  3. MySensor.h conflict with RF24.h?
7 Posts 2 Posters 2.8k Views 2 Watching
  • y4CdW42Ol8Y
    y4CdW42Ol8Y
    y4CdW42Ol8
    My goal is simply to Xmit the battery voltage and moisture sensor data from one Pro Mini (with RF24) to another Pro Mini (also with a RF24 radio), not using gw calls. My receiving Pro Mini will simply control a relay.
    I'm trying to combine two example sketches:
    • Plant_Moisture_Sensor_Low_Power
    • Arduino RF24XmitExample
    #include "RF24.h"
    However, I'm getting compile errors. There seems to be a conflict between the MySensor gw library calls and the RF24 library calls.
    The first of many compile errors I get are:
    C:\Users\Dieter\AppData\Local\Temp\build3316808d9e952884aa2dded546ad6403.tmp\libraries\RF24\RF24.cpp.o: In function `SPIClass::setBitOrder(unsigned char)':
    C:\Users\Dieter\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11\libraries\SPI\src/SPI.h:293: multiple definition of `RF24::csn(bool)'
    In the end, I get: Exit status 1
    Error compiling for board Arduino Pro or Pro Mini.
    Both examples individually compile OK.
    Any thoughts?
    Dieter
    • y4CdW42Ol8Y
      y4CdW42Ol8Y
      y4CdW42Ol8
      I forgot to mention I only use the gw libary to put the 3.3v Mini to sleep.
        Using both rf24 and MySensors will not work.
        If you only need sleep, the rocketscream lowpower library will probably be a better choice (except that it won't put the radio to sleep I think so you'll need to handle that separately.
        • y4CdW42Ol8Y
          y4CdW42Ol8Y
          y4CdW42Ol8
          When using the GW library, is there a way to communicate from one node to another, without having to go thru a controller?
          I have read some of the 1.5 API, but I cant really tell if this can be done.
          What about the LowPower.h library. Does it put the Radio to sleep?
          • y4CdW42Ol8Y
            y4CdW42Ol8Y
            y4CdW42Ol8
            What can i use to create an interrupt to wake a sleeping Arduino?
            This using your Plant_Moisture_Sensor sketch.
            • y4CdW42Ol8Y y4CdW42Ol8
              Yes. Use setDestination on the message, see https://www.mysensors.org/download/sensor_api_15#the-full-api
              To my knowledge, LowPower.h is the rocketscream lowpower library. So no, it does not.
                A timer (whick my sketch alreay uses) or a change in an interrupt pin, see the Sleeping section on https://www.mysensors.org/download/sensor_api_15#the-full-api and http://playground.arduino.cc/Code/Interrupts
