  3. [Solved] Function repeater not working
16 Posts 3 Posters 4.9k Views 2 Watching
  • D
    D
    Daemon D
    wrote on last edited by tekka
    Help, function repeater not working
    Vera lite fw 1.7.830
    GW Arduino nano serial - MySensors Arduino Library v2.0.0 master
    node/repeater Arduino nano MySensors Arduino Library v2.0.0 master
    code node/repeater ID=3
    #define MY_REPEATER_FEATURE
    node ID = 4 and ID = 6 long distance and worked perfectly through the library 1.5.4 and repeater ID = 3
    After the transition to version 2, these two nodes fallen off
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=3)
    TSM:FPAR
    TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 4-4-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSP:MSG:BC
    TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=3)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    Setup:
    !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
    TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=ok:2.0.0
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:READ 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Alarm Sensor
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
    TSP:MSG:SEND 3-3-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=3,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 3-3-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    Request registration...
    TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=3, parent=0, distance=1, registration=1
    TSP:MSG:BC
    TSP:MSG:READ 6-6-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:SEND 3-3-0-0 s=3,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=ok:0
    tekkaT 1 Reply Last reply
    • D Daemon D
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSP:MSG:BC
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=3)
      TSM:UPL
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      Setup:
      Node registration=1
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      tekkaT
      tekkaT
      tekka
      Node 3 is not defined as repeater:
      RNNNA- indicates normal node operation. This also explains, why node 3 does not reply to I_FIND_PARENT requests:
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      TSP:MSG:BC
      Please double check and upload node 3 sketch if problem persists.
      • D
        D
        Daemon D
        that is enough to enable the repeater?
        • D Daemon D
          tekkaT
          tekkaT
          tekka
          @Daemon-D Please post the full repeater sketch
          D 1 Reply Last reply
          • tekkaT tekka
            D
            D
            Daemon D
            @tekka
            #include "CyberLib.h" //Библиотека от Cyber-Place.ru
            #include <Bounce2.h>
            #define ConsoleComm 0
            #define TIME_READ_INPUT_SEPIC_SIGN 1000 //время снятия показаний с входов
            #define TIME_SEND_VERA_SEPTIC 66000 //время для отправки данных септика
            #define TIME_SEND_VERA_SIGN 11000 //время для отправки данных сигнализации
            #define TIME_SEND_VERA_220 53100 //время для отправки данных 220
            #define RELAY_SIGN  6  // pin relay сигнализации
            #define DIGITAL_INPUT_SEPTIC 7   // The digital input D7 септик
            #define DIGITAL_INPUT_SIGN 8   // The digital input D8 сигнализация
            #define INTERRUPT_220V 3   // пин датчика наличия 220
            #define CHILD_VERA_SEPTIC 1   // Id Vera вирутального сенсора ошибки септика
            #define CHILD_VERA_SIGN 2   // Id  Vera вирутального сенсора срабатывания сигнализации
            #define CHILD_VERA_220 3 // ID Vera вирутального сенсора наличия 220
            #define CHILD_VERA_RELAY_SIGN 4 // Id Vera реле сигнализации
            #define CHILD_VERA_ROLLING 5 // Id Vera  рольставни
            //MySensor gw; // MySensor
            Bounce debouncerInputSeptic = Bounce();
            Bounce debouncerInputSign = Bounce();
            MyMessage errorMsgSeptic(CHILD_VERA_SEPTIC, V_TRIPPED); // виртуальный сенсор ошибки септика
            MyMessage errorMsgSign(CHILD_VERA_SIGN, V_TRIPPED); // виртуальный сенсор сигнализации
            MyMessage errorMsg220(CHILD_VERA_220, V_TRIPPED); // виртуальный сенсор 220
            int powerlostint; // храним нарастающим итогом переходы 0 по 220
            bool powerlost, valueSeptic, valueSign;
            unsigned long currentTime;
            unsigned long loopTimeRead, loopTimeSeptic, loopTimeSign, loopTime220;
            Metro timer_read = Metro(TIME_READ_INPUT_SEPIC_SIGN); // храним время опросов датчиков входов
            Metro time_send_septic = Metro(TIME_SEND_VERA_SEPTIC); // храним время отправки данных на Vera о септике
            Metro time_send_sign = Metro(TIME_SEND_VERA_SIGN); // храним время отправки данных на Vera о сигнализации
            Metro time_send_220 = Metro(TIME_SEND_VERA_220); // храним время отправки данных на Vera о 220
            void presentation()  {
              //  gw.begin(incomingMessage, AUTO, true); //repeater node
                sendSketchInfo("Alarm Sensor", "1.0");
