  3. Battery sensor and re-connecting to gateway
24 Posts 6 Posters 9.1k Views 4 Watching
  • Mark SwiftM Mark Swift
    @tekka I'm using the latest snapshot on one of my battery sensors and can see if it can't connect, it doesn't sleep and the debug shows a rapid number of connection attempts. I'd like to know if the sensor will eventually sleep if it cannot successfully connect, and what the default timeout is?
    tekkaT
    tekkaT
    tekka
    @Mark-Swift Please post your sketch & full debug log. Thanks
    • Mark SwiftM
      Mark SwiftM
      Mark Swift
      @tekka I don't think there's an issue.
      I'm simply asking what the logic is behind the reconnection logic on sleeping sensors, how long is the timeout for example (I'm conscious of battery drain for nodes having issues connecting).
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        @Mark-Swift No, this sounds like an issue - a rapid number of connection attempts is unusual, that's why I'm interested in your sketch/debug log.
        To answer your questions: In the latest dev version the node will try to reconnect with a 10sec timeout (if sleeping time > 10sec, this can be changed via MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS) before sleeping - if time is left.
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          wrote on last edited by Mark Swift
          @tekka it's been a while but I never resolved this... If I test by changing the parent node ID to a fake one, it just tried to connect forever, thus draining the battery...
          Sketch:
            REVISION HISTORY
            Created by Mark Swift
            V1.2 - Added sleep time to force daily update
            V1.3 - Deactivate pullup on setup and added old_value logic
            V1.4 - Added daily wakeup to sleep
            V1.5 - Code cleanup
          //*** EXTERNAL LIBRARIES **********************************
          #include <Vcc.h>
          //*** MYSENSORS *******************************************
          // Enable debug prints
          // Lower serial speed if using 1Mhz clock
          // #define MY_BAUD_RATE 9600
          #define MY_NODE_ID 4
          #define MY_PARENT_NODE_ID 1 // AUTO
          // #define MY_RADIO_RFM69
          // Override RF24L01 channel number
          // #define MY_RF24_CHANNEL 125
          // Override RF24L01 module PA level
          // #define MY_RF24_PA_LEVEL RF24_PA_LOW
          // Override RF24L01 datarate
          // #define MY_RF24_DATARATE RF24_250KBPS
          // *** SKETCH CONFIG **************************************
          #define SKETCH_NAME "Door Sensor"
          #define SKETCH_MAJOR_VER "1"
          #define SKETCH_MINOR_VER "5"
          // Define the sensor child IDs
          #define CHILD_ID1 1 // Switch
          #define CHILD_ID2 2 // Battery voltage
          #define CHILD_ID3 3 // Battery percent
          // Define the message formats
          MyMessage msg(CHILD_ID1, V_TRIPPED);
          MyMessage msg2(CHILD_ID2, V_CUSTOM);
          MyMessage msg3(CHILD_ID3, V_CUSTOM);
          // *** SENSORS CONFIG *************************************
          // Digital I/O pin for button or reed switch
          #define PRIMARY_BUTTON_PIN 3
          // Debounce using a small sleep
          #define DEBOUNCE_SLEEP 5
          // Sleep timer in milliseconds
          #define SLEEP_IN_MS 86400000
          // Store the old value for comparison
          int old_value = -1;
          // Minimum expected vcc level, in volts (2xAA alkaline)
          const float vcc_min = 2.0 * 0.9;
          // Maximum expected vcc level, in volts (2xAA alkaline)
          const float vcc_max = 2.0 * 1.5;
          // Measured vcc by multimeter divided by reported vcc
          const float vcc_correction = 2.88 / 2.82;
          Vcc vcc(vcc_correction);
          // *** BEGIN **********************************************
            // Setup the contact sensor
            // Activate or deactivate the internal pull-up - high if using internal resistor or low if using external
            digitalWrite(PRIMARY_BUTTON_PIN, LOW);
            // Register all sensors to the gateway
            present(CHILD_ID1, S_DOOR);
            present(CHILD_ID2, S_CUSTOM);
            present(CHILD_ID3, S_CUSTOM);
            // Debouce using sleep
            sleep(DEBOUNCE_SLEEP);
            int value = digitalRead(PRIMARY_BUTTON_PIN);
            // If value has changed send the updated value
            if (value != old_value) {
              send(msg.set(value == HIGH ? 0 : 1));
              old_value = value;
            // Read battery voltage
            float battery_voltage = vcc.Read_Volts();
            // Calculate battery percentage
            float battery_percent = vcc.Read_Perc(vcc_min, vcc_max);
          #ifdef MY_DEBUG
            Serial.print("Battery = ");
            Serial.print(battery_voltage);
            Serial.println(" Volts");
            Serial.print(battery_percent);
            Serial.println("%");
            // Send battery readings
            send(msg2.set(battery_voltage, 2));
            send(msg3.set(battery_percent, 1));
            sendBatteryLevel(battery_percent);
            // Sleep until either interupt change or timer reaches zero
            smartSleep(PRIMARY_BUTTON_PIN - 2, CHANGE, SLEEP_IN_MS);
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            Debug:
            0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
            4 TSM:INIT
            6 TSF:WUR:MS=0
            14 TSM:INIT:TSP OK
            16 TSM:INIT:STATID=4
            18 TSF:SID:OK,ID=4
            20 TSM:FPAR
            22 TSM:FPAR:STATP=1
            24 TSM:ID
            24 TSM:ID:OK
            26 TSM:UPL
