  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.3k Views 5 Watching
  • Pictor LallemandP
    Pictor LallemandP
    Pictor Lallemand
    @tekka my debug output
    C:\Users\victor\Documents\Arduino\sketch_aug14c\sketch_aug14c.ino
    2.0.0
    1703
    5001
    164
    16000000
    tekkaT 1 Reply Last reply
    • Pictor LallemandP Pictor Lallemand
      2.0.0
      1703
      5001
      164
      16000000
      tekkaT
      tekkaT
      tekka
      @Pictor-Lallemand and from your GW?
      • Pictor LallemandP
        Pictor LallemandP
        Pictor Lallemand
        @tekka
        debug gw
        C:\Users\victor\Documents\Arduino\sketch_aug14b\sketch_aug14b.ino
        2.0.0
        1703
        4728
        175
        16000000
          @tekka
          debug gw
          2.0.0
          1703
          4728
          175
          16000000
          tekkaT
          tekkaT
          tekka
          @Pictor-Lallemand Ok output looks good, GW is running at a slightly higher frequency - but this can also be an artefact. I assume your radios run at 3V3?
          Let's try these things:
          1. increase the RF24 data rate to 1MBPS using
          #define MY_RF24_DATARATE RF24_1MBPS
          1. If (1) doesn't improve the radio transmissions, change the RF24 channel using
          #define MY_RF24_CHANNEL 37
          • Pictor LallemandP
            Pictor LallemandP
            Pictor Lallemand
            @tekka I already used the command 1Mbit
            • Pictor LallemandP
              Pictor LallemandP
              Pictor Lallemand
              after having followed your two board this is what I get the node code
              debug
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=101)
              TSM:FPAR
              TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSP:MSG:READ 0-0-255 s=255,c=3,t=20,pt=0,l=1,sg=0:0
              TSP:MSG:BC
              TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
              TSP:MSG:PAR OK (ID=0, dist=1)
              TSM:FPAR:OK
              TSM:ID
              TSM:CHKID:OK (ID=101)
              TSM:UPL
              TSP:PING:SEND (dest=0)
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=1,st=fail:0
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=2,st=fail:0
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=3,st=fail:0
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=4,st=fail:0
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=5,st=fail:0
              TSP:CHKUPL:FAIL (hops=255)
              !TSM:UPL:FAIL
              TSM:FPAR
              TSP:MSG:BC
              TSP:MSG:BC
              TSP:MSG:BC
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSP:MSG:BC
              TSP:MSG:BC
              !TSP:FPAR:ACTIVE (msg not send)
              TSP:MSG:BC
              TSP:MSG:READ 0-0-255 s=255,c=3,t=255,pt=0,l=3,sg=0:255
              TSP:MSG:BC
              TSP:MSG:BC
              TSP:MSG:BC
              TSM:FPAR:OK
              TSM:ID
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=fail:0
              TSP:MSG:BC
              TSP:MSG:BC
              TSP:MSG:BC
              TSP:MSG:BC
              TSM:UPL
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=fail:1
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=6,st=fail:0
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=7,st=fail:0
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=8,st=fail:0
              TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
              TSP:MSG:PONG RECV (hops=1)
              TSP:MSG:BC
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=9,st=fail:0
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=10,st=fail:0100
              !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=11,st=fail:2.0.0
              !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=12,st=fail:0
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              Request registration...
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              Init complete, id=101, parent=255, distance=255, registration=1
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              the code of node
              #define MY_NODE_ID 101
              MyMessage msgGeneral(0, V_VAR1);
              uint32_t counter = 0, lastSend = 0;
              uint8_t rebootCounter = 5;
              void presentation() {
                sendSketchInfo("TestNode", "1.0");
                present(0, S_ARDUINO_NODE, "Counter");
                 if (millis() - lastSend > 500) {
                    msgGeneral.setDestination(GATEWAY_ADDRESS);
                    send(msgGeneral.set(counter), true);
                    counter = 0;
                    lastSend = millis();
                    if(!rebootCounter--) {
                      hwReboot();
                 counter++;
              the gateway code
               * The ArduinoGateway prints data received from sensors on the serial link.
               * The gateway accepts input on seral which will be sent out on radio network.
               * The GW code is designed for Arduino Nano 328p / 16MHz
               * Wire connections (OPTIONAL):
               * - Inclusion button should be connected between digital pin 3 and GND
               * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
               * LEDs (OPTIONAL):
               * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
              // Enable serial gateway
              #define MY_GATEWAY_SERIAL
              // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
              #if F_CPU == 8000000L
              #define MY_BAUD_RATE 38400
              // Flash leds on rx/tx/err
              #define MY_LEDS_BLINKING_FEATURE
              // Set blinking period
              // Enable inclusion mode
              the debug gateway
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSM:RADIO:OK
              0;255;3;0;9;TSM:GW MODE
              0;255;3;0;9;TSM:READY
              0;255;0;0;18;2.0.0
              0;255;3;0;9;TSP:MSG:READ 101-101-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
              0;255;3;0;9;TSP:MSG:BC
              0;255;3;0;9;TSP:MSG:FPAR REQ (sender=101)
              0;255;3;0;9;TSP:CHKUPL:OK
              0;255;3;0;9;TSP:MSG:GWL OK
              0;255;3;0;9;!TSP:MSG:SEND 0-0-101-101 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
              0;255;3;0;9;TSP:SANCHK:OK
              • Pictor LallemandP
                Pictor LallemandP
                Pictor Lallemand
                @tekka
                yes my radio module operates on 3.3V ams1117 I use the regulator to reduce the voltage 3.3V
