  3. Battery sensor and re-connecting to gateway
24 Posts 6 Posters 9.1k Views 4 Watching
  • karl261K
    karl261K
    karl261
    I found this code in another thread, but it is locked for reply. I have some sensors outside and sometimes they lose the connection and actually they never re-connect.
    So for me to understand properly: It seems to me to make a lot of sense to put this code into all my battery powered sensors, because they sleep all the time and if they lose the connection, then they will never re-connect, but with this code they should. Is that right? They are only awake to take some reading and send it and then sleep,immediately.
    Is that correct?
    if(isTransportOK()){
        sleep(30000);  // transport is OK, node can sleep
      else {
        wait(5000); // transport is not operational, allow the transport layer to fix this
    TheoLT 1 Reply Last reply
    • karl261K karl261
      Is that correct?
        else {
      TheoLT
      TheoLT
      TheoL
      @karl261 That could do the trick. Because the Node needs time to reestablish the connection with the gateway. Which it can't do when your Arduino is sleeping.
      But before I'd try such tricks, I would be interested in what the cause of connection loss is. Is the distance too long? Is there a power issue? Also what version of MySensors are you using?
      F 1 Reply Last reply
      • TheoLT TheoL
        F
        F
        flopp
        @TheoL
        In version 1.5.1, when the node send the data without connection it will try to find a parent(repeater) after 6 failures.
        So if your node send data every hour it will need 6 hour before it will try to find a parent.
        If you start the sensor near the GW and then move the node too far away from the GW and out have a repeater next to the new place where you out the node it needs 6 transmissions before it find the repeater.
        But you shall find out what the main problem is for the node.
        Maybe you can connect a serial monitor to it and change the sleep to 1 min and then see what happens.
        • F flopp
          @TheoL
          TheoLT
          TheoLT
          TheoL
          @flopp Hello dear friend,
          If I'm not mistaken, there's in improvement on that field in MySensors 2.0. Maybe @Hek or @Tekka or @Yveaux know more about this.
          But as advised before. If you can solve the communication problem, it'll be a more permanent solution.
          tekkaT 1 Reply Last reply
          • TheoLT TheoL
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @TheoL @flopp @karl261 I'm currently working on a improved sleep function in 2.0.1 that will address some of the issues mentioned above. Depending on the radio status, the node will sleep if link is ok, or try to reconnect and abort if too many failed attempts and retry later.
            • karl261K
              karl261K
              karl261
              Ok, thanks a lot. It is clear now. I will add some code and try. Later in 2.0.1 I can just remove this code...
              Question: the six failed transmissions: do they need to be consecutive? Or does it just count to six over time?
              • karl261K karl261
                tekkaT
                tekkaT
                tekka
                @karl261 consecutive
                • karl261K
                  karl261K
                  karl261
                  Another question:
                  Woudn't it be better to do something like this
                  while(!isTransportOK()){
                  sleep(SLEEP_TIME);  // transport is OK, node can sleep
                  or doesn't this bring anything?
                  • karl261K
                    karl261K
                    karl261
                    Wow, This is so cool. This probably solves all my problems from the past year.
                    It just happened: I had a node connected to the gateway and brought it far away. It lost the connection to the gateway. I switched on a repeater node halfway. The node reconnected to the gateway via the repeater node.
                    I can't believe it!
                    • karl261K
                      karl261K
                      karl261
                      @tekka The only problem with this extra code is, that in case the node loses its connection, it will drain the battery quite quickly...
                      • karl261K karl261
                        tekkaT
                        tekkaT
                        tekka
                        @karl261 yes, in the example you mentioned, the node won't sleep at all if connection is lost and cannot be re-established. For battery powered nodes I recommend using MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC to prevent the transport state machine from entering the SNP (search new parent) state.
                        MySensors 2.0.1 introduces an enhanced sleeping function with a reconnection timeout: https://github.com/mysensors/MySensors/pull/558
                        • tekkaT tekka
                          great work @tekka
                          • karl261K
                            karl261K
                            karl261
                            @tekka Yeah, that's what I actually use. Since I normally don't move my sensors and repeaters, having the parent node static sounds like a good thing to do.
                            I look forward to the 2.0.1 release. There seem to be a lot of cool new things inside.
                            @tekka, @oitzu, Still, this nrf is driving me nuts. My sensor in the garden has worked just fine for three weeks, and nothing has changed. Now it makes problems. It is still running, because once per day one Temp reading or similar is getting through. Battery is just the same as before.
                            Do you have any idea why it could have stopped working? I don't see any reason why the repeater should stop receiving the values. The repeater works fine, it relays all other nodes. And the geometry between repeater and garden sensor has not changed.
                            The weather has changed. The T is about 7 degrees less outside...
                            • Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              @tekka I'm using the latest snapshot on one of my battery sensors and can see if it can't connect, it doesn't sleep and the debug shows a rapid number of connection attempts. I'd like to know if the sensor will eventually sleep if it cannot successfully connect, and what the default timeout is?
                              • Mark SwiftM Mark Swift
                                tekkaT
                                tekkaT
                                tekka
                                @Mark-Swift Please post your sketch & full debug log. Thanks
                                • Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  @tekka I don't think there's an issue.
                                  I'm simply asking what the logic is behind the reconnection logic on sleeping sensors, how long is the timeout for example (I'm conscious of battery drain for nodes having issues connecting).
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Mark-Swift No, this sounds like an issue - a rapid number of connection attempts is unusual, that's why I'm interested in your sketch/debug log.
                                    To answer your questions: In the latest dev version the node will try to reconnect with a 10sec timeout (if sleeping time > 10sec, this can be changed via MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS) before sleeping - if time is left.