            63 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            2072 TSM:UPL
            2109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            4118 TSM:UPL
            4155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            6164 TSM:UPL
            6201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            8210 !TSM:UPL:FAIL
            8212 TSM:FPAR
            8212 TSM:FPAR:STATP=1
            8214 TSM:ID
            8216 TSM:ID:OK
            8218 TSM:UPL
            8255 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            10264 TSM:UPL
            10301 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            12310 TSM:UPL
            12347 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            14356 TSM:UPL
            14393 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            16402 !TSM:UPL:FAIL
            16404 TSM:FPAR
            16404 TSM:FPAR:STATP=1
            16408 TSM:ID
            16410 TSM:ID:OK
            16410 TSM:UPL
            16449 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            18458 TSM:UPL
            18495 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            20504 TSM:UPL
            20541 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            22550 TSM:UPL
            22587 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            24596 !TSM:UPL:FAIL
            24598 TSM:FPAR
            24598 TSM:FPAR:STATP=1
            24602 TSM:ID
            24604 TSM:ID:OK
            24604 TSM:UPL
            24643 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            26652 TSM:UPL
            26689 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            28698 TSM:UPL
            28735 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            30744 TSM:UPL
            30781 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            32790 !TSM:UPL:FAIL
            32792 TSM:FPAR
            32792 TSM:FPAR:STATP=1
            32796 TSM:ID
            32798 TSM:ID:OK
            32798 TSM:UPL
            32837 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            34846 TSM:UPL
            34883 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            36892 TSM:UPL
            36929 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            38938 TSM:UPL
            38975 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            40984 !TSM:UPL:FAIL
            40986 TSM:FPAR
            40986 TSM:FPAR:STATP=1
            40990 TSM:ID
            40992 TSM:ID:OK
            40992 TSM:UPL
            41031 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            43040 TSM:UPL
            43077 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            45086 TSM:UPL
            45123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            47132 TSM:UPL
            47169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            49178 !TSM:UPL:FAIL
            49180 TSM:FPAR
            49180 TSM:FPAR:STATP=1
            49184 TSM:ID
            49186 TSM:ID:OK
            49186 TSM:UPL
            49225 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            51234 TSM:UPL
            51271 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            53280 TSM:UPL
            53317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            55326 TSM:UPL
            55363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            57372 !TSM:UPL:FAIL
            57374 TSM:FPAR
            57374 TSM:FPAR:STATP=1
            57378 TSM:ID
            57380 TSM:ID:OK
            57380 TSM:UPL
            57419 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            59428 TSM:UPL
            59465 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            61474 TSM:UPL
            61511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            63520 TSM:UPL
            63557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            65566 !TSM:UPL:FAIL
            65568 TSM:FPAR
            65568 TSM:FPAR:STATP=1
            65572 TSM:ID
            65574 TSM:ID:OK
            65574 TSM:UPL
            65613 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            67624 TSM:UPL
            67661 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            69672 TSM:UPL
            69709 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            71720 TSM:UPL
            71757 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            73768 !TSM:UPL:FAIL
            73771 TSM:FPAR
            73771 TSM:FPAR:STATP=1
            73775 TSM:ID
            73777 TSM:ID:OK
            73777 TSM:UPL
            73816 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            75825 TSM:UPL
            75862 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            77871 TSM:UPL
            77907 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            79917 TSM:UPL
            79953 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            81963 !TSM:UPL:FAIL
            81965 TSM:FPAR
            81965 TSM:FPAR:STATP=1
            81969 TSM:ID
            81971 TSM:ID:OK
            81971 TSM:UPL
            82010 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            84019 TSM:UPL
            84056 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            86065 TSM:UPL
            86102 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            88111 TSM:UPL
            88147 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            90157 !TSM:UPL:FAIL
            90159 TSM:FPAR
            90159 TSM:FPAR:STATP=1
