  3. What is wrong with this sketch?
20 Posts 4 Posters 4.9k Views 4 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    Why does not the motion-sensor trigger in this sketch?
    #define MY_DEBUG    // Enables debug messages in the serial log
    #define MY_RADIO_RFM69
    #define MY_REPEATER_FEATURE  // Enables repeater functionality for a radio node
    #define PRESSURE_ID 1
    #define MOTION_ID 2   // Id of the sensor child
    int FSR_Pin = A0; //analog pin 0
    int value = 0;
    int oldvalue = 0;
    int OPEN = 0;
    int CLOSE = 1;
    boolean lastTripped = 0;
    MyMessage msgPressure(PRESSURE_ID, V_TRIPPED);
    MyMessage msgMotion(MOTION_ID, V_TRIPPED);
     sendSketchInfo("Pressure/Motion Sensor", "1.0");
      present(PRESSURE_ID, S_DOOR);
      present(MOTION_ID, S_MOTION);
    int FSRReading = analogRead(FSR_Pin);
    if(FSRReading > 150)
        value=CLOSE;
    else
        value=OPEN;
    // Read digital motion value
       if(lastTripped != tripped && value!= oldvalue)
          send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
          lastTripped=tripped;
          send(msgPressure.set(value?"1":"0"));
          oldvalue = value;
          sleep(1000);
       else if (lastTripped != tripped)
          //Serial.println(tripped);
            sleep(1000);
       else if(value!= oldvalue)
           oldvalue = value;
           sleep(1000);
        else
            sleep(1000);
    • nielsokkerN Offline
      nielsokkerN Offline
      nielsokker
      I am trying to debug it. I will let you know in a second.
        nielsokkerN Offline
        nielsokker
        #define FSR_Pin = A0; //analog pin 0
        int value = 0; // change this to a signed  or unsigned thingy
        int oldvalue = 0; // change this to a signed  or unsigned thingy
        #define OPEN 0
        #define CLOSE 1
          pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as inputa
          if (FSRReading > 150)
            value = CLOSE;
          else
            value = OPEN;
          boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR);
          if (lastTripped != tripped) // if only the tripped has changed
            send(msgMotion.set(tripped ? "1" : "0")); // Send tripped value to gw
            lastTripped = tripped;
          if (value != oldvalue)
            send(msgPressure.set(value ? "1" : "0"));
            oldvalue = value;
          wait(SLEEP_TIME);
        I changed the loop part. I had a lot of double code which did not do anything. I changed some ints to defines because they did not change ever. I changed sleep to wait since it is a repeater (they cannot sleep). Also. After every round you want to sleep, so why not just write it once instead of in every if statement.
        I hope this helps you.
        nielsokkerN 1 Reply Last reply
        • nielsokkerN nielsokker
          #define OPEN 0
          #define CLOSE 1
              value = CLOSE;
            else
              value = OPEN;
              oldvalue = value;
            wait(SLEEP_TIME);
          nielsokkerN Offline
          nielsokkerN Offline
          nielsokker
          @nielsokker
          I see it does not compile. You have to change the define.
          #define FSR_Pin = A0; //analog pin 0 needs to be
          needs to be
          #define FSR_Pin  A0 //analog pin 0 needs to be
          corbinC 1 Reply Last reply
            @nielsokker
            needs to be
            corbinC Offline
            corbinC Offline
            corbin
            @nielsokker
            That wait at the end of the loop won't wake up on interrupt, for the motion sensor.
            @Cliff-Karlsson
            Is this node intended to be a repeater as well?
              Cliff Karlsson
              @corbin said:
              Yes it will be permanently powered so I figured I could use it for a repeater as well.
              As it won't run on batteries I don't need sleep (?) I just want it to update on pressure (when it goes from 1 to 0 or from 0 to 1) and when detecting movement and not spamming my controller as the original sketch that I made did.
                corbinC Offline
                corbinC Offline
                corbin
                @Cliff-Karlsson
                This is the sketch I'm using for a repeater and motion node. If you are using a HC-SR501 PIR with high and low triggers it should work ok without spamming your gateway.
                Note that there are no sleeps or waits, it will just keep running the loop. I don't know if that is ideal - definitely no good for batteries.
                 * Version 1.0 - Henrik Ekblad
                 * Example sketch showing how to create a node thay repeates messages
                 * from nodes far from gateway back to gateway.
                 * It is important that nodes that has enabled repeater mode calls
                 * process() frequently. Repeaters should never sleep.
