  3. (Relay) node asks for parent. Gateway forwards (!)
6 Posts 2 Posters 1.7k Views 1 Watching
  • E
    E
    Erik Forsberg
    wrote on last edited by Erik Forsberg
    Hi!
    I have a problem with one of my nodes, a sensor that is counting pulses on my power meter and also acts as relay. The relay functionality works fine from what I can see, but I'm not receiving any data from the power meter.
    I don't have the output from the actual node available (it's in the garage..), but I see strange things happening on the gateway. Here's a typical message that reoccurs every 10s:
    16-08-07 19:58:04 mysensors.mysensors: n:0 c:255 t:3 s:9 p:TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    16-08-07 19:58:04 mysensors.mysensors: n:0 c:255 t:3 s:9 p:TSF:MSG:BC
    16-08-07 19:58:04 mysensors.mysensors: n:0 c:255 t:3 s:9 p:TSF:MSG:FPAR REQ,ID=4
    16-08-07 19:58:04 mysensors.mysensors: n:0 c:255 t:3 s:9 p:TSF:CHKUPL:OK,FCTRL
    16-08-07 19:58:04 mysensors.mysensors: n:0 c:255 t:3 s:9 p:TSF:MSG:GWL OK
    16-08-07 19:58:05 mysensors.mysensors: n:0 c:255 t:3 s:9 p:TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    Now, I don't have the whole protocol understanding, and I just switched to 2.0.1-beta1 (directly off git) on the gateway to see if that was the problem, but if I read the above right the node (node id 4) is sending a request to get a parent, but the gateway forwards it instead of replying with a message that it is the parent.
    Am I right? What could be the reason of this? Bad routing table in gateway?
    Receiving messages from other nodes works w/o problems - even from nodes that pass through this troublesome node.
    Gateway is running what's on development branch right now (d054c1c0c87d444c2e34e0e49f5e357e401ee209). The node is running a slightly earlier version.
    Thanks!
    \EF
    For reference, here's my gateway code:
    #define MY_RF24_CHANNEL  42
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    void presentation() {
    E 1 Reply Last reply
    • E Erik Forsberg
      Hi!
      Thanks!
      \EF
      E
      E
      Erik Forsberg
      @Erik-Forsberg
      So, replying to my own post, after looking a bit closer, it does send a reply telling the node that its parent is 0. So I guess the problem is on the other side some way. Hmm.. Need to investigate further.
      tekkaT 1 Reply Last reply
      • E Erik Forsberg
        @Erik-Forsberg
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @Erik-Forsberg The GW replies to a I_FIND_PARENT request from node 4 - nothing unusual here. I assume there is a radio/power issue with node 4 - can you get the debug log from that node?
        Here is an explanation of the different GW messages
        1. Node 4 sends I_FIND_PARENT request to broadcast address (=255)
        1. GW receives broadcast message
        TSF:MSG:BC
        1. BC message is identified as I_FIND_PARENT request from node 4
        1. GW has also repeater functionality, meaning it checks the uplink (in that case to itself). Uplink is ok. FCTRL refers to "flood control", a mechanism that prevents flooding the GW with check uplink requests.
        TSF:CHKUPL:OK,FCTRL
        TSF:MSG:GWL OK
        1. Send I_FIND_PARENT_RESPONSE to node 4
        Everything as expected from a GW/repeater perspective :)
        • tekkaT tekka
          TSF:MSG:BC
          TSF:CHKUPL:OK,FCTRL
          TSF:MSG:GWL OK
          E
          E
          Erik Forsberg
          @tekka Thankyou! I will need to dig further another day. I will start by upgrading that troublesome node to the latest library version and see if the problem persists.
          After enabling signing debug, it's now complaining a lot about the node not signing messages that should really be signed. So there could be some bug hidden in the combination of a node that makes both get and set requests, is a relay, and use soft signing.
          I'll report back as soon as I find the time to make these experiments.
          • E Erik Forsberg
            tekkaT
            tekkaT
            tekka
            @Erik-Forsberg ok, certainly a good idea to update all nodes and GW to the most recent version - there are incompatibilities with singing and other features if used in a mixed setup.
            • E
              E
              Erik Forsberg
              Hmm.. basically, this node works if signing is disabled. If it's enabled, all the nonce requests fail to transmit (with st=NACK). Disabling signing, it has greater success in transferring its data.
              So I guess it's yet another problem with the radio. I suspected this.
              This is an NRF24L01+PA+LNA module. I have:
              • Tried multiple radio modules to rule out a faulty one.
              • Put the radio module on a dedicated 3.3V power regulator.
              • Tried both high and low PA level.
              • Same thing on gateway - NRF24L01+PA+LNA, on dedicated 3.3V power regulator.
              It seems to succeed in most cases, at least when it's sending just a set request. Presentations and others do not work. It's like it's having trouble transmitting longer messages. Odd.
              The code in this sketch is using an interrupt handler to count pulsess on my energy meter. Could this be related?
              Some debug output from the node, with signing disabled:
              MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
              TSM:INIT
              TSM:INIT:TSP OK
              TSF:ASID:OK,ID=4
              TSM:FPAR
              TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              TSF:MSG:FPAR RES,ID=0,D=0
              TSF:MSG:FPAR OK,ID=0,D=1
              TSM:FPAR:OK
              TSM:ID
              TSM:ID:OK,ID=4
              TSM:UPL
              TSF:PING:SEND,TO=0
              TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              TSF:MSG:PONG RECV,HP=1
              TSF:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              !TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=NACK:2.0.1-beta
              TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
              TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=NACK:Energy Meter
              TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=OK:1.1
              TSF:MSG:SEND,4-4-0-0,s=4,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
              MCO:REG:REQ
              TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              MCO:PIM:NODE REG=1
              setup(). Radio Channel is 42
              TSF:MSG:SEND,4-4-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
              MCO:BGN:INIT OK,ID=4,PAR=0,DIS=1,REG=1
              TSF:MSG:READ,0-0-4,s=4,c=1,t=24,pt=0,l=7,sg=0:7418044
              Received last pulse count from gw:7418044
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:3169
              Watt:3169
              !TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=NACK:7418088
              !TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=1,st=NACK:741.8089
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=17,pt=5,l=4,sg=0,ft=2,st=OK:3156
              Watt:3156
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:7418132
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:741.8133
              Watt:3169
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:7418177
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:741.8177
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:7311
              Watt:7241
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:7418249
              TSF:MSG:SEND,4-4-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:741.8249```