            90163 TSM:ID
            90165 TSM:ID:OK
            90165 TSM:UPL
            90204 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            92213 TSM:UPL
            92250 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            94259 TSM:UPL
            94296 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            96305 TSM:UPL
            96342 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            98351 !TSM:UPL:FAIL
            98353 TSM:FPAR
            98353 TSM:FPAR:STATP=1
            98357 TSM:ID
            98359 TSM:ID:OK
            98359 TSM:UPL
            98398 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            100407 TSM:UPL
            100444 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            102453 TSM:UPL
            102490 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            104499 TSM:UPL
            104536 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            106545 !TSM:UPL:FAIL
            106547 TSM:FPAR
            106549 TSM:FPAR:STATP=1
            106551 TSM:ID
            106553 TSM:ID:OK
            106555 TSM:UPL
            106592 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            108601 TSM:UPL
            108638 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            110647 TSM:UPL
            110684 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            112693 TSM:UPL
            112730 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            114739 !TSM:UPL:FAIL
            114741 TSM:FPAR
            114743 TSM:FPAR:STATP=1
            114745 TSM:ID
            114747 TSM:ID:OK
            114749 TSM:UPL
            114786 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            116795 TSM:UPL
            116832 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            118841 TSM:UPL
            118878 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            120887 TSM:UPL
            120924 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            122933 !TSM:UPL:FAIL
            122935 TSM:FPAR
            122937 TSM:FPAR:STATP=1
            122939 TSM:ID
            122941 TSM:ID:OK
            122943 TSM:UPL
            122980 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            124989 TSM:UPL
            125026 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            127035 TSM:UPL
            127072 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            129081 TSM:UPL
            129118 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            131127 !TSM:UPL:FAIL
            131129 TSM:FPAR
            131131 TSM:FPAR:STATP=1
            131133 TSM:ID
            131135 TSM:ID:OK
            131137 TSM:UPL
            131174 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            133183 TSM:UPL
            133220 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            135229 TSM:UPL
            135266 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            137275 TSM:UPL
            137312 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            139321 !TSM:UPL:FAIL
            139323 TSM:FPAR
            139325 TSM:FPAR:STATP=1
            139327 TSM:ID
            139329 TSM:ID:OK
            139331 TSM:UPL
            139368 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            141377 TSM:UPL
            141414 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            143423 TSM:UPL
            143460 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            145469 TSM:UPL
            145506 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            147515 !TSM:UPL:FAIL
            147517 TSM:FPAR
            147519 TSM:FPAR:STATP=1
            147521 TSM:ID
            147523 TSM:ID:OK
            147525 TSM:UPL
            147562 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            149571 TSM:UPL
            149608 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            151617 TSM:UPL
            151654 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            153663 TSM:UPL
            153700 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            155709 !TSM:UPL:FAIL
            155711 TSM:FPAR
            155713 TSM:FPAR:STATP=1
            155715 TSM:ID
            155717 TSM:ID:OK
            155719 TSM:UPL
            155756 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            157765 TSM:UPL
            157802 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            159811 TSM:UPL
            159848 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            161857 TSM:UPL
            161894 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            163903 !TSM:UPL:FAIL
            163905 TSM:FPAR
            163907 TSM:FPAR:STATP=1
            163909 TSM:ID
            163911 TSM:ID:OK
            163913 TSM:UPL
            163950 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            165959 TSM:UPL
            165996 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            168005 TSM:UPL
            168042 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            170051 TSM:UPL
            170088 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            172097 !TSM:UPL:FAIL
            172099 TSM:FPAR
            172101 TSM:FPAR:STATP=1
            172103 TSM:ID
            172105 TSM:ID:OK
            172107 TSM:UPL
            172144 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            174153 TSM:UPL
            174190 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            176199 TSM:UPL