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      wrote on last edited by Mark Swift
                                      @tekka it's been a while but I never resolved this... If I test by changing the parent node ID to a fake one, it just tried to connect forever, thus draining the battery...
                                      Sketch:
                                        REVISION HISTORY
                                        Created by Mark Swift
                                        V1.2 - Added sleep time to force daily update
                                        V1.3 - Deactivate pullup on setup and added old_value logic
                                        V1.4 - Added daily wakeup to sleep
                                        V1.5 - Code cleanup
                                      //*** EXTERNAL LIBRARIES **********************************
                                      #include <Vcc.h>
                                      //*** MYSENSORS *******************************************
                                      // Enable debug prints
                                      // Lower serial speed if using 1Mhz clock
                                      // #define MY_BAUD_RATE 9600
                                      #define MY_NODE_ID 4
                                      #define MY_PARENT_NODE_ID 1 // AUTO
                                      // #define MY_RADIO_RFM69
                                      // Override RF24L01 channel number
                                      // #define MY_RF24_CHANNEL 125
                                      // Override RF24L01 module PA level
                                      // #define MY_RF24_PA_LEVEL RF24_PA_LOW
                                      // Override RF24L01 datarate
                                      // #define MY_RF24_DATARATE RF24_250KBPS
                                      // Enabled repeater feature for this node
                                      // #define MY_REPEATER_FEATURE
                                      // *** SKETCH CONFIG **************************************
                                      #define SKETCH_NAME "Door Sensor"
                                      #define SKETCH_MAJOR_VER "1"
                                      #define SKETCH_MINOR_VER "5"
                                      // Define the sensor child IDs
                                      #define CHILD_ID1 1 // Switch
                                      #define CHILD_ID2 2 // Battery voltage
                                      #define CHILD_ID3 3 // Battery percent
                                      // Define the message formats
                                      MyMessage msg(CHILD_ID1, V_TRIPPED);
                                      MyMessage msg2(CHILD_ID2, V_CUSTOM);
                                      MyMessage msg3(CHILD_ID3, V_CUSTOM);
                                      // *** SENSORS CONFIG *************************************
                                      // Digital I/O pin for button or reed switch
                                      #define PRIMARY_BUTTON_PIN 3
                                      // Debounce using a small sleep
                                      #define DEBOUNCE_SLEEP 5
                                      // Sleep timer in milliseconds
                                      #define SLEEP_IN_MS 86400000
                                      // Store the old value for comparison
                                      int old_value = -1;
                                      // Minimum expected vcc level, in volts (2xAA alkaline)
                                      const float vcc_min = 2.0 * 0.9;
                                      // Maximum expected vcc level, in volts (2xAA alkaline)
                                      const float vcc_max = 2.0 * 1.5;
                                      // Measured vcc by multimeter divided by reported vcc
                                      const float vcc_correction = 2.88 / 2.82;
                                      Vcc vcc(vcc_correction);
                                      // *** BEGIN **********************************************
                                        // Setup the contact sensor
                                        pinMode(PRIMARY_BUTTON_PIN, INPUT);
                                        // Activate or deactivate the internal pull-up - high if using internal resistor or low if using external
                                        digitalWrite(PRIMARY_BUTTON_PIN, LOW);
                                        // Send the sketch version information to the gateway and controller
                                        sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
                                        // Register all sensors to the gateway
                                        present(CHILD_ID1, S_DOOR);
                                        present(CHILD_ID2, S_CUSTOM);
                                        present(CHILD_ID3, S_CUSTOM);
                                        // Debouce using sleep
                                        sleep(DEBOUNCE_SLEEP);
                                        int value = digitalRead(PRIMARY_BUTTON_PIN);
                                        // If value has changed send the updated value
                                        if (value != old_value) {
                                          send(msg.set(value == HIGH ? 0 : 1));
                                          old_value = value;
                                        // Read battery voltage
                                        float battery_voltage = vcc.Read_Volts();
                                        // Calculate battery percentage
                                        float battery_percent = vcc.Read_Perc(vcc_min, vcc_max);
                                      #ifdef MY_DEBUG
                                        Serial.print("Battery = ");
                                        Serial.print(battery_voltage);
                                        Serial.println(" Volts");
                                        Serial.print(battery_percent);
                                        Serial.println("%");
                                        // Send battery readings
                                        send(msg2.set(battery_voltage, 2));
                                        send(msg3.set(battery_percent, 1));
                                        sendBatteryLevel(battery_percent);
                                        // Sleep until either interupt change or timer reaches zero
                                        smartSleep(PRIMARY_BUTTON_PIN - 2, CHANGE, SLEEP_IN_MS);
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        Debug:
                                        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                                        4 TSM:INIT
                                        6 TSF:WUR:MS=0
                                        14 TSM:INIT:TSP OK
                                        16 TSM:INIT:STATID=4
                                        18 TSF:SID:OK,ID=4
                                        20 TSM:FPAR
                                        22 TSM:FPAR:STATP=1
                                        24 TSM:ID
                                        24 TSM:ID:OK
                                        26 TSM:UPL
                                        63 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        2072 TSM:UPL
                                        2109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        4118 TSM:UPL
                                        4155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        6164 TSM:UPL
                                        6201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        8210 !TSM:UPL:FAIL
                                        8212 TSM:FPAR
                                        8212 TSM:FPAR:STATP=1
                                        8214 TSM:ID
                                        8216 TSM:ID:OK
                                        8218 TSM:UPL
                                        8255 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        10264 TSM:UPL
                                        10301 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        12310 TSM:UPL
                                        12347 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        14356 TSM:UPL
                                        14393 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        16402 !TSM:UPL:FAIL
                                        16404 TSM:FPAR
                                        16404 TSM:FPAR:STATP=1
                                        16408 TSM:ID
                                        16410 TSM:ID:OK
                                        16410 TSM:UPL
                                        16449 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        18458 TSM:UPL
                                        18495 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        20504 TSM:UPL
                                        20541 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        22550 TSM:UPL
                                        22587 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        24596 !TSM:UPL:FAIL
                                        24598 TSM:FPAR
                                        24598 TSM:FPAR:STATP=1
                                        24602 TSM:ID
                                        24604 TSM:ID:OK
                                        24604 TSM:UPL
