  3. Library 2.0 - No Humidity sketch
8 Posts 4 Posters 1.9k Views 4 Watching
  • DdawmeD Offline
    DdawmeD Offline
    Ddawme
    I wanted to update all my sensor to the 2.0 library but Im noticing that the Humidity sketch seems to have been removed. Is this correct?
    • tlpeterT Offline
      tlpeterT Offline
      tlpeter
      It is there and is called
      DhtTemperatureAndHumiditySensor
      • DdawmeD Offline
        DdawmeD Offline
        Ddawme
        hmm... is it possible I somehow got an incomplete library? I only have 4 sketches that begin with D and none of them are that one.
        • tlpeterT Offline
          tlpeterT Offline
          tlpeter
          wrote on last edited by tlpeter
          Did you download the new examples? they are not included anymore.
          Here you can find them:
          https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples
          DdawmeD 1 Reply Last reply
          • tlpeterT tlpeter
            DdawmeD Offline
            DdawmeD Offline
            Ddawme
            @tlpeter I had not, thanks so much! I'm still a novice when it comes to GitHub, how do I download the files?
            • tlpeterT Offline
              tlpeterT Offline
              tlpeter
              I don't know either and i remember that there should be a zip file which you can download.
              I only cannot remember where.
              For now you can copy the code and save it.
              • mfalkviddM Offline
                The zip download link is a bit hard to find because it is only visible at the top level of the project (not in subfolders). Keep in mind that the sketch depends on the dht library so you'll need to download the zip file. Just the sketch might not work.
                • Tagore.PDET Offline
                  Tagore.PDET Offline
                  Tagore.PDE
                  //Including nescessary libraries
                  #include <DHT.h>
                  #define HUMIDITY 1
                  #define TEMPERATURE 2
                  DHT dht;
                  float lastTempValue;
                  float lastHumValue;
                  boolean metric = true;
                  unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)(30 seconds)
                  #define MESSAGEWAIT 500
                  MyMessage msgHum(HUMIDITY, V_HUM);
                  MyMessage msgTemp(TEMPERATURE, V_TEMP);
                  void presentation()  {
                    sendSketchInfo("XXXX", "XX");
                    wait(MESSAGEWAIT);
                    present(HUMIDITY, S_HUM);
                    wait(MESSAGEWAIT);
                    present(TEMPERATURE, S_TEMP);
                    wait(MESSAGEWAIT);
                              if (isnan(temperature)) {
                                                      } else if (temperature != lastTempValue) {
        lastTempValue = temperature;
        Serial.print("Temp: ");
        Serial.println(temperature);
                               if (isnan(humidity)) {
                                                    } else if (humidity != lastHumValue) {
        lastHumValue = humidity;
        Serial.print("Hum: ");
        Serial.println(humidity);
                              sleep(SLEEP_TIME);
                  12.1k
