  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.3k Views 5 Watching
  • Pictor LallemandP Pictor Lallemand
    the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
    tekkaT
    tekkaT
    tekka
    @Pictor-Lallemand
    Lets start with a simple setup:
    • all radio caps >= 22uF (ideal 100uF)
    • latest MySensors lib (i.e. 2.0.0)
    Gateway - Program GatewaySerial from the MySensors examples
    Node - Program this simple sketch:
    #define MY_NODE_ID 100
    MyMessage msgGeneral(0, V_VAR1);
    uint32_t counter = 0, lastSend = 0;
    uint8_t rebootCounter = 5;
    void presentation() {
      sendSketchInfo("TestNode", "1.0");
      present(0, S_ARDUINO_NODE, "Counter");
       if (millis() - lastSend > 500) {
          msgGeneral.setDestination(GATEWAY_ADDRESS);
          send(msgGeneral.set(counter), true);
          counter = 0;
          lastSend = millis();
          if(!rebootCounter--) {
            hwReboot();
       counter++;
    ...and post the debug log from both, GW and node.
    • hensingH
      hensingH
      hensing
      same problem here:
      minimal example worked and I figured out that assignment of an ID helps :)
      Maybe I missed this point that I have to and that auto assignment doesn't work the way I thought.
      tekkaT 1 Reply Last reply
      • hensingH hensing
        same problem here:
        tekkaT
        tekkaT
        tekka
        @hensing said:
        same problem here:
        Ok, so not related to UPL:Fail (as the title of this topic suggests)?
        • Pictor LallemandP
          Pictor LallemandP
          Pictor Lallemand
          i add 22uF capacitor to node and GW
          debug gw
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSM:RADIO:OK
          0;255;3;0;9;TSM:GW MODE
          0;255;3;0;9;TSM:READY
          0;255;0;0;18;2.0.0
          0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
          0;255;3;0;9;TSP:MSG:BC
          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
          0;255;3;0;9;TSP:CHKUPL:OK
          0;255;3;0;9;TSP:MSG:GWL OK
          0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
          0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
          0;255;3;0;9;TSP:SANCHK:OK
          debug node
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=100)
          TSM:FPAR
          TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
          TSP:MSG:PAR OK (ID=0, dist=1)
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=100)
          TSM:UPL
          TSP:PING:SEND (dest=0)
          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
          TSP:CHKUPL:FAIL (hops=255)
          !TSM:UPL:FAIL
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          I'm really frustrated that it does not work correctly yet I applied literally your sugestions
            debug gw
            0;255;0;0;18;2.0.0
            debug node
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            tekkaT
            tekkaT
            tekka
            @Pictor-Lallemand ok, now next step: substitute all caps to 100uF (or if not available add a second 22uF in parallel). Please test and upload the same logs again. How do you power your nodes?
            • Pictor LallemandP
              Pictor LallemandP
              Pictor Lallemand
              i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
              the node is powered by my laptop for use serial debug
              debug node
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              gw debug
              0;255;0;0;18;2.0.0
              Thank you for your support
                debug node
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:UPL
                !TSM:UPL:FAIL
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:UPL
                !TSM:UPL:FAIL
                TSM:FPAR
                gw debug
                0;255;0;0;18;2.0.0
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                #27
                @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
                Pictor LallemandP 1 Reply Last reply
                • tekkaT tekka
                  Pictor LallemandP
                  Pictor LallemandP
                  Pictor Lallemand
                  @tekka in parallel
                    @tekka in parallel
                    tekkaT
                    tekkaT
                    tekka
                    @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
                    • tekkaT tekka
                      Pictor LallemandP
                      Pictor LallemandP
                      Pictor Lallemand
                      @tekka I just try not conclusive
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      an idea ?
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:UPL
                        !TSM:UPL:FAIL
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        an idea ?
                        tekkaT
                        tekkaT
                        tekka
                        #31
                        @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
                        • tekkaT tekka
                          Pictor LallemandP
                          Pictor LallemandP
                          Pictor Lallemand
                          @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
                            tekkaT
                            tekkaT
                            tekka
                            @Pictor-Lallemand What HW are you using & frequency?
                            • tekkaT tekka
                              Pictor LallemandP
                              Pictor LallemandP
                              Pictor Lallemand
                              @tekka What is the HW?
                              • scalzS
                                scalzS
                                wrote on last edited by scalz
                                #35
                                @Pictor-Lallemand
                                HW= hardware ;) FW for firmware or SW software
                                that's weird you're not lucky on this, I agree with tekka it looks like hardware issue..Perhaps you could try to replace your usb cable, not sure but who knows, or maybe some bad dupont cable too (try with some other). I have already seen bad usb or dupont cables so...or maybe try with another radio module.