                                        24643 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        26652 TSM:UPL
                                        26689 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        28698 TSM:UPL
                                        28735 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        30744 TSM:UPL
                                        30781 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        32790 !TSM:UPL:FAIL
                                        32792 TSM:FPAR
                                        32792 TSM:FPAR:STATP=1
                                        32796 TSM:ID
                                        32798 TSM:ID:OK
                                        32798 TSM:UPL
                                        32837 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        34846 TSM:UPL
                                        34883 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        36892 TSM:UPL
                                        36929 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        38938 TSM:UPL
                                        38975 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        40984 !TSM:UPL:FAIL
                                        40986 TSM:FPAR
                                        40986 TSM:FPAR:STATP=1
                                        40990 TSM:ID
                                        40992 TSM:ID:OK
                                        40992 TSM:UPL
                                        41031 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        43040 TSM:UPL
                                        43077 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        45086 TSM:UPL
                                        45123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        47132 TSM:UPL
                                        47169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        49178 !TSM:UPL:FAIL
                                        49180 TSM:FPAR
                                        49180 TSM:FPAR:STATP=1
                                        49184 TSM:ID
                                        49186 TSM:ID:OK
                                        49186 TSM:UPL
                                        49225 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        51234 TSM:UPL
                                        51271 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        53280 TSM:UPL
                                        53317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        55326 TSM:UPL
                                        55363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        57372 !TSM:UPL:FAIL
                                        57374 TSM:FPAR
                                        57374 TSM:FPAR:STATP=1
                                        57378 TSM:ID
                                        57380 TSM:ID:OK
                                        57380 TSM:UPL
                                        57419 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        59428 TSM:UPL
                                        59465 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        61474 TSM:UPL
                                        61511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        63520 TSM:UPL
                                        63557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        65566 !TSM:UPL:FAIL
                                        65568 TSM:FPAR
                                        65568 TSM:FPAR:STATP=1
                                        65572 TSM:ID
                                        65574 TSM:ID:OK
                                        65574 TSM:UPL
                                        65613 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        67624 TSM:UPL
                                        67661 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        69672 TSM:UPL
                                        69709 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        71720 TSM:UPL
                                        71757 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        73768 !TSM:UPL:FAIL
                                        73771 TSM:FPAR
                                        73771 TSM:FPAR:STATP=1
                                        73775 TSM:ID
                                        73777 TSM:ID:OK
                                        73777 TSM:UPL
                                        73816 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        75825 TSM:UPL
                                        75862 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        77871 TSM:UPL
                                        77907 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        79917 TSM:UPL
                                        79953 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        81963 !TSM:UPL:FAIL
                                        81965 TSM:FPAR
                                        81965 TSM:FPAR:STATP=1
                                        81969 TSM:ID
                                        81971 TSM:ID:OK
                                        81971 TSM:UPL
                                        82010 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        84019 TSM:UPL
                                        84056 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        86065 TSM:UPL
                                        86102 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        88111 TSM:UPL
                                        88147 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        90157 !TSM:UPL:FAIL
                                        90159 TSM:FPAR
                                        90159 TSM:FPAR:STATP=1
                                        90163 TSM:ID
                                        90165 TSM:ID:OK
                                        90165 TSM:UPL
                                        90204 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        92213 TSM:UPL
                                        92250 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        94259 TSM:UPL
                                        94296 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        96305 TSM:UPL
                                        96342 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        98351 !TSM:UPL:FAIL
                                        98353 TSM:FPAR
                                        98353 TSM:FPAR:STATP=1
                                        98357 TSM:ID
                                        98359 TSM:ID:OK
                                        98359 TSM:UPL
                                        98398 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        100407 TSM:UPL
                                        100444 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        102453 TSM:UPL
                                        102490 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        104499 TSM:UPL
                                        104536 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        106545 !TSM:UPL:FAIL
                                        106547 TSM:FPAR
                                        106549 TSM:FPAR:STATP=1
                                        106551 TSM:ID
                                        106553 TSM:ID:OK
                                        106555 TSM:UPL
                                        106592 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        108601 TSM:UPL
                                        108638 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        110647 TSM:UPL
                                        110684 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        112693 TSM:UPL
                                        112730 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        114739 !TSM:UPL:FAIL
                                        114741 TSM:FPAR
                                        114743 TSM:FPAR:STATP=1
                                        114745 TSM:ID
                                        114747 TSM:ID:OK
                                        114749 TSM:UPL
                                        114786 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        116795 TSM:UPL
                                        116832 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        118841 TSM:UPL
                                        118878 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        120887 TSM:UPL
                                        120924 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        122933 !TSM:UPL:FAIL
                                        122935 TSM:FPAR
                                        122937 TSM:FPAR:STATP=1
                                        122939 TSM:ID
                                        122941 TSM:ID:OK
                                        122943 TSM:UPL
                                        122980 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        124989 TSM:UPL
                                        125026 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        127035 TSM:UPL
                                        127072 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        129081 TSM:UPL
                                        129118 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        131127 !TSM:UPL:FAIL
                                        131129 TSM:FPAR
                                        131131 TSM:FPAR:STATP=1
