  3. Can't get sensors talking
24 Posts 7 Posters 10.8k Views 6 Watching
  • linus72982L
    linus72982L
    linus72982
    wrote on last edited by linus72982
    I keep having a few problems that I can't figure out. I think they are related, but I'm not entirely sure. I have the Nano Compatible as my serial gateway connected to the NRF24L01+PA+LNA Antenna version radio with a 4.7uf cap (ground connected to the white strip side) using the 2.0 GatewaySerial example (unchanged). I have it shielded the radio with the "ugly fix", the tin foil attached to ground. I checked the pins for continuity, nothing is touching the ground. On the sensor side, I have a pro mini 3.3v connected via the ftdi adapter to another usb port. The radio is the NRF24L01+ 2.4GHz Wireless Transceiver with a 47uf cap (yes, 47 for this and 4.7 for the other, I found references to use both in different places, of course, if my electronics classes serve me, it doesn't matter if I go bigger, it should still work, right?) Connected is a magnetic open/close sensor. This guy is running the 2.0 BinarySwitchSleepSensor (unchanged).
    What I've tried: Replacing the pro mini with another, replacing the pro mini's radio (twice), replacing all cables (dupont cables), replacing caps, moving the node further away from the gateway (to the adjacent room).
    I don't have a controller, so I've hard-coded (I think) the node ID and parent id with #define MY_NODE_ID 1 and #define MY_PARENT_NODE_ID 0 for the gateway, then the same with node # 3 and parent #1 for the node. The goal is to write my own controller but I need to get these working first.
    So, when I start the two monitors up within a few seconds of each other (gateway first), here's the output of the gateway:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=3)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
    0;255;3;0;9;!TSP:SANCHK:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    Here was the output of the pro mini over the same time:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=3)
    TSM:FPAR
    TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    To my untrained eye, it looks like the gateway sees the node as it says FPAR req'd sender=3, but then it looks like the fpar fails? I don't even know what FPAR is and I can't find anything on the site that allows me to decode these messages, only the 0;255;3;0;9 which is logging.
    Can anyone see what I'm doing incorrectly?
    • linus72982L
      linus72982L
      linus72982
      Also, after running for a bit, I get this from the gateway:
      0;255;3;0;9;TSM:PDT
      0;255;3;0;9;TSM:PDT
      0;255;3;0;9;TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
      0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
      0;255;3;0;9;TSP:MSG:PINGED (ID=3, hops=1)
      0;255;3;0;9;TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
      0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      0;255;3;0;9;!TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
      0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
      3;255;0;0;17;2.0.0
      0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
      3;255;3;0;6;0
      0;255;3;0;9;TSP:MSG:READ 3-3-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Binary Sensor
      3;255;3;0;11;Binary Sensor
      0;255;3;0;9;TSM:PDT
      0;255;3;0;9;TSP:SANCHK:OK
      and this from the pro mini:
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
      TSP:MSG:PAR OK (ID=0, dist=1)
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=3)
      TSM:UPL
      TSP:PING:SEND (dest=0)
      TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
      TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
      TSP:MSG:PONG RECV (hops=1)
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
      TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
      TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
      !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=fail:Binary Sensor
      !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
      !TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,ft=2,st=fail:
      !TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=0,pt=0,l=0,sg=0,ft=3,st=fail:
      Request registration...
      !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=fail:2
      !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
      !TSM:UPL FAIL, SNP
      TSM:FPAR
      !TSP:SEND:TNR
      TSM:FPAR
      !TSP:SEND:TNR
      TSM:FPAR
      Init complete, id=3, parent=255, distance=255, registration=1
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      !TSP:SEND:TNR
      the !TSP:SEND:TNR messages at the end happen each time I open or close the sensor.
      tekkaT 1 Reply Last reply
      • linus72982L linus72982
        0;255;3;0;9;TSM:PDT
        0;255;3;0;9;TSM:PDT
        3;255;0;0;17;2.0.0
        3;255;3;0;6;0
        0;255;3;0;9;TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=3)
        TSM:UPL
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        !TSM:UPL FAIL, SNP
        TSM:FPAR
        !TSP:SEND:TNR
        TSM:FPAR
        !TSP:SEND:TNR
        TSM:FPAR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @linus72982 looks like you have an issue with your GW radio:
        GW and repeater nodes have by default regular sanity checks enabled. In your case, the sanity check fails, most likely due to cable and/or power issues. Try fixing/reseating the radio cables and/or add a larger cap to the GW radio.
        Also, please post the node sketch for further analysis.
        As for the debug messages, here the most important ones:
        TSM:FPAR => Transport State Machine:Find PARent
        !TSM:UPL FAIL, SNP => Uplink failed, Search New Parent
        !TSP:SEND:TNR => Transport:SEND:Transport Not Ready
        TSM:PDT => PowerDown Transport
        I'm currently working on a PR to unify and document all transport debug log messages for troubleshooting
        In your case, this is what happened:
        1. Node initializes and assigns ID 3, then it fails to find a parent...
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        1. Later on it receives a response to the find parent request from node ID 0 (=GW)
        TSM:FPAR:OK
        1. and finally, the TSM is fully operational.
        TSM:READY
        1. Then the node starts sending the presentation messages...
        1. ...and fails again to (successfully) send the messages to the GW
        1. Hence, start searching for a new parent...
        !TSM:UPL FAIL, SNP
        TSM:FPAR
        1. ...and (again) no reply from the GW, therefore...
