  3. Garden light, humidity, temperature monitor with working SHT10 sensor 99% done and I need your help!
4 Posts 3 Posters 2.5k Views 4 Watching
  • A
    A
    ajachierno
    Hi everyone I am working on my latest project a garden soil humidity/temperature monitor and light sensor. The problem is I am stuck. I got the SHT10 sensor working flawlessly to report the soil humidity and temperature but the light sensor seems to report once when powered up then never again. Also it always seems to be the same value regardless of light conditions (54612 ). I am thinking my sketch is wrong as I am not the best programmer can some one check it for me please and tell me where i went wrong. Also photos of the project attached. at the bottom
    #include "SHT1x.h"
    #include <BH1750.h>
    #include <Wire.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define dataPin 6
    #define sckPin 7 //serial clock
    unsigned long SLEEP_TIME = 30000;
    SHT1x th_sensor(dataPin, sckPin);
    float lastTemp;
    float lastHum;
    BH1750 lightSensor;
    boolean metric = true;
    uint16_t lastlux;
    gw.begin();
    gw.sendSketchInfo("Humidity", "1.0");
    gw.sendSketchInfo("Light Lux Sensor", "1.0");
    gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
    lightSensor.begin();
    float temperature = th_sensor.readTemperatureF();
    if (isnan(temperature)) {
    Serial.println("Failed reading temperature");
    lastTemp = temperature;
    if (!metric) {
    temperature = th_sensor.readTemperatureC();
    Serial.print("T: ");
    Serial.println(temperature);
    float humidity = th_sensor.readHumidity();
    if (isnan(humidity)) {
    Serial.println("Failed reading humidity");
    lastHum = humidity;
    Serial.print("H: ");
    Serial.println(humidity);
    uint16_t lux = lightSensor.readLightLevel();// Get Lux value
    Serial.println(lux);
    if (lux != lastlux) {
    gw.send(msg.set(lux));
    lastlux = lux;
    gw.sleep(SLEEP_TIME); //sleep a bit
    [URL=http://s1074.photobucket.com/user/ajachierno/media/20160719_1810421_zpsg1gccgpd.jpg.html][IMG]http://i1074.photobucket.com/albums/w405/ajachierno/20160719_1810421_zpsg1gccgpd.jpg[/IMG][/URL]
    [URL=http://s1074.photobucket.com/user/ajachierno/media/20160719_1810321_zpsa9tm5mp4.jpg.html][IMG]http://i1074.photobucket.com/albums/w405/ajachierno/20160719_1810321_zpsa9tm5mp4.jpg[/IMG][/URL]
    [URL=http://s1074.photobucket.com/user/ajachierno/media/20160719_1659381_zpsmaqne2x9.jpg.html][IMG]http://i1074.photobucket.com/albums/w405/ajachierno/20160719_1659381_zpsmaqne2x9.jpg[/IMG][/URL]
    [URL=http://s1074.photobucket.com/user/ajachierno/media/20160719_1657091_zpscjtpxuiu.jpg.html][IMG]http://i1074.photobucket.com/albums/w405/ajachierno/20160719_1657091_zpscjtpxuiu.jpg[/IMG][/URL]
    corbinC 1 Reply Last reply
    • A ajachierno
      #include "SHT1x.h"
      #include <BH1750.h>
      #include <Wire.h>
      #define dataPin 6
      float lastTemp;
      float lastHum;
      BH1750 lightSensor;
      uint16_t lastlux;
      gw.begin();
      if (!metric) {
      lastHum = humidity;
      lastlux = lux;
      corbinC
      corbinC
      corbin
      Your sketch looks correct to me, but if the lux sensor is always reporting the same value, then it will only send the message once as you have seen. Are you sure the lux sensor is wired correctly?
      A 1 Reply Last reply
      • Nca78N
        Nca78N
        wrote on last edited by Nca78
        first please use the code tags around your code it's easier to read, it's with the </> button at the right of the toolbar when you type your message.
        The code seems ok to me too, this value means there is a i2c communication problem with the sensor. So either your sensor is dead, or it is not correctly wired.
        What I would do :
        1. try the example from the BH1750 library to concentrate on the sensor readings and avoid any problem that could be related to MySensors. Just make the test with arduino + BH1750 sensor and nothing else.
        2. check (and double check :)) your wiring to the SDA / SCL pins
        3. if you still can't read a value connect the ADDR pin of the BH1750 board to GND and try again
        4. if you still can't read a value, now you are sure your sensor is correctly connected, try i2c scanner sketch, it will tell you if it finds any i2c devices on the i2c bus. If it fails to see your sensor then you can assume it's dead...
        http://playground.arduino.cc/Main/I2cScanner
        • corbinC corbin
          A
          A
          ajachierno
          Thank you Corbin and NCA78, I had assumed it was my code since I am not very good at it. However it turned out to be a bad sensor. I will post some additional information and pictures in the project section this evening now that everything is working. Thank you again for your help.