                                        131133 TSM:ID
                                        131135 TSM:ID:OK
                                        131137 TSM:UPL
                                        131174 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        133183 TSM:UPL
                                        133220 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        135229 TSM:UPL
                                        135266 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        137275 TSM:UPL
                                        137312 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        139321 !TSM:UPL:FAIL
                                        139323 TSM:FPAR
                                        139325 TSM:FPAR:STATP=1
                                        139327 TSM:ID
                                        139329 TSM:ID:OK
                                        139331 TSM:UPL
                                        139368 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        141377 TSM:UPL
                                        141414 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        143423 TSM:UPL
                                        143460 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        145469 TSM:UPL
                                        145506 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        147515 !TSM:UPL:FAIL
                                        147517 TSM:FPAR
                                        147519 TSM:FPAR:STATP=1
                                        147521 TSM:ID
                                        147523 TSM:ID:OK
                                        147525 TSM:UPL
                                        147562 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        149571 TSM:UPL
                                        149608 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        151617 TSM:UPL
                                        151654 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        153663 TSM:UPL
                                        153700 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        155709 !TSM:UPL:FAIL
                                        155711 TSM:FPAR
                                        155713 TSM:FPAR:STATP=1
                                        155715 TSM:ID
                                        155717 TSM:ID:OK
                                        155719 TSM:UPL
                                        155756 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        157765 TSM:UPL
                                        157802 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        159811 TSM:UPL
                                        159848 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        161857 TSM:UPL
                                        161894 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        163903 !TSM:UPL:FAIL
                                        163905 TSM:FPAR
                                        163907 TSM:FPAR:STATP=1
                                        163909 TSM:ID
                                        163911 TSM:ID:OK
                                        163913 TSM:UPL
                                        163950 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        165959 TSM:UPL
                                        165996 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        168005 TSM:UPL
                                        168042 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        170051 TSM:UPL
                                        170088 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        172097 !TSM:UPL:FAIL
                                        172099 TSM:FPAR
                                        172101 TSM:FPAR:STATP=1
                                        172103 TSM:ID
                                        172105 TSM:ID:OK
                                        172107 TSM:UPL
                                        172144 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        174153 TSM:UPL
                                        174190 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        176199 TSM:UPL
                                        176236 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        178245 TSM:UPL
                                        178282 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        180291 !TSM:UPL:FAIL
                                        180293 TSM:FPAR
                                        180295 TSM:FPAR:STATP=1
                                        180297 TSM:ID
                                        180299 TSM:ID:OK
                                        180301 TSM:UPL
                                        180338 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        182347 TSM:UPL
                                        182384 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        184393 TSM:UPL
                                        184430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        186439 TSM:UPL
                                        186476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        188485 !TSM:UPL:FAIL
                                        188487 TSM:FPAR
                                        188489 TSM:FPAR:STATP=1
                                        188491 TSM:ID
                                        188493 TSM:ID:OK
                                        188495 TSM:UPL
                                        188532 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        190541 TSM:UPL
                                        190578 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        192587 TSM:UPL
                                        192624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        194633 TSM:UPL
                                        194670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        196679 !TSM:UPL:FAIL
                                        196681 TSM:FPAR
                                        196683 TSM:FPAR:STATP=1
                                        196685 TSM:ID
                                        196687 TSM:ID:OK
                                        196689 TSM:UPL
                                        196726 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        198735 TSM:UPL
                                        198772 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        200781 TSM:UPL
                                        200818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        202827 TSM:UPL
                                        202864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        204873 !TSM:UPL:FAIL
                                        204875 TSM:FPAR
                                        204877 TSM:FPAR:STATP=1
                                        204879 TSM:ID
                                        204881 TSM:ID:OK
                                        204883 TSM:UPL
                                        204920 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        206931 TSM:UPL
                                        206968 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        208979 TSM:UPL
                                        209016 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        211027 TSM:UPL
                                        211064 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        213075 !TSM:UPL:FAIL
                                        213078 TSM:FPAR
                                        213080 TSM:FPAR:STATP=1
                                        213082 TSM:ID
                                        213084 TSM:ID:OK
                                        213086 TSM:UPL
                                        213123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        215132 TSM:UPL
                                        215169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        217178 TSM:UPL
                                        217214 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        219224 TSM:UPL
                                        219260 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        221270 !TSM:UPL:FAIL
                                        221272 TSM:FPAR
                                        221274 TSM:FPAR:STATP=1
                                        221276 TSM:ID
                                        221278 TSM:ID:OK
                                        221280 TSM:UPL
                                        221317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        223326 TSM:UPL
                                        223363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        225372 TSM:UPL
                                        225409 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        225689 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                                        225695 TSF:MSG:BC
                                        226275 TSF:MSG:READ,0-3-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                                        226281 TSF:MSG:BC
                                        227418 TSM:UPL
                                        227454 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        229464 !TSM:UPL:FAIL
                                        229466 TSM:FPAR
                                        229468 TSM:FPAR:STATP=1
                                        229470 TSM:ID
                                        229472 TSM:ID:OK
