  2. Feature Requests
  3. How to change the SerialGateway nodeID?
4 Posts 3 Posters 1.7k Views 3 Watching
  • Magic WM
    Magic WM
    Magic W
    The default serial Gateway ID is 0, so,how to change the gateway ID?
      Changing the id of the gateway is not supported. Perhaps there is another solution to the problem you are trying to solve. Could you describe what you want to do?
      • Magic WM
        Magic WM
        Magic W
        Thanks for replay!
        I read the doc,just can‘t find how to modified the gateway id.If in the network,there are two gateway,What will it be?
        YveauxY 1 Reply Last reply
        • Magic WM Magic W
          Thanks for replay!
          YveauxY
          YveauxY
          @Magic-W there can be only one gateway per network. You can create 2 separate networks with 2 gateways (put each on a different channel to prevent interference).
          Why do you need 2 gateways?