            176236 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            178245 TSM:UPL
            178282 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            180291 !TSM:UPL:FAIL
            180293 TSM:FPAR
            180295 TSM:FPAR:STATP=1
            180297 TSM:ID
            180299 TSM:ID:OK
            180301 TSM:UPL
            180338 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            182347 TSM:UPL
            182384 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            184393 TSM:UPL
            184430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            186439 TSM:UPL
            186476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            188485 !TSM:UPL:FAIL
            188487 TSM:FPAR
            188489 TSM:FPAR:STATP=1
            188491 TSM:ID
            188493 TSM:ID:OK
            188495 TSM:UPL
            188532 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            190541 TSM:UPL
            190578 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            192587 TSM:UPL
            192624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            194633 TSM:UPL
            194670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            196679 !TSM:UPL:FAIL
            196681 TSM:FPAR
            196683 TSM:FPAR:STATP=1
            196685 TSM:ID
            196687 TSM:ID:OK
            196689 TSM:UPL
            196726 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            198735 TSM:UPL
            198772 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            200781 TSM:UPL
            200818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            202827 TSM:UPL
            202864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            204873 !TSM:UPL:FAIL
            204875 TSM:FPAR
            204877 TSM:FPAR:STATP=1
            204879 TSM:ID
            204881 TSM:ID:OK
            204883 TSM:UPL
            204920 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            206931 TSM:UPL
            206968 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            208979 TSM:UPL
            209016 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            211027 TSM:UPL
            211064 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            213075 !TSM:UPL:FAIL
            213078 TSM:FPAR
            213080 TSM:FPAR:STATP=1
            213082 TSM:ID
            213084 TSM:ID:OK
            213086 TSM:UPL
            213123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            215132 TSM:UPL
            215169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            217178 TSM:UPL
            217214 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            219224 TSM:UPL
            219260 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            221270 !TSM:UPL:FAIL
            221272 TSM:FPAR
            221274 TSM:FPAR:STATP=1
            221276 TSM:ID
            221278 TSM:ID:OK
            221280 TSM:UPL
            221317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            223326 TSM:UPL
            223363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            225372 TSM:UPL
            225409 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            225689 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
            225695 TSF:MSG:BC
            226275 TSF:MSG:READ,0-3-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
            226281 TSF:MSG:BC
            227418 TSM:UPL
            227454 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            229464 !TSM:UPL:FAIL
            229466 TSM:FPAR
            229468 TSM:FPAR:STATP=1
            229470 TSM:ID
            229472 TSM:ID:OK
            229474 TSM:UPL
            229511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            231520 TSM:UPL
            231557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            233566 TSM:UPL
            233603 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            235612 TSM:UPL
            235649 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            237658 !TSM:UPL:FAIL
            237660 TSM:FPAR
            237662 TSM:FPAR:STATP=1
            237664 TSM:ID
            237666 TSM:ID:OK
            237668 TSM:UPL
            237705 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            239714 TSM:UPL
            239751 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            241760 TSM:UPL
            241797 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            243806 TSM:UPL
            243843 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            245852 !TSM:UPL:FAIL
            245854 TSM:FPAR
            245856 TSM:FPAR:STATP=1
            245858 TSM:ID
            245860 TSM:ID:OK
            245862 TSM:UPL
            245899 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            247908 TSM:UPL
            247945 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            249954 TSM:UPL
            249991 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            252000 TSM:UPL
            252037 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            254046 !TSM:UPL:FAIL
            254048 TSM:FPAR
            254050 TSM:FPAR:STATP=1
            254052 TSM:ID
            254054 TSM:ID:OK
            254056 TSM:UPL
            254093 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            256102 TSM:UPL
            256139 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            258148 TSM:UPL
            258185 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            260194 TSM:UPL