        !TSP:SEND:TNR
        1. Transport not ready, and starting from the beginning...
        linus72982L alexsh1A 2 Replies Last reply
        • sundberg84S
          @tekka - i get this:
          TSM:FPAR
          TSP:MSG:SEND 12-12-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSP:MSG:READ 0-0-12 s=255,c=3,t=8,pt=1,l=1,sg=0:0
          TSP:MSG:READ 101-101-12 s=255,c=3,t=8,pt=1,l=1,sg=0:1
          TSP:MSG:FPAR RES (ID=101, dist=1)
          TSP:MSG:READ 99-99-12 s=255,c=3,t=8,pt=1,l=1,sg=0:1
          TSP:MSG:FPAR RES (ID=99, dist=1)
          TSP:MSG:READ 100-100-12 s=255,c=3,t=8,pt=1,l=1,sg=0:1
          TSP:MSG:FPAR RES (ID=100, dist=1)
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=12)
          TSM:UPL
          TSP:MSG:SEND 12-12-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
          TSP:CHKUPL:FAIL (hops=255)
          !TSM:UPL:FAIL
          in an endless repeat.
          What does it mean?
          This is the same code as before - cleared eeprom and uploaded to a working node, only change is 2.0 lib.
          My guess is that I need to update the repeater/gw as well? They are running 2.0 beta.
          YveauxY tekkaT 2 Replies Last reply
          • sundberg84S sundberg84
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            What does it mean?
            YveauxY
            YveauxY
            Start with that indeed.
            2.0.0 sensors require repeaters and gateway to also run 2.0.0
            • YveauxY Yveaux
              @Yveaux will do but I would like to know what that error message is if possible.
              YveauxY 1 Reply Last reply
                YveauxY
                YveauxY
                @sundberg84 you will when @tekka finishes his documentation .
                Give him a break; I rather have him documenting the new stuff than answering all those individual questions :smirk:
                • YveauxY Yveaux
                  @Yveaux - I have missed this info about document. I will revert everything back then until proper documentation is finished.
                  Its hen and a egg problem... if documentation was finished before release all the questions could be avoided.
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    What does it mean?
                    tekkaT
                    tekkaT
                    tekka
                    @sundberg84 We do not recommend nor have the bandwidth to support and troubleshoot setups with mixed MySensors versions (i.e. 1.x and 2.x). That said, mixed setups can but are not guaranteed to function. As semantic versioning suggests, a major version increment implies API changes that are not backwards compatible: For a full list of changes in 2.0.0, please refer to the change log.
                    In your case, update all nodes/GW/repeaters to the most recent MySensors version, and report back if you encounter any issues.
                    As @Yveaux pointed out, I am working on a PR that unifies and documents all debug messages emitted from the transport layer.
                    • tekkaT tekka
                      @tekka - ok, thanks @tekka. I have 25+ nodes so I guess I have some work then
                      .. or maybe I'll just stick to 2.0b.
                        tekkaT
                        tekkaT
                        tekka
                        @sundberg84 Wow, how is the topology?
                        • sundberg84S
                          @tekka -
                          GW - 2.0b
                          3x Repeaters (combined with motion) - 2.0b
                          Nodes about 50% 1.4-1.5 and 50% 2.0b
                          but nevermind, I will hold on to your document is finished - no worries. I was just to eager to upgrade :)
                          Then I will try to upgrade the gw and see what happens.
                          • tekkaT tekka
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:FPAR:OK
                            TSM:READY
                            !TSM:UPL FAIL, SNP
                            TSM:FPAR
                            !TSP:SEND:TNR
                            linus72982L
                            linus72982L
                            linus72982
                            @tekka
                            Thanks for the explanation of the messages, that helped me quite a bit. I figured out that my gateway radio wasn't working very well so I bought an Addicore version that the reviews said was a bit more reliable. It came in today and works like a champ (and it has labeled pins which is helpful).
                            I eagerly await the documentation of the messages. I am writing a controller in Python and with my limited C knowledge (weird, I know, as Python is a C-based language, but it's just different enough to drive me nuts), I'm going cross-eyed trying to reverse-engineer the messages from the code. Your documentation will help immensely. Just the bit you told me up there has allowed me to write most of it. Thanks, again.
                              @tekka
                              tekkaT
                              tekkaT
                              tekka
                              @linus72982 You'll find some more information here. This is a PR (still WIP) for the dev branch and applies to the upcoming 2.0.1 release.
                              linus72982L 1 Reply Last reply
                              • tekkaT tekka
                                linus72982L
                                linus72982L
                                linus72982
                                @tekka
                                That's good info, thank you. Quick question if you have a minute, what is the difference between CHKUPL and SANCHK? Based on the docs, they both seem to accomplish the same goal.
                                  @tekka
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @linus72982 No, they do different things: CHKUPL checks the uplink, i.e. connection to GW whereas SANCHK is the regular radio HW sanity check (radio register verification + SPI connection).
                                  • tekkaT tekka
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:FPAR:OK
                                    TSM:READY
                                    !TSM:UPL FAIL, SNP
                                    TSM:FPAR
                                    !TSP:SEND:TNR
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tekka Can we please get your info about deciphering the log in v.2 into a separate sticky thread in the Troubleshooting section?
                                    Thank you very much for producing it
                                    • alexsh1A alexsh1
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @alexsh1 The debug log messages are fully documented in the upcoming 2.0.1 release, see here for a preview (dev): https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/
                                      • tekkaT tekka
                                        YveauxY
                                        YveauxY
                                        @alexsh1 more explicitly, a description of the transport state machine messages (TSM) can be found here: https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/
                                        • YveauxY Yveaux
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Yveaux @alexsh1 https://ci.mysensors.org/job/Verifiers/job/MySensorsArduinoLibPR/Doxygen_HTML/group__MyTransportgrp.html
