  3. [SOLVED] ESP8266 - RFM69W - Are they talking??
8 Posts 4 Posters 3.2k Views 4 Watching
  • DinnocD
    DinnocD
    Dinnoc
    I'm working on a project for an ESP8266 RFM69W Gateway and Sensor.
    I currently have the gateway and sensor set up and about 1M away from each other.
    The gateway seems to start fine and gives the following output on serial monitor
    Gateway
    0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    scandone
    f 0, ....scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with SKYD7336, channel 11
    dhcp client start...
    .ip:192.168.0.10,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.10
    pm open,type:2 0
    0;255;3;0;9;TSP:SANCHK:OK
    However when i start up the motionsensor node it doesn't seem to connect
    Starting sensor (RRNNE-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=254)
    TSM:FPAR
    TSP:MSG:SEND 254-254-255-255 s=255,cTSM:FPAR
    scandone
    state: 0 -> 2 (b0)
    TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 7
    cnt
    ip:192.168.0.24,mask:255.255.255.0,gw:192.168.0.1
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    pm open,type:2 0
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    The motion sensor output is especially confusing because the motion sensor in theory doesnt know my SSID, however it says its connected to my wifi router etc.
    As I say I'm pretty new to this so any help would be appreciated??
    finally, is there a reference to allow me to make sense of the output messages or do i have to hack into the code?
    TheoLT tekkaT 2 Replies Last reply
    • DinnocD Dinnoc
      Gateway
      scandone
      f 0, ....scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 5
      cnt
      .IP: 192.168.0.10
      pm open,type:2 0
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 7
      cnt
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      pm open,type:2 0
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TheoLT
      TheoLT
      TheoL
      @Dinnoc There's a reference to the meaning if the debug somewhere on the forum. @tekka might now where it is.
      As far as I read other threads on the forum, your node is continuously looking for a gateway which it can't find. What happens if you put them farther away of each other?
      Or both radio's on the same frequency?
      • DinnocD Dinnoc
        Gateway
        scandone
        f 0, ....scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 5
        cnt
        .IP: 192.168.0.10
        pm open,type:2 0
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 7
        cnt
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        pm open,type:2 0
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @Dinnoc @Theol is right, your node is searching for a parent (=GW in your case). Can you upload the sketches of both, GW and node? From the debug log it looks like you are running your node on ESP8266?
        • DinnocD
          DinnocD
          Dinnoc
          wrote on last edited by Dinnoc
          thanks tekka,
          I am running on and eSP8266-12 and using an RFM69W.
          A few questions/points
          -Can you confirm the pin assignments for ESP8266 - are they configurable?
          -for the RFM69W should i add #define MY_IS_RFM69HW in the myconfig file?
          -i have added 4.7uf caps on bothpower supplies and dont seem to be getting any reboots or funny SANCHK messages. (ive use esp alot so am used to power fluctuation issues)
          Code is pretty close to examples with static setting of node id and parent node id
          GATEWAY
          #include <EEPROM.h>
          #define MY_BAUD_RATE 9600
          #define MY_PARENT_NODE_ID 0
          #define MY_NODE_ID 100
          //#define MY_RADIO_NRF24
          #define MY_RADIO_RFM69
          #define MY_GATEWAY_ESP8266
          #define MY_ESP8266_SSID "888888"
          #define MY_ESP8266_PASSWORD "8888888"
          // Enable UDP communication
          //#define MY_USE_UDP
           #define MY_ESP8266_HOSTNAME "sensor-gateway"
          #define MY_PORT 5003
          // Enable inclusion mode
          // #define MY_INCLUSION_BUTTON_FEATURE
          // Flash leds on rx/tx/err
           #define MY_LEDS_BLINKING_FEATURE
          // Set blinking period
          // Led pins used if blinking feature is enabled above
          #if defined(MY_USE_UDP)
            #include <WiFiUDP.h>
          #else
            #include <ESP8266WiFi.h>
          void presentation() {
          MOTION SENSOR
          // Enable debug prints
          #define MY_PARENT_NODE_ID 100
          #define MY_NODE_ID 45
          // Initialize motion message
            sendSketchInfo("Motion Sensor", "1.0");
            present(CHILD_ID, S_MOTION);
            // Read digital motion value
            Serial.println("in Loop");
            Serial.println(tripped);
            send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
            sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
          chrilleC 1 Reply Last reply
          • DinnocD Dinnoc
            thanks tekka,
            GATEWAY
            #include <EEPROM.h>
            #else
            MOTION SENSOR
            chrilleC
            chrilleC
            chrille
            The SPI bus signals (MISO + MOSI + SCK) seems to be hardwired to GPIO 12, 13 and 14
            The interrupt pin and chip select are configurable - for my gateway I use
            #define MY_RF69_IRQ_PIN 15
            #define MY_RF69_SPI_CS 16
            Remember that GPIO 16 doesn't support interrupts on the ESP8266 so it can't be used for interrupts. I avoid using GPIO 4+5 since these are default pins for I2C and I have several ideas on using I2C on the gateway (status display or locally attached sensors)
            GPIO 0 + 2 are usable for LED's
            No, W and CW have lower output and should not have MY_IS_RFM69HW defined - it's only for HW and HCW version
            Also, did you configure MY_RFM69_FREQUENCY to match your frequency band?