            260231 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            262240 !TSM:UPL:FAIL
            262242 TSM:FPAR
            262244 TSM:FPAR:STATP=1
            262246 TSM:ID
            262248 TSM:ID:OK
            262250 TSM:UPL
            262287 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            264296 TSM:UPL
            264333 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            266342 TSM:UPL
            266379 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            268388 TSM:UPL
            268425 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            270434 !TSM:UPL:FAIL
            270436 TSM:FPAR
            270438 TSM:FPAR:STATP=1
            270440 TSM:ID
            270442 TSM:ID:OK
            270444 TSM:UPL
            270481 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            272490 TSM:UPL
            272527 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            274536 TSM:UPL
            274573 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            276582 TSM:UPL
            276619 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            278628 !TSM:UPL:FAIL
            278630 TSM:FPAR
            278632 TSM:FPAR:STATP=1
            278634 TSM:ID
            278636 TSM:ID:OK
            278638 TSM:UPL
            278675 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            280684 TSM:UPL
            280721 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            282730 TSM:UPL
            282767 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            284776 TSM:UPL
            284813 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            286822 !TSM:UPL:FAIL
            286824 TSM:FPAR
            286826 TSM:FPAR:STATP=1
            286828 TSM:ID
            286830 TSM:ID:OK
            286832 TSM:UPL
            286869 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            288878 TSM:UPL
            288915 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            290924 TSM:UPL
            290961 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            292970 TSM:UPL
            293007 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            295016 !TSM:UPL:FAIL
            295018 TSM:FPAR
            295020 TSM:FPAR:STATP=1
            295022 TSM:ID
            295024 TSM:ID:OK
            295026 TSM:UPL
            295063 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            297072 TSM:UPL
            297109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            299118 TSM:UPL
            299155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            301164 TSM:UPL
            301201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            303210 !TSM:UPL:FAIL
            303212 TSM:FPAR
            303214 TSM:FPAR:STATP=1
            303216 TSM:ID
            303218 TSM:ID:OK
            303220 TSM:UPL
            303257 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            305266 TSM:UPL
            305303 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            307312 TSM:UPL
            307349 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            309358 TSM:UPL
            309395 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            311404 !TSM:UPL:FAIL
            311406 TSM:FPAR
            311408 TSM:FPAR:STATP=1
            311410 TSM:ID
            311412 TSM:ID:OK
            311414 TSM:UPL
            311451 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            313460 TSM:UPL
            313497 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            315506 TSM:UPL
            315543 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            317552 TSM:UPL
            317589 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            319598 !TSM:UPL:FAIL
            319600 TSM:FPAR
            319602 TSM:FPAR:STATP=1
            319604 TSM:ID
            319606 TSM:ID:OK
            319608 TSM:UPL
            319645 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            321654 TSM:UPL
            321691 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            323700 TSM:UPL
            323737 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            325746 TSM:UPL
            325783 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            327792 !TSM:UPL:FAIL
            327794 TSM:FPAR
            327796 TSM:FPAR:STATP=1
            327798 TSM:ID
            327800 TSM:ID:OK
            327802 TSM:UPL
            327839 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            329848 TSM:UPL
            329885 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            331894 TSM:UPL
            331931 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            333940 TSM:UPL
            333977 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            335986 !TSM:UPL:FAIL
            335988 TSM:FPAR
            335990 TSM:FPAR:STATP=1
            335992 TSM:ID
            335994 TSM:ID:OK
            335996 TSM:UPL
            336033 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            338042 TSM:UPL
            338079 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            340088 TSM:UPL
            340125 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            342134 TSM:UPL
            342171 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            344180 !TSM:UPL:FAIL
            344182 TSM:FPAR
            344184 TSM:FPAR:STATP=1
            344186 TSM:ID
            344188 TSM:ID:OK
            344190 TSM:UPL