                present(CHILD_VERA_SEPTIC, S_MOTION); //alarm D7
                present(CHILD_VERA_SIGN, S_MOTION); //alarm D8
                present(CHILD_VERA_220, S_MOTION); //alarm 220
                present(CHILD_VERA_RELAY_SIGN, S_LIGHT); //relay D6
                present(CHILD_VERA_ROLLING, S_LIGHT); // вирутальное реле для рольставень
            //********************обработчики прерываний*******************************
            void  detect_up() { // обработка внешнего прерывания. Сработает по переднему фронту
                powerlostint++; // если 50 раз в секунду получаем прерывание, увеличиваем powerlostint
            //****************************SETUP*********************************************
                UART_Init(115200);//инициализация последовательного порта
            #if ConsoleComm
                Serial << "Setup: " <<  endl;
                pinMode(RELAY_SIGN, OUTPUT);
                D4_Out; //Настраиваем пин D4 на выход для управления рольставнями
                pinMode(DIGITAL_INPUT_SEPTIC, INPUT);  // определяем DIGITAL_INPUT_SEPTIC как вход
                digitalWrite(DIGITAL_INPUT_SEPTIC, HIGH);     // подключить подтягивающий резистор
                pinMode(DIGITAL_INPUT_SIGN, INPUT);  // определяем IGITAL_INPUT_SENSOR_D7 как вход
                digitalWrite(DIGITAL_INPUT_SIGN, HIGH);     // подключить подтягивающий резистор
                debouncerInputSeptic.attach(DIGITAL_INPUT_SEPTIC);
                debouncerInputSeptic.interval(5);
                debouncerInputSign.attach(DIGITAL_INPUT_SIGN);
                debouncerInputSign.interval(5);
            //**************************** LOOP ********************************************************
               // gw.process(); // By calling process() you route messages in the background
                debouncerInputSeptic.update();  // обновляем статус боунсера септика
                debouncerInputSign.update(); // обновляем статус боунсера сигнализации
                if (timer_read.check() == 1) ReadD(); // через TIME_READ_INPUT_SEPIC_SIGN запускаем ReadD()
                if (time_send_septic.check() == 1) SendVeraSeptic(); // через TIME_SEND_VERA_SEPTIC запускаем SendVeraSeptic()
                if (time_send_sign.check() == 1) SendVeraSign(); // через TIME_SEND_VERA_SIGN запускаем SendVeraSign()
                if (time_send_220.check() == 1) SendVera220(); // через TIME_SEND_VERA_220 запускаем SendVera220()
            //************************ END LOOP **********************************************************
            //************************** ReadD() *********************************************************
            // считываем данные со входов
            void ReadD() {
                // Get the update value
                valueSeptic = debouncerInputSeptic.read();
                valueSign = debouncerInputSign.read();
                //valueSign = digitalRead(DIGITAL_INPUT_SIGN);
            #if ConsoleComm
                Serial << "valueSign: " << valueSign << endl;
                Serial << "valueSeptic: " << valueSeptic << endl;
                Serial << "powerlost: " << powerlost << endl;
            //******************************** END ReadD() ****************************************************
            //********************************* SendVeraSeptic() ***********************************************
            // отсылаем данные на Vera о септике
            void SendVeraSeptic() {
            #if ConsoleComm
                Serial << "SendVeraSeptic(): " << valueSeptic << endl;
                send(errorMsgSeptic.set(valueSeptic ? "1" : "0")); // Send tripped value to gw
            //********************************* END SendVeraSeptic() ***********************************************
            //********************************* SendVeraSign() ***********************************************
            // отсылаем данные на Vera о сигнализации
            void SendVeraSign() {
            #if ConsoleComm
                Serial << "SendVeraSign(): " << valueSign << endl;
                send(errorMsgSign.set(valueSign ? "1" : "0")); // Send tripped value to gw
            //********************************* END SendVeraSign() ***********************************************
            //********************************* SendVera220() ***********************************************
            // отсылаем данные на Vera о 220
            void SendVera220() {
            #if ConsoleComm
                Serial << "220: " << powerlostint << endl;
                attachInterrupt(digitalPinToInterrupt(INTERRUPT_220V),detect_up, LOW); // включаем прерывание чтобы наловить фронты 220
                delay(2); // нужен, т.к. бывает не успевает собрать данные
                if (powerlostint > 0) powerlost = false; // если получили кучу прерываний, значит 220 есть
                else powerlost=true;	// если нет прерываний, нет и 220
                detachInterrupt(digitalPinToInterrupt(INTERRUPT_220V)); //временно выключаем прерывание