                                        229474 TSM:UPL
                                        229511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        231520 TSM:UPL
                                        231557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        233566 TSM:UPL
                                        233603 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        235612 TSM:UPL
                                        235649 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        237658 !TSM:UPL:FAIL
                                        237660 TSM:FPAR
                                        237662 TSM:FPAR:STATP=1
                                        237664 TSM:ID
                                        237666 TSM:ID:OK
                                        237668 TSM:UPL
                                        237705 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        239714 TSM:UPL
                                        239751 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        241760 TSM:UPL
                                        241797 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        243806 TSM:UPL
                                        243843 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        245852 !TSM:UPL:FAIL
                                        245854 TSM:FPAR
                                        245856 TSM:FPAR:STATP=1
                                        245858 TSM:ID
                                        245860 TSM:ID:OK
                                        245862 TSM:UPL
                                        245899 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        247908 TSM:UPL
                                        247945 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        249954 TSM:UPL
                                        249991 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        252000 TSM:UPL
                                        252037 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        254046 !TSM:UPL:FAIL
                                        254048 TSM:FPAR
                                        254050 TSM:FPAR:STATP=1
                                        254052 TSM:ID
                                        254054 TSM:ID:OK
                                        254056 TSM:UPL
                                        254093 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        256102 TSM:UPL
                                        256139 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        258148 TSM:UPL
                                        258185 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        260194 TSM:UPL
                                        260231 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        262240 !TSM:UPL:FAIL
                                        262242 TSM:FPAR
                                        262244 TSM:FPAR:STATP=1
                                        262246 TSM:ID
                                        262248 TSM:ID:OK
                                        262250 TSM:UPL
                                        262287 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        264296 TSM:UPL
                                        264333 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        266342 TSM:UPL
                                        266379 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        268388 TSM:UPL
                                        268425 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        270434 !TSM:UPL:FAIL
                                        270436 TSM:FPAR
                                        270438 TSM:FPAR:STATP=1
                                        270440 TSM:ID
                                        270442 TSM:ID:OK
                                        270444 TSM:UPL
                                        270481 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        272490 TSM:UPL
                                        272527 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        274536 TSM:UPL
                                        274573 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        276582 TSM:UPL
                                        276619 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        278628 !TSM:UPL:FAIL
                                        278630 TSM:FPAR
                                        278632 TSM:FPAR:STATP=1
                                        278634 TSM:ID
                                        278636 TSM:ID:OK
                                        278638 TSM:UPL
                                        278675 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        280684 TSM:UPL
                                        280721 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        282730 TSM:UPL
                                        282767 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        284776 TSM:UPL
                                        284813 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        286822 !TSM:UPL:FAIL
                                        286824 TSM:FPAR
                                        286826 TSM:FPAR:STATP=1
                                        286828 TSM:ID
                                        286830 TSM:ID:OK
                                        286832 TSM:UPL
                                        286869 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        288878 TSM:UPL
                                        288915 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        290924 TSM:UPL
                                        290961 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        292970 TSM:UPL
                                        293007 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        295016 !TSM:UPL:FAIL
                                        295018 TSM:FPAR
                                        295020 TSM:FPAR:STATP=1
                                        295022 TSM:ID
                                        295024 TSM:ID:OK
                                        295026 TSM:UPL
                                        295063 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        297072 TSM:UPL
                                        297109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        299118 TSM:UPL
                                        299155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        301164 TSM:UPL
                                        301201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        303210 !TSM:UPL:FAIL
                                        303212 TSM:FPAR
                                        303214 TSM:FPAR:STATP=1
                                        303216 TSM:ID
                                        303218 TSM:ID:OK
                                        303220 TSM:UPL
                                        303257 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        305266 TSM:UPL
                                        305303 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        307312 TSM:UPL
                                        307349 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        309358 TSM:UPL
                                        309395 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        311404 !TSM:UPL:FAIL
                                        311406 TSM:FPAR
                                        311408 TSM:FPAR:STATP=1
                                        311410 TSM:ID
                                        311412 TSM:ID:OK
                                        311414 TSM:UPL
                                        311451 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        313460 TSM:UPL
                                        313497 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        315506 TSM:UPL
                                        315543 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        317552 TSM:UPL
                                        317589 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        319598 !TSM:UPL:FAIL
                                        319600 TSM:FPAR
                                        319602 TSM:FPAR:STATP=1
                                        319604 TSM:ID
                                        319606 TSM:ID:OK
                                        319608 TSM:UPL
                                        319645 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        321654 TSM:UPL
                                        321691 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        323700 TSM:UPL
                                        323737 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        325746 TSM:UPL
                                        325783 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        327792 !TSM:UPL:FAIL
                                        327794 TSM:FPAR
                                        327796 TSM:FPAR:STATP=1
                                        327798 TSM:ID
                                        327800 TSM:ID:OK
                                        327802 TSM:UPL
                                        327839 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        329848 TSM:UPL
                                        329885 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        331894 TSM:UPL
                                        331931 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        333940 TSM:UPL