            344227 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            346238 TSM:UPL
            346275 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            348286 TSM:UPL
            348323 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            350334 TSM:UPL
            350371 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            352382 !TSM:UPL:FAIL
            352385 TSM:FPAR
            352387 TSM:FPAR:STATP=1
            352389 TSM:ID
            352391 TSM:ID:OK
            352393 TSM:UPL
            352430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            354439 TSM:UPL
            354476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            356485 TSM:UPL
            356521 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            358531 TSM:UPL
            358567 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            360577 !TSM:UPL:FAIL
            360579 TSM:FPAR
            360581 TSM:FPAR:STATP=1
            360583 TSM:ID
            360585 TSM:ID:OK
            360587 TSM:UPL
            360624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            362633 TSM:UPL
            362670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            364679 TSM:UPL
            364716 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            366725 TSM:UPL
            366761 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            368771 !TSM:UPL:FAIL
            368773 TSM:FPAR
            368775 TSM:FPAR:STATP=1
            368777 TSM:ID
            368779 TSM:ID:OK
            368781 TSM:UPL
            368818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            370827 TSM:UPL
            370864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            372873 TSM:UPL
            372910 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            374919 TSM:UPL
            374956 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            376965 !TSM:UPL:FAIL
            376967 TSM:FPAR
            376969 TSM:FPAR:STATP=1
            376971 TSM:ID
            376973 TSM:ID:OK
            376975 TSM:UPL
            377012 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
            379021 TSM:UPL
            379058 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
            381067 TSM:UPL
            381104 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
            383113 TSM:UPL
            383150 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
            385159 !TSM:UPL:FAIL
            385161 TSM:FPAR
            385163 TSM:FPAR:STATP=1
            385165 TSM:ID
            385167 TSM:ID:OK
            385169 TSM:UPL
            385206 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
            387215 TSM:UPL
            387252 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
            389261 TSM:UPL
            389298 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
            391307 TSM:UPL
            391344 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
            393353 !TSM:UPL:FAIL
            393355 TSM:FPAR
            393357 TSM:FPAR:STATP=1
            393359 TSM:ID
            393361 TSM:ID:OK
            393363 TSM:UPL
            393400 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
            395409 TSM:UPL
            395446 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
            397455 TSM:UPL
            397492 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
            399501 TSM:UPL
            399538 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
            401547 !TSM:UPL:FAIL
            401549 TSM:FPAR
            401551 TSM:FPAR:STATP=1
            401553 TSM:ID
            401555 TSM:ID:OK
            401557 TSM:UPL
            401594 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
            403603 TSM:UPL
            403640 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
            405649 TSM:UPL
            405686 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
            407695 TSM:UPL
            407732 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
            409741 !TSM:UPL:FAIL
            409743 TSM:FPAR
            409745 TSM:FPAR:STATP=1
            409747 TSM:ID
            409749 TSM:ID:OK
            409751 TSM:UPL
            409788 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
              Debug:
              4 TSM:INIT
              6 TSF:WUR:MS=0
              14 TSM:INIT:TSP OK
              18 TSF:SID:OK,ID=4
              20 TSM:FPAR
              22 TSM:FPAR:STATP=1
              24 TSM:ID
              24 TSM:ID:OK
              26 TSM:UPL
              2072 TSM:UPL
              4118 TSM:UPL
              6164 TSM:UPL
              8210 !TSM:UPL:FAIL
              8212 TSM:FPAR
              8214 TSM:ID
              8216 TSM:ID:OK
              8218 TSM:UPL
              10264 TSM:UPL
              12310 TSM:UPL
              14356 TSM:UPL
              16402 !TSM:UPL:FAIL
              16404 TSM:FPAR
              16408 TSM:ID
              16410 TSM:ID:OK
              16410 TSM:UPL
              18458 TSM:UPL
              20504 TSM:UPL
              22550 TSM:UPL
              24596 !TSM:UPL:FAIL
              24598 TSM:FPAR
              24602 TSM:ID
              24604 TSM:ID:OK
              24604 TSM:UPL
              26652 TSM:UPL
              28698 TSM:UPL
              30744 TSM:UPL
              32790 !TSM:UPL:FAIL
              32792 TSM:FPAR
              32796 TSM:ID
              32798 TSM:ID:OK
              32798 TSM:UPL
              34846 TSM:UPL
              36892 TSM:UPL
              38938 TSM:UPL
              40984 !TSM:UPL:FAIL
