  3. Domoticz
  4. Last seen?
Last seen?
3 Posts 2 Posters 1.9k Views 2 Watching
  • kk02067K
    kk02067K
    kk02067
    I have a problem with a sensor that is not updating in the dashboard. In the hardware setup page for mysensors gateway v2.0 I see "last seen" update every 10 sec. But under device I can see the device but it doesn't update more then once. "Last seen" in device page doesn't update. So the temperature doesn't update in the dashboard. What am I doing wrong? I'm kind of new at this.
    The sketch looks like this:
    I2C_ReadAllData.ino
    BME280 Arduino and Teensy example
    Marshall Taylor @ SparkFun Electronics
    May 20, 2015
    https://github.com/sparkfun/SparkFun_BME280_Arduino_Library
    This sketch configures the BME280 to read all measurements. The sketch also
    displays the BME280's physical memory and what the driver perceives the
    calibration words to be.
    Resources:
    Uses Wire.h for I2C operation
    Uses SPI.h for SPI operation
    Development environment specifics:
    Arduino IDE 1.6.4
    Teensy loader 1.23
    This code is released under the MIT License.
    Please review the LICENSE.md file included with this example. If you have any questions
    or concerns with licensing, please contact techsupport@sparkfun.com.
    Distributed as-is; no warranty is given.
    #include <stdint.h>
    #include "SparkFunBME280.h"
    //Library allows either I2C or SPI, so include both.
    #include "Wire.h"
    #include "SPI.h"
    #define SKETCH_NAME "Environment Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define CHILD_ID_1 1
    #define CHILD_ID_2 2
    #define CHILD_ID_3 3
    //Global sensor object
    BME280 Sensor;
    MyMessage msg1(CHILD_ID_1, V_TEMP);
    MyMessage msg2(CHILD_ID_2, V_HUM);
    MyMessage msg3(CHILD_ID_3, V_PRESSURE);
    //Driver settings*****************************//
    //commInterface can be I2C_MODE or SPI_MODE
    //specify chipSelectPin using arduino pin names
    //specify I2C address. Can be 0x77(default) or 0x76
    //For I2C, enable the following and disable the SPI section
    Sensor.settings.commInterface = I2C_MODE;
    Sensor.settings.I2CAddress = 0x77;
    //For SPI enable the following and dissable the I2C section
    //Sensor.settings.commInterface = SPI_MODE;
    //Sensor.settings.chipSelectPin = 10;
    //***Operation settings*****************************//
    //renMode can be:
    //  0, Sleep mode
    //  1 or 2, Forced mode
    //  3, Normal mode
    Sensor.settings.runMode = 3; //Normal mode
    //tStandby can be:
    //  0, 0.5ms
    //  1, 62.5ms
    //  2, 125ms
    //  3, 250ms
    //  4, 500ms
    //  5, 1000ms
    //  6, 10ms
    //  7, 20ms
    Sensor.settings.tStandby = 5;
    //filter can be off or number of FIR coefficients to use:
    //  0, filter off
    //  1, coefficients = 2
    //  2, coefficients = 4
    //  3, coefficients = 8
    //  4, coefficients = 16
    Sensor.settings.filter = 0;
    //tempOverSample can be:
    //  0, skipped
    //  1 through 5, oversampling *1, *2, *4, *8, *16 respectively
    Sensor.settings.tempOverSample = 1;
    //pressOverSample can be:
    //  0, skipped
    Sensor.settings.pressOverSample = 1;
    //humidOverSample can be:
    //  0, skipped
    Sensor.settings.humidOverSample = 1;
    // Serial.begin(57600);
    Serial.print("Program Started\n");