                send(errorMsg220.set(powerlost ? "1" : "0")); // Send tripped value to gw
                powerlostint=0; // обнуляем счётчик прерываний
            //********************************* END SendVera220() ***********************************************
            //********************************** incomingMessage ************************************************
                    // Change relay state
                    if (message.sensor == CHILD_VERA_RELAY_SIGN) { // если пришло для сигнализации
                        digitalWrite(RELAY_SIGN, message.getBool() ? RELAY_ON : RELAY_OFF);
                        // Store state in eeprom
                        // gw.saveState(message.sensor, message.getBool());
                    if (message.sensor == CHILD_VERA_ROLLING) { // если пришло для рольставень
                        if (message.getBool() == true) { // если пришла 1 то закрываем
                            for (int i = 0; i < 5; i++) {
                                closers();
                        } else if (message.getBool() == false)
                            for (int i = 0; i < 5; i++) { // если пришёл 0 то открываем
                                    openrs();
                        //  attachInterrupt(digitalPinToInterrupt(INTERRUPT_220V), detect_up, LOW);  // настроить срабатывание прерывания interrupt1 на pin 2 на низкий уровень
                    // Write some debug info
            #if ConsoleComm
                    Serial.print(message.sensor);
            //************************************* END incomingMessage ******************************************
            • D Daemon D
              @tekka
              #if ConsoleComm
              void ReadD() {
              #if ConsoleComm
              #if ConsoleComm
              #if ConsoleComm
              #if ConsoleComm
                                  closers();
                                      openrs();
              #if ConsoleComm
              tekkaT
              tekkaT
              tekka
              @Daemon-D Hmm...where do you load the MySensors lib?
              (this statement is missing in your sketch)
              D sinczeS 2 Replies Last reply
              • tekkaT tekka
                D
                D
                Daemon D
                wrote on last edited by Daemon D
                @tekka
                Используем библиотеку MySensors версии 2.0.1-beta из папки: C:\Users\Daemon\Google Drive\Project\libraries\MySensors
                Already I tried the beta of the development, all the same.
                • tekkaT tekka
                  sinczeS
                  sinczeS
                  sincze
                  MySensors Evangelist
                  @tekka interesting. I assume people are already using repeaters in 2.0.x so it will be safe for me to. Migrate from 1.5.4 to 2.0.0??
                  D tekkaT 2 Replies Last reply
                  • sinczeS sincze
                    D
                    D
                    Daemon D
                    Yes, Migrate from 1.5.4 to 2.0.0
                    sinczeS 1 Reply Last reply
                    • D Daemon D
                      sinczeS
                      sinczeS
                      sincze
                      @Daemon-D okay for you still not working right??
                      • sinczeS sincze
                        D
                        D
                        Daemon D
                        Repeater not working :(
                        • D Daemon D
                          tekkaT
                          tekkaT
                          tekka
                          @Daemon-D I'm not sure you got my question regarding the issue you have with your repeater node. I suggest you try the RepeaterNode sketch from the MySensors examples and post the debug log here.
                          • sinczeS sincze
                            tekkaT
                            tekkaT
                            tekka
                            Yes, should be safe to use.
                            • tekkaT tekka
                              D
                              D
                              Daemon D
                              @tekka
                              The problem was solved by a code transfer at the very beginning as a test sketch before #include
                              // Enabled repeater feature for this node
                              #define MY_REPEATER_FEATURE```
                              • D Daemon D
                                @tekka
                                tekkaT
                                tekkaT
                                tekka
                                @Daemon-D Can you explain how you solved the issue - I'm sure other user could also profit if they face a similar problem. Thanks.
                                • tekkaT tekka
                                  D
                                  D
                                  Daemon D
                                  The problem was solved by moving to the top of the sketch exactly like the to test the sketch before #include
