  3. Powering a sensor with digital out
27 Posts 7 Posters 6.4k Views 7 Watching
  • hozzeH Offline
    hozzeH Offline
    hozze
    wrote on last edited by hozze
    I'm trying to power a sensor with one of the digital pins of Arduino. Issue I'm facing is I'm unable to turn on digital pin, I have tried quite few options. I feel I'm missing something simple but its wrecking my brain. Can any one of you look at the code and see what I'm doing wrong, please.
    Arduino : pro mini Atmega168 3.3v
    #define MY_NODE_ID 1  // node id
    #define MY_RADIO_NRF24  // enabling support for NRF radio module
    #define NODE_ID 1  // sensor id
    #define SENS_ON 2
    MyMessage msg(NODE_ID, V_LEVEL); // constructing the msg
    const int VAL_PROBE = 0; // initializing the moisture variable
      pinMode(SENS_ON, OUTPUT);
      present(NODE_ID, S_MOISTURE);  // presenting the sensor
      sendSketchInfo("SoilSensor", "0.1"); //meta data
      digitalWrite(SENS_ON, HIGH);
      delay(10000); // To check the input voltage on pin 2
      int moisture = analogRead(VAL_PROBE); //measuring the moisture
      send(msg.set(moisture));  // sending the data
      sleep(1000);  // sleeping for 10 sec
    T mfalkviddM 2 Replies Last reply
    • hozzeH hozze
      #define SENS_ON 2
      T Offline
      T Offline
      TheoL
      @hozze
      try this
      // byTheo 10 seconds seems to be a bit much??
        digitalWrite(SENS_ON, LOW); // turn it off
      //byTheo you didn't turn the pin off
        sleep(10000);  // sleeping for 10 sec
      // byTheo 1000 s isn't 10 secs
      • hozzeH hozze
        #define SENS_ON 2
        @hozze I'm using a similar solution if my office plant monitoring. It works well. What observation made you think that it doesn't work? Have you tried measuring the output pin with a multimeter? Could you show your wiring diagram?
        • mfalkviddM Offline
          You could try changing
          to
          #define VAL_PROBE A0
          I don't see any point in declaring it const int, and I prefer to use the An naming to make it clear which pin I am using.
          • hozzeH Offline
            hozzeH Offline
            hozze
            @TheoL , Thanks for the suggestion . Tried that, same result.
            @mfalkvidd , Thanks for the code suggestion, I made the change. Regarding the issue, I did check with a multi-meter and it shows 0V . To make sure I also used the example blink sketch with pin 2 as output and it is showing 3.24V I will attach the wiring diagram(I haven't drawn one). Things I noticed.
            • On commenting the Mysensor.h library and related code from above sketch I'm able to turn on the Pin
            • I tried using different digital pins and same result.
            • To make sure I measured the output pin voltage powering it with USB ( without connecting the board to radio and soil sensor ) , same result voltage is 0V
            • hozzeH hozze
              @hozze looks like good troubleshooting, great work.
              Very interesting that it works when uncommenting the MySensors stuff. I think there are some leds blinking features in 2.0 (have not yet moved to 2.0 myself so I don't know more than what I've read in the forum), but I think that is only enabled for gateways.
              Does it help if you remove include <SPI.h>? It looks like SPI is not used so it shouldn't make a difference but you might as well remove it if you aren't using it.
              Y 1 Reply Last reply
                Y Offline
                Y Offline
                This feature is also present in previous versions and not limited to gateways.
                Pin 2 however is never used for leds as it is the default irq pin for nRF.
                Try with another pin, e.g. 4/5/6 and see if that makes a difference.
                • hozzeH Offline
                  hozzeH Offline
                  hozze
                  @mfalkvidd : Removed SPI.h , it didn't help though. Thanks for pointers on cleaning up the code :smiley:
                  @Yveaux :
                  Tried with pin 5 , same result.
                  Tried using a different pro mini ( Atmega328 16Mhz 5 v ) got same result , no output on pin :expressionless:
                  • hozzeH hozze
                    @Yveaux :
                    Y Offline
                    Y Offline
                    @hozze make sure you don't define MY_LEDS_BLINKING_FEATURE or MY_INCLUSION_MODE_FEATURE, as their pin mappings might interfere with your application.