    Serial.print("Starting BME280... result of .begin(): 0x");
    //Calling .begin() causes the settings to be loaded
    delay(10);  //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
    Serial.println(Sensor.begin(), HEX);
    Serial.print("Displaying ID, reset and ctrl regs\n");
    Serial.print("ID(0xD0): 0x");
    Serial.println(Sensor.readRegister(BME280_CHIP_ID_REG), HEX);
    Serial.print("Reset register(0xE0): 0x");
    Serial.println(Sensor.readRegister(BME280_RST_REG), HEX);
    Serial.print("ctrl_meas(0xF4): 0x");
    Serial.println(Sensor.readRegister(BME280_CTRL_MEAS_REG), HEX);
    Serial.print("ctrl_hum(0xF2): 0x");
    Serial.println(Sensor.readRegister(BME280_CTRL_HUMIDITY_REG), HEX);
    Serial.print("\n\n");
    Serial.print("Displaying all regs\n");
    uint8_t memCounter = 0x80;
    uint8_t tempReadData;
    for(int rowi = 8; rowi < 16; rowi++ )
    	Serial.print("0x");
    	Serial.print(rowi, HEX);
    	Serial.print("0:");
    	for(int coli = 0; coli < 16; coli++ )
    		tempReadData = Sensor.readRegister(memCounter);
    		Serial.print((tempReadData >> 4) & 0x0F, HEX);//Print first hex nibble
    		Serial.print(tempReadData & 0x0F, HEX);//Print second hex nibble
    		Serial.print(" ");
    		memCounter++;
    	Serial.print("\n");
    Serial.print("Displaying concatenated calibration words\n");
    Serial.print("dig_T1, uint16: ");
    Serial.println(Sensor.calibration.dig_T1);
    Serial.print("dig_T2, int16: ");
    Serial.println(Sensor.calibration.dig_T2);
    Serial.print("dig_T3, int16: ");
    Serial.println(Sensor.calibration.dig_T3);
    Serial.print("dig_P1, uint16: ");
    Serial.println(Sensor.calibration.dig_P1);
    Serial.print("dig_P2, int16: ");
    Serial.println(Sensor.calibration.dig_P2);
    Serial.print("dig_P3, int16: ");
    Serial.println(Sensor.calibration.dig_P3);
    Serial.print("dig_P4, int16: ");
    Serial.println(Sensor.calibration.dig_P4);
    Serial.print("dig_P5, int16: ");
    Serial.println(Sensor.calibration.dig_P5);
    Serial.print("dig_P6, int16: ");
    Serial.println(Sensor.calibration.dig_P6);
    Serial.print("dig_P7, int16: ");
    Serial.println(Sensor.calibration.dig_P7);
    Serial.print("dig_P8, int16: ");
    Serial.println(Sensor.calibration.dig_P8);
    Serial.print("dig_P9, int16: ");
    Serial.println(Sensor.calibration.dig_P9);
    Serial.print("dig_H1, uint8: ");
    Serial.println(Sensor.calibration.dig_H1);
    Serial.print("dig_H2, int16: ");
    Serial.println(Sensor.calibration.dig_H2);
    Serial.print("dig_H3, uint8: ");
    Serial.println(Sensor.calibration.dig_H3);
    Serial.print("dig_H4, int16: ");
    Serial.println(Sensor.calibration.dig_H4);
    Serial.print("dig_H5, int16: ");
    Serial.println(Sensor.calibration.dig_H5);
    Serial.print("dig_H6, uint8: ");
    Serial.println(Sensor.calibration.dig_H6);
    Serial.println();
    void presentation() {
    sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
    // Register binary input sensor to sensor_node (they will be created as child devices)
    present(CHILD_ID_1, S_TEMP);
    present(CHILD_ID_2, S_HUM);
    present(CHILD_ID_3, S_BARO);
    //Each loop, take a reading.
    //Start with temperature, as that data is needed for accurate compensation.
    //Reading the temperature updates the compensators of the other functions
    //in the background.