                                        333977 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        335986 !TSM:UPL:FAIL
                                        335988 TSM:FPAR
                                        335990 TSM:FPAR:STATP=1
                                        335992 TSM:ID
                                        335994 TSM:ID:OK
                                        335996 TSM:UPL
                                        336033 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        338042 TSM:UPL
                                        338079 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        340088 TSM:UPL
                                        340125 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        342134 TSM:UPL
                                        342171 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        344180 !TSM:UPL:FAIL
                                        344182 TSM:FPAR
                                        344184 TSM:FPAR:STATP=1
                                        344186 TSM:ID
                                        344188 TSM:ID:OK
                                        344190 TSM:UPL
                                        344227 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        346238 TSM:UPL
                                        346275 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        348286 TSM:UPL
                                        348323 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        350334 TSM:UPL
                                        350371 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        352382 !TSM:UPL:FAIL
                                        352385 TSM:FPAR
                                        352387 TSM:FPAR:STATP=1
                                        352389 TSM:ID
                                        352391 TSM:ID:OK
                                        352393 TSM:UPL
                                        352430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        354439 TSM:UPL
                                        354476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        356485 TSM:UPL
                                        356521 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        358531 TSM:UPL
                                        358567 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        360577 !TSM:UPL:FAIL
                                        360579 TSM:FPAR
                                        360581 TSM:FPAR:STATP=1
                                        360583 TSM:ID
                                        360585 TSM:ID:OK
                                        360587 TSM:UPL
                                        360624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        362633 TSM:UPL
                                        362670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        364679 TSM:UPL
                                        364716 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        366725 TSM:UPL
                                        366761 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        368771 !TSM:UPL:FAIL
                                        368773 TSM:FPAR
                                        368775 TSM:FPAR:STATP=1
                                        368777 TSM:ID
                                        368779 TSM:ID:OK
                                        368781 TSM:UPL
                                        368818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        370827 TSM:UPL
                                        370864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        372873 TSM:UPL
                                        372910 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        374919 TSM:UPL
                                        374956 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        376965 !TSM:UPL:FAIL
                                        376967 TSM:FPAR
                                        376969 TSM:FPAR:STATP=1
                                        376971 TSM:ID
                                        376973 TSM:ID:OK
                                        376975 TSM:UPL
                                        377012 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                        379021 TSM:UPL
                                        379058 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                                        381067 TSM:UPL
                                        381104 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                                        383113 TSM:UPL
                                        383150 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                                        385159 !TSM:UPL:FAIL
                                        385161 TSM:FPAR
                                        385163 TSM:FPAR:STATP=1
                                        385165 TSM:ID
                                        385167 TSM:ID:OK
                                        385169 TSM:UPL
                                        385206 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                                        387215 TSM:UPL
                                        387252 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                                        389261 TSM:UPL
                                        389298 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                                        391307 TSM:UPL
                                        391344 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                                        393353 !TSM:UPL:FAIL
                                        393355 TSM:FPAR
                                        393357 TSM:FPAR:STATP=1
                                        393359 TSM:ID
                                        393361 TSM:ID:OK
                                        393363 TSM:UPL
                                        393400 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        395409 TSM:UPL
                                        395446 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                                        397455 TSM:UPL
                                        397492 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                                        399501 TSM:UPL
                                        399538 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                                        401547 !TSM:UPL:FAIL
                                        401549 TSM:FPAR
                                        401551 TSM:FPAR:STATP=1
                                        401553 TSM:ID
                                        401555 TSM:ID:OK
                                        401557 TSM:UPL
                                        401594 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                                        403603 TSM:UPL
                                        403640 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                                        405649 TSM:UPL
                                        405686 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                                        407695 TSM:UPL
                                        407732 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                                        409741 !TSM:UPL:FAIL
                                        409743 TSM:FPAR
                                        409745 TSM:FPAR:STATP=1
                                        409747 TSM:ID
                                        409749 TSM:ID:OK
                                        409751 TSM:UPL
                                        409788 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                                          Debug:
                                          4 TSM:INIT
                                          6 TSF:WUR:MS=0
                                          14 TSM:INIT:TSP OK
                                          18 TSF:SID:OK,ID=4
                                          20 TSM:FPAR
                                          22 TSM:FPAR:STATP=1
                                          24 TSM:ID
                                          24 TSM:ID:OK
                                          26 TSM:UPL
                                          2072 TSM:UPL
                                          4118 TSM:UPL
                                          6164 TSM:UPL
                                          8210 !TSM:UPL:FAIL
                                          8212 TSM:FPAR
                                          8214 TSM:ID
                                          8216 TSM:ID:OK
                                          8218 TSM:UPL
                                          10264 TSM:UPL
                                          12310 TSM:UPL
                                          14356 TSM:UPL
                                          16402 !TSM:UPL:FAIL
                                          16404 TSM:FPAR
                                          16408 TSM:ID
                                          16410 TSM:ID:OK
                                          16410 TSM:UPL
                                          18458 TSM:UPL
                                          20504 TSM:UPL
                                          22550 TSM:UPL
                                          24596 !TSM:UPL:FAIL
                                          24598 TSM:FPAR
                                          24602 TSM:ID
                                          24604 TSM:ID:OK