                // Enabled repeater feature for this node
                boolean previousTripped = LOW;
                // Initialize motion message
                  //Send the sensor node sketch version information to the gateway
                  sendSketchInfo("Motion and Repeater Node", "1.0");
                  present(CHILD_ID, S_MOTION);
                  // Sensor must be HIGH and not yet sent the status of the sensor
                  if ((tripped == HIGH) && (tripped != previousTripped) ) {
                    send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
                    previousTripped = tripped;
                  // Is sensor low and not sent? Then send LOW to gateway
                  if ((tripped == LOW) && (tripped != previousTripped)) {
                  Cliff Karlsson
                  This is my last attempt and I think it works pretty well, but the gateway still get spammed. When I trigger the motion-sensor the domotizc log looks like this:
                  2016-07-19 11:38:53.250 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:54.354 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:54.411 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:55.515 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:55.574 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:56.678 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:56.736 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:57.842 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:57.899 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:59.003 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:38:59.061 (RFM) Lighting 2 (Säng Motion)
                  2016-07-19 11:39:00.166 (RFM) Lighting 2 (Säng Motion)
                  int value = 0;
                  int oldvalue = 0;
                  int OPEN = 0;
                  int CLOSE = 1;
                      value=CLOSE;
                  else
                      value=OPEN;
                    else if ((tripped == LOW) && (tripped != previousTripped)) {
                         oldvalue = value;
                     else{
                          sleep(1000);
                  A 1 Reply Last reply
                    int value = 0;
                    int oldvalue = 0;
                    int OPEN = 0;
                    int CLOSE = 1;
                        value=CLOSE;
                    else
                        value=OPEN;
                           oldvalue = value;
                       else{
                            sleep(1000);
                    A Offline
                    A Offline
                    AWI
                    wrote on last edited by AWI
                    @Cliff-Karlsson A few things:
                    1. You are mixing all kinds of variable types which makes it rather confusing. a boolean can only have a "true" or "false" value (not HIGH/LOW or OPEN/CLOSE ).
                    2. The pressure sensor "value" is fact a boolean. I would be easier to read if you make it a boolean and name it "pressureHigh" or so.
                    3. The operator <test>?<if true>: <if false> takes a boolean as first argument.
                    4. There are two independent sensors (motion and "pressure") in your node. so you should treat them as such. so something like this instead of stacking "else if"
                    if (<sensor 1>)    // sensor 1 actions
                    else (<sensor 1>)
                    if (<sensor 2>)    // sensor 2 actions
                    else (<sensor 2>)
                    sleep(  <interrupt>, <time>) ;
                    the spamming of the gateway is probably caused by somethin else ;-)
                      Cliff Karlsson
                      Ok, I am going to try to make some use of that info. But can I still use "sleep( <interrupt>, <time>) ;" when I also need to monitor the A0 (Pressure)? Will the Pressure still trigger when the sensor sleeps and there are no motion?
                      corbinC A 2 Replies Last reply
                        corbinC Offline
                        corbinC Offline
                        corbin
                        @Cliff-Karlsson
                        You cannot use sleep of any kind, because it will power down the radio, and you need that running 100% of the time for the repeater function.
                          A Offline
                          A Offline
                          AWI
                          @Cliff-Karlsson It depends what kind of pressure sensor you have, i will probably be enough if you poll it each second or so. And as @corbin mentioned don't use repeater function when you sleep.
                          Cliff KarlssonC 1 Reply Last reply
                          • A AWI
                            Cliff Karlsson
                            Ok, I know this is probably very basic. But exactly how would I modify the original sketch to have it behave like this?
                              nielsokkerN Offline
                              nielsokkerN Offline
                              nielsokker
                              @Cliff-Karlsson
                              I dont really understand what you mean. You want it to send its value every second? In that case my attempt still works. You want to use interrupts?
                                Cliff Karlsson
                                I just want a sketch that updates the status of the pressure sensor when it goes from HIGH to LOW or from LOW to HIGH. And when Movement is detected, but does only report back to the controller when a actual change has happened.
                                In my last sketch all seemed to work except it "spammed" the controller with the motion-sensor:
                                  nielsokkerN Offline
                                  nielsokkerN Offline
                                  nielsokker
                                  @Cliff-Karlsson
                                  I see why. But once again, i think i made your sketch work.
                                  As i see it. This is the current desired logic.
                                  once per second, you want to check the following things:
                                  • is there motion?
                                  • has there been a change in pressure (HIGH to LOW or LOW to HIGH)?
                                  But actually you want to check both ALWAYS. The thing you are obviously looking for, are interrupts. I do not know how these work if you do not want to sleep. Maybe there is a wait(interrupt_pin_1_functor, interrupt_pin_2_functor, waittime=forever) function (I know the sleep() version exists).
                                  Maybe you already know what interrupts are but, in short: When a given interrupt pin notices a difference in value (HIGH to LOW, for example) it gives a signal. The current code is being stopped and the function that is bound to the pin is executed. This function could be sending the new value to the gateway.
                                  Can someone confirm this?
                                    Cliff Karlsson
                                    I tried again with your sketch @nielsokker , I think I only added some sleep. But the motion-sensor just turns on/off super-quick every time the motion triggers. What am I doing wrong ?
                                    A nielsokkerN 2 Replies Last reply
                                      A Offline
                                      A Offline
                                      AWI
                                      @Cliff-Karlsson how is your motion sensor powered? It needs a solid power supply
                                        nielsokkerN Offline
                                        nielsokkerN Offline
                                        nielsokker
                                        wrote on last edited by nielsokker
                                        Yea, my example just checks both sensors every second. So it sends both values every second. I know now that is not what you want. At least the code looks better in my opinion (ofc its my code :) ).
                                        I have to agree with @AWI that it seems like your sensor does not work properly.
                                          Cliff Karlsson
                                          ahh!!!, you where right. I powered the node using a mobile charger but had not connected the PIR to the same GND as the charger. Now it works.