              40986 TSM:FPAR
              40990 TSM:ID
              40992 TSM:ID:OK
              40992 TSM:UPL
              43040 TSM:UPL
              45086 TSM:UPL
              47132 TSM:UPL
              49178 !TSM:UPL:FAIL
              49180 TSM:FPAR
              49184 TSM:ID
              49186 TSM:ID:OK
              49186 TSM:UPL
              51234 TSM:UPL
              53280 TSM:UPL
              55326 TSM:UPL
              57372 !TSM:UPL:FAIL
              57374 TSM:FPAR
              57378 TSM:ID
              57380 TSM:ID:OK
              57380 TSM:UPL
              59428 TSM:UPL
              61474 TSM:UPL
              63520 TSM:UPL
              65566 !TSM:UPL:FAIL
              65568 TSM:FPAR
              65572 TSM:ID
              65574 TSM:ID:OK
              65574 TSM:UPL
              67624 TSM:UPL
              69672 TSM:UPL
              71720 TSM:UPL
              73768 !TSM:UPL:FAIL
              73771 TSM:FPAR
              73775 TSM:ID
              73777 TSM:ID:OK
              73777 TSM:UPL
              75825 TSM:UPL
              77871 TSM:UPL
              79917 TSM:UPL
              81963 !TSM:UPL:FAIL
              81965 TSM:FPAR
              81969 TSM:ID
              81971 TSM:ID:OK
              81971 TSM:UPL
              84019 TSM:UPL
              86065 TSM:UPL
              88111 TSM:UPL
              90157 !TSM:UPL:FAIL
              90159 TSM:FPAR
              90163 TSM:ID
              90165 TSM:ID:OK
              90165 TSM:UPL
              92213 TSM:UPL
              94259 TSM:UPL
              96305 TSM:UPL
              98351 !TSM:UPL:FAIL
              98353 TSM:FPAR
              98357 TSM:ID
              98359 TSM:ID:OK
              98359 TSM:UPL
              100407 TSM:UPL
              102453 TSM:UPL
              104499 TSM:UPL
              106547 TSM:FPAR
              106551 TSM:ID
              106553 TSM:ID:OK
              106555 TSM:UPL
              108601 TSM:UPL
              110647 TSM:UPL
              112693 TSM:UPL
              114741 TSM:FPAR
              114745 TSM:ID
              114747 TSM:ID:OK
              114749 TSM:UPL
              116795 TSM:UPL
              118841 TSM:UPL
              120887 TSM:UPL
              122935 TSM:FPAR
              122939 TSM:ID
              122941 TSM:ID:OK
              122943 TSM:UPL
              124989 TSM:UPL
              127035 TSM:UPL
              129081 TSM:UPL
              131129 TSM:FPAR
              131133 TSM:ID
              131135 TSM:ID:OK
              131137 TSM:UPL
              133183 TSM:UPL
              135229 TSM:UPL
              137275 TSM:UPL
              139323 TSM:FPAR
              139327 TSM:ID
              139329 TSM:ID:OK
              139331 TSM:UPL
              141377 TSM:UPL
              143423 TSM:UPL
              145469 TSM:UPL
              147517 TSM:FPAR
              147521 TSM:ID
              147523 TSM:ID:OK
              147525 TSM:UPL
              149571 TSM:UPL
              151617 TSM:UPL
              153663 TSM:UPL
              155711 TSM:FPAR
              155715 TSM:ID
              155717 TSM:ID:OK
              155719 TSM:UPL
              157765 TSM:UPL
              159811 TSM:UPL
              161857 TSM:UPL
              163905 TSM:FPAR
              163909 TSM:ID
              163911 TSM:ID:OK
              163913 TSM:UPL
              165959 TSM:UPL
              168005 TSM:UPL
              170051 TSM:UPL
              172099 TSM:FPAR
              172103 TSM:ID
              172105 TSM:ID:OK
              172107 TSM:UPL
              174153 TSM:UPL
              176199 TSM:UPL
              178245 TSM:UPL
              180293 TSM:FPAR
              180297 TSM:ID
              180299 TSM:ID:OK
              180301 TSM:UPL
              182347 TSM:UPL
              184393 TSM:UPL
              186439 TSM:UPL
              188487 TSM:FPAR
              188491 TSM:ID
              188493 TSM:ID:OK
              188495 TSM:UPL
              190541 TSM:UPL
              192587 TSM:UPL
              194633 TSM:UPL
              196681 TSM:FPAR
              196685 TSM:ID
              196687 TSM:ID:OK
              196689 TSM:UPL
              198735 TSM:UPL
              200781 TSM:UPL
              202827 TSM:UPL
              204875 TSM:FPAR
              204879 TSM:ID
              204881 TSM:ID:OK
              204883 TSM:UPL
              206931 TSM:UPL
              208979 TSM:UPL
              211027 TSM:UPL
              213078 TSM:FPAR
              213082 TSM:ID
              213084 TSM:ID:OK
              213086 TSM:UPL
              215132 TSM:UPL
              217178 TSM:UPL
              219224 TSM:UPL
              221272 TSM:FPAR
              221276 TSM:ID
              221278 TSM:ID:OK
              221280 TSM:UPL
              223326 TSM:UPL
              225372 TSM:UPL
              225695 TSF:MSG:BC
              226281 TSF:MSG:BC
              227418 TSM:UPL
              229466 TSM:FPAR
              229470 TSM:ID
              229472 TSM:ID:OK
              229474 TSM:UPL
              231520 TSM:UPL
              233566 TSM:UPL
              235612 TSM:UPL
              237660 TSM:FPAR
              237664 TSM:ID
              237666 TSM:ID:OK
              237668 TSM:UPL
              239714 TSM:UPL
              241760 TSM:UPL
              243806 TSM:UPL
              245854 TSM:FPAR
              245858 TSM:ID
              245860 TSM:ID:OK
              245862 TSM:UPL
              247908 TSM:UPL
              249954 TSM:UPL
              252000 TSM:UPL
              254048 TSM:FPAR
              254052 TSM:ID
              254054 TSM:ID:OK
              254056 TSM:UPL
              256102 TSM:UPL
              258148 TSM:UPL