                                • Pictor LallemandP
                                  Pictor LallemandP
                                  Pictor Lallemand
                                  @tekka My HW is arduino pro mini 5v + ams1117 3,3V for radio module and NRF24L01 for radio
                                  • Pictor LallemandP
                                    Pictor LallemandP
                                    Pictor Lallemand
                                    @tekka
                                    I weld son tips on antenna here debug
                                    node
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSP:MSG:READ 0-0-255 s=255,c=3,t=20,pt=0,l=1,sg=0:0
                                    TSP:MSG:BC
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:UPL
                                    !TSM:UPL:FAIL
                                    TSM:FPAR
                                    TSP:MSG:BC
                                    TSP:MSG:BC
                                    !TSP:FPAR:ACTIVE (msg not send)
                                    TSP:MSG:BC
                                    TSP:MSG:BC
                                    TSP:MSG:BC
                                    TSP:MSG:BC
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSP:MSG:BC
                                    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=ok:0
                                    TSP:MSG:BC
                                    TSP:MSG:BC
                                    TSM:UPL
                                    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                    TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    TSP:MSG:PONG RECV (hops=1)
                                    TSP:CHKUPL:OK
                                    TSM:UPL:OK
                                    TSM:READY
                                    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                    TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                    TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=fail:TestNode
                                    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
                                    !TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=17,pt=0,l=7,sg=0,ft=2,st=fail:Counter
                                    Request registration...
                                    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
                                    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=fail:2
                                    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
                                    !TSM:UPL FAIL, SNP
                                    TSM:FPAR
                                    !TSP:SEND:TNR
                                    TSM:FPAR
                                    Init complete, id=100, parent=255, distance=255, registration=1
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    TSM:FPAR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    gateway debug from MYSController
                                    8	13/08/2016 18:33:12	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
                                    10	13/08/2016 18:33:20	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    11	13/08/2016 18:33:22	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    12	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                    14	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                    17	13/08/2016 18:33:27	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                    18	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                    20	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                    23	13/08/2016 18:33:28	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                    24	13/08/2016 18:33:46	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    25	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                    27	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                    30	13/08/2016 18:34:01	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                    31	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                    33	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                    36	13/08/2016 18:34:02	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                    37	13/08/2016 18:34:08	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    38	13/08/2016 18:34:08	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                    40	13/08/2016 18:34:08	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                    43	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                    44	13/08/2016 18:34:09	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                    46	13/08/2016 18:34:09	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                    49	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                    50	13/08/2016 18:34:09	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    51	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    52	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    53	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    54	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    55	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    56	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    57	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    58	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    59	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    60	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    62	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    63	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    64	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                    65	13/08/2016 18:34:14	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                    67	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                    69	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                    71	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	NA (24)	BYTE	1	NO		1
                                    72	13/08/2016 18:34:16	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			hops=1)
                                    73	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	NA (25)	BYTE	1	NO	ok	1
                                    74	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO		0100
                                    75	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO	ok	0100
                                    76	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_PRESENTATION	S_ARDUINO_NODE	STRING	5	NO		2.0.0
                                    78	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_CONFIG	BYTE	1	NO		0
                                    81	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_CONFIG	STRING	1	NO	ok	M
                                    84	13/08/2016 18:36:27	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                      @tekka
                                      node
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSP:MSG:BC
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSP:MSG:BC
                                      TSP:MSG:BC
                                      TSP:MSG:BC
                                      TSP:MSG:BC
                                      TSP:MSG:BC
                                      TSP:MSG:BC
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSP:MSG:BC
                                      TSP:MSG:BC
                                      TSP:MSG:BC
                                      TSM:UPL
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      !TSM:UPL FAIL, SNP
                                      TSM:FPAR
                                      !TSP:SEND:TNR
                                      TSM:FPAR
                                      !TSP:SEND:TNR
                                      !TSP:SEND:TNR
                                      !TSP:SEND:TNR
                                      !TSP:SEND:TNR
                                      TSM:FPAR
                                      !TSP:SEND:TNR
                                      !TSP:SEND:TNR
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Pictor-Lallemand Looks to me like a power issue, not an antenna issue.
                                      Half of the messages are OK, and then all of a sudden they all fail:
                                      TSM:UPL
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      At what frequency are you running your minis? Out of curiosity, can you post a pic of your node+radio (ideally with a pic of the cap) and GW+radio - this may give additional info.
                                      • Pictor LallemandP
                                        Pictor LallemandP
                                        Pictor Lallemand
                                        @tekka
                                        my node
                                        my gateway
                                          @tekka
                                          my node
                                          my gateway
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Pictor-Lallemand ok, now upload this sketch to both nodes and post the debug output:
                                          #define MY_CORE_ONLY
                                          void setup(){
                                            MY_SERIALDEVICE.begin(115200);
                                            MY_SERIALDEVICE.println(F("**********"));
                                            MY_SERIALDEVICE.println(__FILE__);
                                            MY_SERIALDEVICE.println(MYSENSORS_LIBRARY_VERSION);
                                            MY_SERIALDEVICE.println(hwFreeMem());
                                            MY_SERIALDEVICE.println(hwCPUVoltage());
                                            MY_SERIALDEVICE.println(hwCPUFrequency());
                                            MY_SERIALDEVICE.println(F_CPU);
                                          void loop(){}
