  3. Powering a sensor with digital out
27 Posts 7 Posters 6.5k Views 7 Watching
  • hozzeH
    hozzeH
    hozze
    Thanks guys, I will check this out.
    • hozzeH
      hozzeH
      hozze
      Was away from arduino for over a week with regular job. Tested the code with debug on a new arduino pro mini 3.3v 8Mhz and the below is the output ( please note that the values getting send are random values , i'm still not able to power the sensor with digital Pin )
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
      TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
      TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=35,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:SoilSensor
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:0.1
      Request registration...
      TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
      TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
      Node registration=1
      Init complete, id=1, parent=0, distance=1, registration=1
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:786
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:503
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:410
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:425
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:461
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:539
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:507
      TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:392
      Looks fine for me , still I can't turn a digital pin On :disappointed:
      Boots33B 1 Reply Last reply
      • hozzeH hozze
        Node registration=1
        Boots33B
        Boots33B
        Boots33
        @hozze It really should be working. I tried your original above and with a led connected to pin 5 it turns on when the code is run
        try the code below with some serial prints to see what happens
        #define MY_NODE_ID 150  // node id
        #define MY_RADIO_NRF24  // enabling support for NRF radio module
        #define NODE_ID 1  // sensor id
        #define SENS_ON 5
        #define VAL_PROBE A0
        #define POWER_ON 1  //  value to write to turn on sensor
        #define POWER_OFF 0 //  value to write to turn off sensor
        MyMessage msg(NODE_ID, V_LEVEL); // constructing the msg
          pinMode(SENS_ON, OUTPUT);
          present(NODE_ID, S_MOISTURE);  // presenting the sensor
          sendSketchInfo("SoilSensor", "0.1"); //meta data
          digitalWrite(SENS_ON, POWER_ON);
          Serial.print("Sensor Power on pin "); Serial.print(SENS_ON); Serial.print(" is..."); Serial.println((POWER_ON));
          wait(1000); // To check the input voltage of pin 2
          int moisture = analogRead(VAL_PROBE); //measuring the moisture
          send(msg.set(moisture));  // sending the data
          digitalWrite(SENS_ON, POWER_OFF); // turn it off
          Serial.print("Sensor Power on pin "); Serial.print(SENS_ON); Serial.print(" is..."); Serial.println((POWER_OFF));
          wait(1000);
        I get an output like this below and the led flashes on and off at 1 second intervals. Maybe try just a led with a 200 to 300 ohm resistor on pin 5 to see what is happening. could the moisture sensor be drawing more than the arduino can give?
        TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
        TSP:MSG:READ 0-0-150 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        TSP:MSG:SEND 150-150-0-0 s=1,c=0,t=35,pt=0,l=0,sg=0,ft=0,st=ok:
        TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:SoilSensor
        TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:0.1
        TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
        TSP:MSG:READ 0-0-150 s=255,c=3,t=27,pt=1,l=1,sg=0:1
        Node registration=1
        Init complete, id=150, parent=0, distance=1, registration=1
        Sensor Power on pin 5 is...1
        TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:511
        Sensor Power on pin 5 is...0
        TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:313
        TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:254
        TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:326
        TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:235
        • hozzeH
          hozzeH
          hozze
          I'm stupid ! @Boots33 the debug info saved me. With debug info I came to notice that the sketch goes into loop part only if the gateway is also connected and available. Stupid me was doing the pin checks just by connecting the sensor and keeping the gateway disconnected , when I had the gateway connected I didn't bother to check the pin out, I was going in the same loop and wasting my and all your valuable time.
          Thanks for all your assistance people, you guys are awesome.
          • Boots33B
            Boots33B
            Boots33
            Great to hear you got it going, and don't worry I am sure everyone here ( including me) has there own moments they would rather forget when it comes to writing code. :)
            • xydixX
              xydixX
              xydix
              This sounds like a really good idea.
              Can I use this to power like a DS18B20 tempsensor. Would this save power and give my battery powered sensors extended battery life?
              bjacobseB 1 Reply Last reply
              • xydixX xydix
                bjacobseB
                bjacobseB
                bjacobse
                wrote on last edited by bjacobse
                #27
                @xydix
                Arduino using Atmega can supply max 40mA per pin, and in total max 100mA.
                DS18B20 seems to use max 1,5mA
                so yes this will work
                After searching on the net.
                https://github.com/nathanchantrell/TinyTX/blob/master/TinyTX_DS18B20/TinyTX_DS18B20.ino
                The part for the power on, read, power off is below (taken from the above link):
                digitalWrite(ONE_WIRE_POWER, HIGH); // turn DS18B20 sensor on
                //Sleepy::loseSomeTime(5); // Allow 5ms for the sensor to be ready
                delay(5); // The above doesn't seem to work for everyone (why?)
                sensors.begin(); //start up temp sensor
                sensors.requestTemperatures(); // Get the temperature
                tinytx.temp=(sensors.getTempCByIndex(0)*100); // Read first sensor and convert to integer, reversed at receiving end
                digitalWrite(ONE_WIRE_POWER, LOW); // turn DS18B20 off