                    • hozzeH Offline
                      hozzeH Offline
                      hozze
                      @Yveaux I don't have those defined. Below is my current code.
                      #define SENS_ON 5
                        delay(1000); // To check the input voltage of pin 2
                      //  sleep(1000);  // sleeping for 10 sec
                      An as soon as I comment it out like below the pin out on 5 works
                      #define SENS_ON 5
                      //#include <MySensors.h>
                      //  present(NODE_ID, S_MOISTURE);  // presenting the sensor
                      //  sendSketchInfo("SoilSensor", "0.1"); //meta data
                      // send(msg.set(moisture));  // sending the data
                      • hozzeH hozze
                        #define SENS_ON 5
                        #define SENS_ON 5
                        Y Offline
                        Y Offline
                        @hozze it's strange that you only measure 3.24V on the output pin if you're using a 5V pro mini. This is IMHO an indication that something is wrong, also when your pin does seem to toggle.
                        T 1 Reply Last reply
                        • hozzeH Offline
                          hozzeH Offline
                          hozze
                          I see that output on pro mini Atmega168 3.3v with commented sketch.
                          I tried with a different 5v pro mini Atmega368 and I'm getting 5.04V on output pin with commented sketch.
                          • Y Yveaux
                            T Offline
                            T Offline
                            TheoL
                            @Yveaux @hozze Are you sure it's a ProMini 5V? Could you measure the voltage on the Raw pin.
                            I've received some Pro Mini 3.3V while I actually did order 5V.
                            It's just a guess.
                            hozzeH 1 Reply Last reply
                            • T TheoL
                              It's just a guess.
                              hozzeH Offline
                              hozzeH Offline
                              hozze
                              @TheoL I have two pro mini's. I measured the voltage across a output pin ( HIGH ) and GND and it gives me near 5V on one and near 3.3V on another .So it looks as if I do have 5V pro mini.
                              I have tried few other sketches on both, seems they are working fine, I face the specific issue only when including the Mysensor.h library. I will give it a try on a nano that I have and see what happens.
                              • hozzeH hozze
                                T Offline
                                T Offline
                                TheoL
                                @hozze It was just a guess. I once compiled a sketch for a 5V and uploaded it to a ProMini 3.3V. Took me a while before I noticed my mistake. I just didn;t understand why my Arduino couldn't control my relay boards ;-)
                                • T TheoL
                                  hozzeH Offline
                                  hozzeH Offline
                                  hozze
                                  @TheoL :smiley: me too learning things the hard way.
                                  Thanks for all the pointers that you guys are giving . Looks as if I'm in the right place and with a great community,
                                  Let me tinker a bit more and see if I can get somewhere, if anyone can give any further info kindly do.
                                  Boots33B 1 Reply Last reply
                                  • hozzeH hozze
                                    Boots33B Offline
                                    Boots33B Offline
                                    Boots33
                                    @hozze You should enable debugging at the top of your sketch with
                                    and check the serial monitor to see if the radio is initialising . Maybe the loop part of the program will not run if this does not happen. That could be why commenting out the #include <MySensors.h> allows it to work.
                                    You might also use wait instead of delay
                                    • hozzeH Offline
                                      hozzeH Offline
                                      hozze
                                      @Boots33 , I enabled MY_DEBUG. Sorry if I sound stupid. I have connected the pro mini to computer with USB serial CP2102 for programming/serial debug , at the same time can I power the pro mini + Radio with an external power supply 3.3V ?
                                      I did something similar with a ATTINY85 few days back and bricked it :cry: ( Connected it to USB and same time powered it )
                                      mfalkviddM Boots33B 2 Replies Last reply
                                      • hozzeH hozze
                                        @hozze connect gnd from the serial adapter AND the external power supply to gnd on the Arduino. Connect + on the external adapter to the pin you normally use (vcc or raw). Do not connect + from the serial adapter. That's it.
                                        • hozzeH hozze
                                          Boots33B Offline
                                          Boots33B Offline
                                          Boots33
                                          @hozze The whole purpose of a good forum is for people to share ideas and knowledge. So never be worried about asking questions. :)