                                          24604 TSM:UPL
                                          26652 TSM:UPL
                                          28698 TSM:UPL
                                          30744 TSM:UPL
                                          32790 !TSM:UPL:FAIL
                                          32792 TSM:FPAR
                                          32796 TSM:ID
                                          32798 TSM:ID:OK
                                          32798 TSM:UPL
                                          34846 TSM:UPL
                                          36892 TSM:UPL
                                          38938 TSM:UPL
                                          40984 !TSM:UPL:FAIL
                                          40986 TSM:FPAR
                                          40990 TSM:ID
                                          40992 TSM:ID:OK
                                          40992 TSM:UPL
                                          43040 TSM:UPL
                                          45086 TSM:UPL
                                          47132 TSM:UPL
                                          49178 !TSM:UPL:FAIL
                                          49180 TSM:FPAR
                                          49184 TSM:ID
                                          49186 TSM:ID:OK
                                          49186 TSM:UPL
                                          51234 TSM:UPL
                                          53280 TSM:UPL
                                          55326 TSM:UPL
                                          57372 !TSM:UPL:FAIL
                                          57374 TSM:FPAR
                                          57378 TSM:ID
                                          57380 TSM:ID:OK
                                          57380 TSM:UPL
                                          59428 TSM:UPL
                                          61474 TSM:UPL
                                          63520 TSM:UPL
                                          65566 !TSM:UPL:FAIL
                                          65568 TSM:FPAR
                                          65572 TSM:ID
                                          65574 TSM:ID:OK
                                          65574 TSM:UPL
                                          67624 TSM:UPL
                                          69672 TSM:UPL
                                          71720 TSM:UPL
                                          73768 !TSM:UPL:FAIL
                                          73771 TSM:FPAR
                                          73775 TSM:ID
                                          73777 TSM:ID:OK
                                          73777 TSM:UPL
                                          75825 TSM:UPL
                                          77871 TSM:UPL
                                          79917 TSM:UPL
                                          81963 !TSM:UPL:FAIL
                                          81965 TSM:FPAR
                                          81969 TSM:ID
                                          81971 TSM:ID:OK
                                          81971 TSM:UPL
                                          84019 TSM:UPL
                                          86065 TSM:UPL
                                          88111 TSM:UPL
                                          90157 !TSM:UPL:FAIL
                                          90159 TSM:FPAR
                                          90163 TSM:ID
                                          90165 TSM:ID:OK
                                          90165 TSM:UPL
                                          92213 TSM:UPL
                                          94259 TSM:UPL
                                          96305 TSM:UPL
                                          98351 !TSM:UPL:FAIL
                                          98353 TSM:FPAR
                                          98357 TSM:ID
                                          98359 TSM:ID:OK
                                          98359 TSM:UPL
                                          100407 TSM:UPL
                                          102453 TSM:UPL
                                          104499 TSM:UPL
                                          106547 TSM:FPAR
                                          106551 TSM:ID
                                          106553 TSM:ID:OK
                                          106555 TSM:UPL
                                          108601 TSM:UPL
                                          110647 TSM:UPL
                                          112693 TSM:UPL
                                          114741 TSM:FPAR
                                          114745 TSM:ID
                                          114747 TSM:ID:OK
                                          114749 TSM:UPL
                                          116795 TSM:UPL
                                          118841 TSM:UPL
                                          120887 TSM:UPL
                                          122935 TSM:FPAR
                                          122939 TSM:ID
                                          122941 TSM:ID:OK
                                          122943 TSM:UPL
                                          124989 TSM:UPL
                                          127035 TSM:UPL
                                          129081 TSM:UPL
                                          131129 TSM:FPAR
                                          131133 TSM:ID
                                          131135 TSM:ID:OK
                                          131137 TSM:UPL
                                          133183 TSM:UPL
                                          135229 TSM:UPL
                                          137275 TSM:UPL
                                          139323 TSM:FPAR
                                          139327 TSM:ID
                                          139329 TSM:ID:OK
                                          139331 TSM:UPL
                                          141377 TSM:UPL
                                          143423 TSM:UPL
                                          145469 TSM:UPL
                                          147517 TSM:FPAR
                                          147521 TSM:ID
                                          147523 TSM:ID:OK
                                          147525 TSM:UPL
                                          149571 TSM:UPL
                                          151617 TSM:UPL
                                          153663 TSM:UPL
                                          155711 TSM:FPAR
                                          155715 TSM:ID
                                          155717 TSM:ID:OK
                                          155719 TSM:UPL
                                          157765 TSM:UPL
                                          159811 TSM:UPL
                                          161857 TSM:UPL
                                          163905 TSM:FPAR
                                          163909 TSM:ID
                                          163911 TSM:ID:OK
                                          163913 TSM:UPL
                                          165959 TSM:UPL
                                          168005 TSM:UPL
                                          170051 TSM:UPL
                                          172099 TSM:FPAR
                                          172103 TSM:ID
                                          172105 TSM:ID:OK
                                          172107 TSM:UPL
                                          174153 TSM:UPL
                                          176199 TSM:UPL
                                          178245 TSM:UPL
                                          180293 TSM:FPAR
                                          180297 TSM:ID
                                          180299 TSM:ID:OK
                                          180301 TSM:UPL
                                          182347 TSM:UPL
                                          184393 TSM:UPL
                                          186439 TSM:UPL
                                          188487 TSM:FPAR
                                          188491 TSM:ID
                                          188493 TSM:ID:OK
                                          188495 TSM:UPL
                                          190541 TSM:UPL
                                          192587 TSM:UPL
                                          194633 TSM:UPL
                                          196681 TSM:FPAR
                                          196685 TSM:ID
                                          196687 TSM:ID:OK
                                          196689 TSM:UPL
                                          198735 TSM:UPL
                                          200781 TSM:UPL
                                          202827 TSM:UPL
                                          204875 TSM:FPAR
                                          204879 TSM:ID
                                          204881 TSM:ID:OK
                                          204883 TSM:UPL
                                          206931 TSM:UPL
                                          208979 TSM:UPL
                                          211027 TSM:UPL
                                          213078 TSM:FPAR
                                          213082 TSM:ID
                                          213084 TSM:ID:OK
                                          213086 TSM:UPL
                                          215132 TSM:UPL
