  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 17.5k Views 5 Watching
  • CrankyCoderC Offline
    CrankyCoder
    wrote on last edited by tekka
    I have my mqtt client gateway up and running and I have a test node setup.
    The debug for the node is
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    Not sure what is causing it. If i reset it a few times it eventually connects. I have tried clearing the eeprom and reuploaded the sketch.
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    T 1 Reply Last reply
    • CrankyCoderC CrankyCoder
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=1)
      TSM:UPL
      T Offline
      T Offline
      tekka
      @Jason-Brunk Please provide additional information such as HW setup and configuration, and also post the complete log from node and GW while booting.
        CrankyCoder
        Looks like it may have been related to my gateway and sensor being too close.
        www.CrankyCoder.net
        MySensors: 2.3
          T Offline
          T Offline
          tekka
          @Jason-Brunk Yes, this is a common issue.
          • X Offline
            X Offline
            xefil
            wrote on last edited by xefil
            Hello!
            I'm having the same issue. How to solve it?
            I've converted a working sensor having API 1.5 with last API and getting this errors:
            Setting S_LIGHT sensor: 1
            Setting S_LIGHT sensor: 2
            Setting S_LIGHT sensor: 3
            Setting S_LIGHT sensor: 4
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=20)
            TSM:FPAR
            TSP:MSG:SEND 20-20-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSP:MSG:READ 0-0-20 s=255,c=3,t=8,pt=1,l=1,sg=0:0
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=20)
            TSM:UPL
            TSP:MSG:SEND 20-20-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:READ 28-28-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
            TSP:MSG:BC
            TSP:CHKUPL:FAIL (hops=255)
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:MSG:BC
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:MSG:BC
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:MSG:BC
            !TSM:UPL:FAIL```
            It has worked without issues until the last update.
            T CrankyCoderC 2 Replies Last reply
            • X xefil
              Hello!
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:MSG:BC
              !TSM:UPL:FAIL```
              T Offline
              T Offline
              tekka
              @xefil Did you also convert the GW to 2.0? If yes, please post the debug log.
              • Pictor LallemandP Offline
                Pictor Lallemand
                I have the same problem as do to solve it?
                Starting repeater (RNNRA-, 2.0.0)
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=123)
                TSM:FPAR
                TSP:MSG:SEND 123-123-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSP:MSG:READ 0-0-123 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=123)
                TSM:UPL
                !TSP:MSG:SEND 123-123-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                !TSM:UPL:FAIL
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                • X Offline
                  X Offline
                  xefil
                  I was quite sure the gateway (MQTTClient) was updated with latest API library, but I was wrong. It was on 1.5 version. Updated to the latest, the problem was solved. Hope it helps!
                  Simon
                  • X xefil
                    Hello!
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:MSG:BC
                    !TSM:UPL:FAIL```
                    CrankyCoder
                    @xefil with my errors. I changed the capacitor value to 100u and that fixed ALOT of problems. Some one mentioned to me that 2.0 uses the radio a little more and may need a higher value cap.
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • Pictor LallemandP Pictor Lallemand
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      T Offline
                      T Offline
                      tekka
                      @Pictor-Lallemand Please make sure your GW is at 2.0.
                      • X xefil
                        Simon
                        T Offline
                        T Offline
                        tekka
                        @xefil Perfect, have fun! :)
                        • X Offline
                          X Offline
                          xefil
                          @Jason-Brunk I already had a 100u capacitor, thanks for the suggestion.... btw strange, maybe the update was important.
                          @tekka , thank you!! ;)
                            Pictor Lallemand
                            or find the code for my GW I use an Arduino pro mini card for a ENC28J60 network and nRF24L01 for radio. because I can not find it in the examples mysensors
                            • X Offline
                              X Offline
                              xefil
                              You mean you cannot find the examples from the API library? When you download it, you can find it in there. On github as well:
                              https://github.com/mysensors/MySensors/tree/master/examples
                              In case try to start uploading two examples (1 GW and 1 sensor) and check. They work without issues. If not, maybe a hardware failure.
                              Simon
                                Pictor Lallemand
                                in the examples of the API (MySensors 2.0.0) I can not find ENC28J60 Gateway
                                send me please you the code in this gateway thank you
                                • H Offline
                                  H Offline
                                  https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples/GatewayENC28J60
                                    Pictor Lallemand
                                    it didnt change anything here is the log for sensors
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    the sketch use
                                     * Version 1.0 - Henrik Ekblad
                                    #define MY_REPEATER_FEATURE
                                    #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    void before() {
                                        pinMode(pin, OUTPUT);
                                        present(sensor, S_LIGHT);
                                      if (message.type==V_LIGHT) {
                                         // Change relay state
                                         // Store state in eeprom
                                         // Write some debug info
                                         Serial.print(message.sensor);
                                    and that of the gateway
                                    0;255;3;0;9;TSM:INIT
                                    0;255;3;0;9;TSM:RADIO:OK
                                    0;255;3;0;9;TSM:GW MODE
                                    0;255;3;0;9;TSM:READY
                                    IP: 192.168.1.15
                                    0;255;3;0;9;Eth: connect
                                    0;255;3;0;9;Eth: 0;0;3;0;2;
                                    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                                    0;255;3;0;9;Eth: 0;0;3;0;18;PING
                                    0;255;3;0;9;TSP:SANCHK:OK
                                    the sketch use
                                     * Version 1.0 - Henrik EKblad
                                     * Contribution by Tomas Hozza <thozza@gmail.com>
                                     * LED purposes:
                                    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
                                    #define MY_RF24_CE_PIN 5
                                    #define MY_RF24_CS_PIN 6
                                    #define MY_GATEWAY_ENC28J60
                                    // Gateway IP address
                                    #define MY_IP_ADDRESS 192,168,1,15
                                    #define MY_PORT 5003
                                    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                                    // Flash leds on rx/tx/err
                                    #define MY_LEDS_BLINKING_FEATURE
                                    // Set blinking period
                                    // Enable inclusion mode
                                    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                                    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                                    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                                    #include <UIPEthernet.h>
                                      i add a capacitor 220U
                                      Pictor Lallemand
                                      the gateway log
                                      IP: 192.168.1.15
                                      0;255;3;0;9;TSP:MSG:READ 123-123-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:BC
                                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=123)
                                      0;255;3;0;9;TSP:CHKUPL:OK
                                      0;255;3;0;9;TSP:MSG:GWL OK
                                      0;255;3;0;9;TSP:MSG:SEND 0-0-123-123 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                      0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                      • X Offline
                                        X Offline
                                        xefil
                                        Do you have some spare-parts to use a different radio? My gateway has a radio with nrf24l01+pa+lna to increase the range. Maybe the gain is needed with the new API? I don't know. How far are the two objects?
                                        Simon
                                          Pictor Lallemand
                                          the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
                                          12.1k
