10
      0;255;3;0;9;TSM:OK
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      0;255;3;0;9;MSG:BC
      T Offline
      T Offline
      tekka
      wrote on last edited by tekka
      @dakky How close are GW and node from each other? Also, can you make sure that you are using the latest dev version since many changes have been applied recently.
      • dakkyD Offline
        dakkyD Offline
        dakky
        @tekka
        Distance 10cm ;)
        BUt the second hint was useful. There seemed to be something "broken"/agile/in development yesterday which was fixed today. As far as I remember this was a fresh merge from development but nevertheless: now it is working again ;) thanks 4 the hint.
        Greetings
        Dakky