                                          217178 TSM:UPL
                                          219224 TSM:UPL
                                          221272 TSM:FPAR
                                          221276 TSM:ID
                                          221278 TSM:ID:OK
                                          221280 TSM:UPL
                                          223326 TSM:UPL
                                          225372 TSM:UPL
                                          225695 TSF:MSG:BC
                                          226281 TSF:MSG:BC
                                          227418 TSM:UPL
                                          229466 TSM:FPAR
                                          229470 TSM:ID
                                          229472 TSM:ID:OK
                                          229474 TSM:UPL
                                          231520 TSM:UPL
                                          233566 TSM:UPL
                                          235612 TSM:UPL
                                          237660 TSM:FPAR
                                          237664 TSM:ID
                                          237666 TSM:ID:OK
                                          237668 TSM:UPL
                                          239714 TSM:UPL
                                          241760 TSM:UPL
                                          243806 TSM:UPL
                                          245854 TSM:FPAR
                                          245858 TSM:ID
                                          245860 TSM:ID:OK
                                          245862 TSM:UPL
                                          247908 TSM:UPL
                                          249954 TSM:UPL
                                          252000 TSM:UPL
                                          254048 TSM:FPAR
                                          254052 TSM:ID
                                          254054 TSM:ID:OK
                                          254056 TSM:UPL
                                          256102 TSM:UPL
                                          258148 TSM:UPL
                                          260194 TSM:UPL
                                          262242 TSM:FPAR
                                          262246 TSM:ID
                                          262248 TSM:ID:OK
                                          262250 TSM:UPL
                                          264296 TSM:UPL
                                          266342 TSM:UPL
                                          268388 TSM:UPL
                                          270436 TSM:FPAR
                                          270440 TSM:ID
                                          270442 TSM:ID:OK
                                          270444 TSM:UPL
                                          272490 TSM:UPL
                                          274536 TSM:UPL
                                          276582 TSM:UPL
                                          278630 TSM:FPAR
                                          278634 TSM:ID
                                          278636 TSM:ID:OK
                                          278638 TSM:UPL
                                          280684 TSM:UPL
                                          282730 TSM:UPL
                                          284776 TSM:UPL
                                          286824 TSM:FPAR
                                          286828 TSM:ID
                                          286830 TSM:ID:OK
                                          286832 TSM:UPL
                                          288878 TSM:UPL
                                          290924 TSM:UPL
                                          292970 TSM:UPL
                                          295018 TSM:FPAR
                                          295022 TSM:ID
                                          295024 TSM:ID:OK
                                          295026 TSM:UPL
                                          297072 TSM:UPL
                                          299118 TSM:UPL
                                          301164 TSM:UPL
                                          303212 TSM:FPAR
                                          303216 TSM:ID
                                          303218 TSM:ID:OK
                                          303220 TSM:UPL
                                          305266 TSM:UPL
                                          307312 TSM:UPL
                                          309358 TSM:UPL
                                          311406 TSM:FPAR
                                          311410 TSM:ID
                                          311412 TSM:ID:OK
                                          311414 TSM:UPL
                                          313460 TSM:UPL
                                          315506 TSM:UPL
                                          317552 TSM:UPL
                                          319600 TSM:FPAR
                                          319604 TSM:ID
                                          319606 TSM:ID:OK
                                          319608 TSM:UPL
                                          321654 TSM:UPL
                                          323700 TSM:UPL
                                          325746 TSM:UPL
                                          327794 TSM:FPAR
                                          327798 TSM:ID
                                          327800 TSM:ID:OK
                                          327802 TSM:UPL
                                          329848 TSM:UPL
                                          331894 TSM:UPL
                                          333940 TSM:UPL
                                          335988 TSM:FPAR
                                          335992 TSM:ID
                                          335994 TSM:ID:OK
                                          335996 TSM:UPL
                                          338042 TSM:UPL
                                          340088 TSM:UPL
                                          342134 TSM:UPL
                                          344182 TSM:FPAR
                                          344186 TSM:ID
                                          344188 TSM:ID:OK
                                          344190 TSM:UPL
                                          346238 TSM:UPL
                                          348286 TSM:UPL
                                          350334 TSM:UPL
                                          352385 TSM:FPAR
                                          352389 TSM:ID
                                          352391 TSM:ID:OK
                                          352393 TSM:UPL
                                          354439 TSM:UPL
                                          356485 TSM:UPL
                                          358531 TSM:UPL
                                          360579 TSM:FPAR
                                          360583 TSM:ID
                                          360585 TSM:ID:OK
                                          360587 TSM:UPL
                                          362633 TSM:UPL
                                          364679 TSM:UPL
                                          366725 TSM:UPL
                                          368773 TSM:FPAR
                                          368777 TSM:ID
                                          368779 TSM:ID:OK
                                          368781 TSM:UPL
                                          370827 TSM:UPL
                                          372873 TSM:UPL
                                          374919 TSM:UPL
                                          376967 TSM:FPAR
                                          376971 TSM:ID
                                          376973 TSM:ID:OK
                                          376975 TSM:UPL
                                          379021 TSM:UPL
                                          381067 TSM:UPL
                                          383113 TSM:UPL
                                          385161 TSM:FPAR
                                          385165 TSM:ID
                                          385167 TSM:ID:OK
                                          385169 TSM:UPL
                                          387215 TSM:UPL
                                          389261 TSM:UPL
                                          391307 TSM:UPL
                                          393355 TSM:FPAR
                                          393359 TSM:ID
                                          393361 TSM:ID:OK
                                          393363 TSM:UPL
                                          395409 TSM:UPL
                                          397455 TSM:UPL
                                          399501 TSM:UPL
                                          401549 TSM:FPAR
                                          401553 TSM:ID
                                          401555 TSM:ID:OK
                                          401557 TSM:UPL
                                          403603 TSM:UPL
                                          405649 TSM:UPL
                                          407695 TSM:UPL
                                          409743 TSM:FPAR
                                          409747 TSM:ID
                                          409749 TSM:ID:OK
                                          409751 TSM:UPL
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Mark-Swift I guess because of MY_PARENT_NODE_IS_STATIC which prevents the use of an alternative parent.