              260194 TSM:UPL
              262242 TSM:FPAR
              262246 TSM:ID
              262248 TSM:ID:OK
              262250 TSM:UPL
              264296 TSM:UPL
              266342 TSM:UPL
              268388 TSM:UPL
              270436 TSM:FPAR
              270440 TSM:ID
              270442 TSM:ID:OK
              270444 TSM:UPL
              272490 TSM:UPL
              274536 TSM:UPL
              276582 TSM:UPL
              278630 TSM:FPAR
              278634 TSM:ID
              278636 TSM:ID:OK
              278638 TSM:UPL
              280684 TSM:UPL
              282730 TSM:UPL
              284776 TSM:UPL
              286824 TSM:FPAR
              286828 TSM:ID
              286830 TSM:ID:OK
              286832 TSM:UPL
              288878 TSM:UPL
              290924 TSM:UPL
              292970 TSM:UPL
              295018 TSM:FPAR
              295022 TSM:ID
              295024 TSM:ID:OK
              295026 TSM:UPL
              297072 TSM:UPL
              299118 TSM:UPL
              301164 TSM:UPL
              303212 TSM:FPAR
              303216 TSM:ID
              303218 TSM:ID:OK
              303220 TSM:UPL
              305266 TSM:UPL
              307312 TSM:UPL
              309358 TSM:UPL
              311406 TSM:FPAR
              311410 TSM:ID
              311412 TSM:ID:OK
              311414 TSM:UPL
              313460 TSM:UPL
              315506 TSM:UPL
              317552 TSM:UPL
              319600 TSM:FPAR
              319604 TSM:ID
              319606 TSM:ID:OK
              319608 TSM:UPL
              321654 TSM:UPL
              323700 TSM:UPL
              325746 TSM:UPL
              327794 TSM:FPAR
              327798 TSM:ID
              327800 TSM:ID:OK
              327802 TSM:UPL
              329848 TSM:UPL
              331894 TSM:UPL
              333940 TSM:UPL
              335988 TSM:FPAR
              335992 TSM:ID
              335994 TSM:ID:OK
              335996 TSM:UPL
              338042 TSM:UPL
              340088 TSM:UPL
              342134 TSM:UPL
              344182 TSM:FPAR
              344186 TSM:ID
              344188 TSM:ID:OK
              344190 TSM:UPL
              346238 TSM:UPL
              348286 TSM:UPL
              350334 TSM:UPL
              352385 TSM:FPAR
              352389 TSM:ID
              352391 TSM:ID:OK
              352393 TSM:UPL
              354439 TSM:UPL
              356485 TSM:UPL
              358531 TSM:UPL
              360579 TSM:FPAR
              360583 TSM:ID
              360585 TSM:ID:OK
              360587 TSM:UPL
              362633 TSM:UPL
              364679 TSM:UPL
              366725 TSM:UPL
              368773 TSM:FPAR
              368777 TSM:ID
              368779 TSM:ID:OK
              368781 TSM:UPL
              370827 TSM:UPL
              372873 TSM:UPL
              374919 TSM:UPL
              376967 TSM:FPAR
              376971 TSM:ID
              376973 TSM:ID:OK
              376975 TSM:UPL
              379021 TSM:UPL
              381067 TSM:UPL
              383113 TSM:UPL
              385161 TSM:FPAR
              385165 TSM:ID
              385167 TSM:ID:OK
              385169 TSM:UPL
              387215 TSM:UPL
              389261 TSM:UPL
              391307 TSM:UPL
              393355 TSM:FPAR
              393359 TSM:ID
              393361 TSM:ID:OK
              393363 TSM:UPL
              395409 TSM:UPL
              397455 TSM:UPL
              399501 TSM:UPL
              401549 TSM:FPAR
              401553 TSM:ID
              401555 TSM:ID:OK
              401557 TSM:UPL
              403603 TSM:UPL
              405649 TSM:UPL
              407695 TSM:UPL
              409743 TSM:FPAR
              409747 TSM:ID
              409749 TSM:ID:OK
              409751 TSM:UPL
              tekkaT
              tekkaT
              tekka
              @Mark-Swift I guess because of MY_PARENT_NODE_IS_STATIC which prevents the use of an alternative parent.
              • Mark SwiftM
                Mark SwiftM
                Mark Swift
                @tekka I guessed that, I thought however that you'd mentioned it would timeout, and try again later? As it stands it appears it'll keep trying until the battery is dead?
                If nothing else I just want to clear up the behaviour so I fully understand it.
                Mark
                  Mark
                  tekkaT
                  tekkaT
                  tekka
                  #22
                  @Mark-Swift it does timeout, but for that you have to set MY_TRANSPORT_WAIT_READY_MS > 0. This ensures, that loop() will be entered after the timeout if the connection could not be established.
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    @tekka thank you, so if I
                    #define MY_TRANSPORT_WAIT_READY_MS 60000
                    Am I right in thinking that my node will enter the loop after it tries to connect to a parent for 60 seconds and fails? (In my case it'd then sleep until the next interrupt, when I guess it would then try again for 60 seconds...).
                    I really appreciate your help getting my head around this :)
                      tekkaT
                      tekkaT
                      tekka
                      @Mark-Swift Almost :)
                      applies only when the node starts, i.e. before entering loop(). Once you are in loop() and you put the node to sleep
                      #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 10000
                      defines how long the node will try to establish a connection before going to sleep, default is 10s. Please have a look here for additional information.
                      12.5k