            I have seen a lot of issues with ESP8266 + RFM69 stability. Somehow it seems to help to touch the antenne of the RFM69! Several other people I have talked has seen this issue as well. I have solved it in two ways
            1. Connecting a dipole antenna or a quarterwave antenna on a ground plane, to the RFM69 instead of a quarterwave (piece of wire)
            2. Laying out a proper 2-layer PCB with a good groundplane
            My current gateway is using a proper PCB and is very reliable
            The RFM69 library from lowpowerlabs comes with two simple sketches (gateway and node) which are quite handy for verifying the RF setup. You need to comment out a few things to compile on the ESP8266, but it's pretty straight forward
            • Jan
            • DinnocD
              DinnocD
              Dinnoc
              Thanks Chrille,
              A few follow up questions
              I have
              MISO --> 12
              MOSI --> 13
              SCK --> 14
              NSS (assume this is IRQ) --> 15 (which is also pulled down to earth with a resistor)
              I dont have anything going to 16 , which pin on the RF69 is chip select?
              Frequency band is 868 and is configured correctly
              And finally i dont have an antenna. my devices are about 0.5m away from each other. Do i need an antenna? If so does it need to be a speicific length? and what socket of the RF69 do it attach it to (ANA??)
              I attach an image of my set up, its not pretty, but it might help.
              • DinnocD Dinnoc
                Thanks Chrille,
                I have
                MISO --> 12
                MOSI --> 13
                SCK --> 14
                chrilleC
                chrilleC
                chrille
                @Dinnoc said:
                I have
                MISO --> 12
                MOSI --> 13
                SCK --> 14
                That's correct
                No, NSS is chip select (MY_RF69_SPI_CS)
                IRQ needs to go to DIO0 (MY_RF69_IRQ_PIN)
                (No need to configure MY_RF69_IRQ_NUM on ESP8266 was pin and IRQ number always is the same on ESP8266)
                So you need 5 connections (MISO, MOSI, SCK, NSS and IRQ) to the ESP8266 + VCC/GND
                A quarterwave at 868 MHz is approx 9 cm, so go with a piece of wire at that length, connected to ANA
                It would probably work without an antenna, but to product the PA of the module you should connect just a simple antennna
                Looking at your picture it looks very much like a HW module, and not a H module, so I suggest you configure isRFM69HW
                • Jan
                • DinnocD
                  DinnocD
                  Dinnoc
                  All working now, thanks Chrille!!
                  For anyone else trying to get RFM69W working with ESP8266
                  I have
                  MISO -> GPIO12
                  MOSI -> GPIO13
                  SCK -> GPIO14
                  NSS - > GPIO16
                  DIO0 ->GPIO15 (Which is also pulled down with a 10k resistor)
                  ANA -> antenna (to be honest i eyeballed 9cm but haven't measured it (was going to trim afterwards))
                  VCC -> 3.3V
                  GND -> GND
                  I also soldered a 4.7uf cap over the power and ground of the RFM69W directly on the RFM69W PCB
                  For the power supply i have a 5V USB supply (old phone charger) with a 1000uf cap over the +ve and -ve. then and LD1117 to feed 3.3V to the ESP and the RFM69. Should probably also have 47uf cap somewhere on the 3.3V side as well.
                  I saw people talking about them being too close as well. I tested most of mine about 50cm apart with no major issues.
                  I made the following mods to get either the gateway or node sketch working
                  All makes for a pretty cheap gateway. I was planning on using the ESP for nodes as well but is seems its power consumption is far greater than the arduino mini pro, so i ordered a few of them for nothing and will build my nodes based on those.
