  3. Battery sensor and re-connecting to gateway
24 Posts 6 Posters 9.1k Views 4 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    @tekka I guessed that, I thought however that you'd mentioned it would timeout, and try again later? As it stands it appears it'll keep trying until the battery is dead?
    If nothing else I just want to clear up the behaviour so I fully understand it.
    Thanks,
    Mark
    tekkaT 1 Reply Last reply
    • Mark SwiftM Mark Swift
      Thanks,
      Mark
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #22
      @Mark-Swift it does timeout, but for that you have to set MY_TRANSPORT_WAIT_READY_MS > 0. This ensures, that loop() will be entered after the timeout if the connection could not be established.
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        @tekka thank you, so if I
        #define MY_TRANSPORT_WAIT_READY_MS 60000
        Am I right in thinking that my node will enter the loop after it tries to connect to a parent for 60 seconds and fails? (In my case it'd then sleep until the next interrupt, when I guess it would then try again for 60 seconds...).
        I really appreciate your help getting my head around this :)
          tekkaT
          tekkaT
          tekka
          @Mark-Swift Almost :)
          applies only when the node starts, i.e. before entering loop(). Once you are in loop() and you put the node to sleep
          #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 10000
          defines how long the node will try to establish a connection before going to sleep, default is 10s. Please have a look here for additional information.