    /* Serial.print("Temperature: ");
    Serial.print(Sensor.readTempC(), 2);
    Serial.println(" degrees C");
    Serial.print(Sensor.readTempF(), 2);
    Serial.println(" degrees F");
    Serial.print("Pressure: ");
    Serial.print(Sensor.readFloatPressure(), 2);
    Serial.println(" Pa");
    Serial.print("Altitude: ");
    Serial.print(Sensor.readFloatAltitudeMeters(), 2);
    Serial.println("m");
    Serial.print(Sensor.readFloatAltitudeFeet(), 2);
    Serial.println("ft");
    Serial.print("%RH: ");
    Serial.print(Sensor.readFloatHumidity(), 2);
    Serial.println(" %");
    Serial.println();
    delay(1000);
        int  temperature;
        int  humidity;
        long  pressure;
        temperature=Sensor.readTempC();
        humidity=Sensor.readFloatHumidity();
        pressure=Sensor.readFloatPressure();
     send(msg1.set(temperature));
     send(msg2.set(humidity));
     send(msg3.set(pressure));
     sleep(10000);
    AWIA 1 Reply Last reply
    • kk02067K kk02067
      I2C_ReadAllData.ino
      May 20, 2015
      Resources:
      Arduino IDE 1.6.4
      Teensy loader 1.23
      #include <stdint.h>
      #include "Wire.h"
      #include "SPI.h"
      BME280 Sensor;
      //renMode can be:
      //  0, Sleep mode
      //  3, Normal mode
      //tStandby can be:
      //  0, 0.5ms
      //  1, 62.5ms
      //  2, 125ms
      //  3, 250ms
      //  4, 500ms
      //  5, 1000ms
      //  6, 10ms
      //  7, 20ms
      //  0, filter off
      //  0, skipped
      //  0, skipped
      //  0, skipped
      	Serial.print("0x");
      	Serial.print("0:");
      		Serial.print(" ");
      		memCounter++;
      	Serial.print("\n");
      Serial.println();
      Serial.println();
      delay(1000);
          int  temperature;
          int  humidity;
          long  pressure;
       sleep(10000);
      AWIA
      AWIA
      AWI
      @kk02067 please enclose the sketch in a "code block" to allow easy reading... you can also put 3 tick marks (back quote ` ) on both sides of the code
      0_1468736519864_upload-98eef9b5-32b9-4f23-a150-d75f0529bf58
      What does you debug on the serial output of the node tell you? (also enclose in code block ;-))
      kk02067K 1 Reply Last reply
      • AWIA AWI
        kk02067K
        kk02067K
        kk02067
        @AWI
        Thanks for your reply and tips to a beginner.
        I experimented with a couple of things in the sketch and after a little digging I seem to have got it working.
        The problem seem to be that if the values sent to the gateway is not in the correct format it wont work. If I send just one value in integer it works. But if I send alla three values as integer it stops working. If I send all three as "double" with two decimals it works as it should.
        The sketch when it functions as it should:
        I2C_ReadAllData.ino
        May 20, 2015
        Resources:
        Arduino IDE 1.6.4
        Teensy loader 1.23
        This code is released under the [MIT License](http://opensource.org/licenses/MIT).
        #include <stdint.h>
        #include "Wire.h"
        #include "SPI.h"
        BME280 Sensor;
        	//***Driver settings********************************//
        	//renMode can be:
        	//  0, Sleep mode
        	//  3, Normal mode
        	//tStandby can be:
        	//  0, 0.5ms
        	//  1, 62.5ms
        	//  2, 125ms
        	//  3, 250ms
        	//  4, 500ms
        	//  5, 1000ms
        	//  6, 10ms
        	//  7, 20ms
        	//  0, filter off
        	//  0, skipped
        	//  0, skipped
        	//  0, skipped
        		Serial.print("0x");
        		Serial.print("0:");
        			Serial.print(" ");
        			memCounter++;
        		Serial.print("\n");
        	Serial.println();
        	Serial.println();
        	delay(1000);
                double  temperature;
                double  humidity;
                double  pressure;
                pressure=Sensor.readFloatPressure()/100;
               send(msg1.set(temperature,2));
               send(msg2.set(humidity,2));
               Serial.print(humidity, 2);
               send(msg3.set(pressure,2));
             sleep(10000);
