  3. Repeaters and Fixed Parents on sensors... [SOLVED]
7 Posts 4 Posters 2.5k Views 4 Watching
  • L Offline
    L Offline
    leeoz
    Just for sharing.
    I tried to add repeaters to my network but the sensor didn't communicate with the repeaters and only tried to send to Gateway.
    I realized that Iv'e fixed parent ID on each sensor because I have a problem with find parent on my sensors (this is why i ended up adding repeaters). So Iv'e changed it back to finding parent mode and the repeater is now communicating with sensors!
    FYI
    T 1 Reply Last reply
    • L leeoz
      Just for sharing.
      FYI
      T Offline
      T Offline
      tekka
      @leeoz Just out of curiosity: could you share the debug logs of both scenarios (from GW, repeater, and node). Thanks
      • L Offline
        L Offline
        leeoz
        I have no idea how to do that :confused:
        • mk55M Offline
          mk55M Offline
          mk55
          I have the same problem...How did you change it back to finding parent?
          I'm using version 2.0, and I'm only using fixed ID's on the nodes
          L 1 Reply Last reply
          • mk55M mk55
            L Offline
            L Offline
            leeoz
            @mk55.
            Hi.
            I just upgraded to 2.0 last night.
            So i have no idea yet. And i need to make changes to all of my sensors code now.
            Please let me know if u find the answer before me.
            mk55M 1 Reply Last reply
            • N Offline
              N Offline
              Nuubi
              In some cases it is also useful to force the NodeId of the repeater to be the parent (obvious, still took some time to understand it)
              • L leeoz
                @mk55.
                Hi.
                mk55M Offline
                mk55M Offline
                mk55
                Well, turns out it does work. I wasn't far enough apparently
