  3. Humidity+Relay with button node
12 Posts 4 Posters 4.1k Views 3 Watching
  • theckoT Offline
    theckoT Offline
    thecko
    i started playing with Mysensors and Arduino and managed to make a Gateway and the relay/humidity node with the following code:
    #include <DHT.h>
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define NODE_ID 1
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_RELAY 2
    #define RELAY_PIN 3
    #define HUMIDITY_SENSOR_DIGITAL_PIN 2
    //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      gw.sendSketchInfo("Combo", "1.0");
      gw.present(CHILD_ID_RELAY, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      digitalWrite(RELAY_PIN, gw.loadState(1) ? RELAY_ON : RELAY_OFF);
      gw.process();
      if (isnan(temperature))
      else if (temperature != lastTemp)
        lastTemp = temperature;
        if (!metric)
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity))
      } else if (humidity != lastHum)
        lastHum = humidity;
        Serial.print("H: ");
        Serial.println(humidity);
      if (message.type == V_LIGHT)
        digitalWrite(RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
        gw.saveState(1, message.getBool());
        Serial.print(message.sensor);
    Since this is copy/pasted from the forum, i am wondering if it is possible to incorporate a hardware button to control the relay. I tried adding code from the Relay with actuator example, but i failed to make it work, i can only turn the relay on with the button. I am using Domoticz as a controller. Any help would be welcome.
    Daniel OliveiraD T 2 Replies Last reply
    • theckoT thecko
      #include <DHT.h>
      #define NODE_ID 1
      #define RELAY_PIN 3
      MyHwATMega328 hw;
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.process();
          if (!metric)
          lastHum = humidity;
      Daniel OliveiraD Offline
      Daniel Oliveira
      Hi @thecko,
      To answer you, yes it is totally possible. But to be able to help you more can you please share your sketch instead? The one that you added the relay code, with that we can help you find what is wrong.
      Regards
      MySensors rules my home :)
      • theckoT Offline
        theckoT Offline
        thecko
        Thee sketch i used is:
        #include <DHT.h>
        #include <Bounce2.h>
        #define NODE_ID 1
        #define RELAY_PIN 3
        #define BUTTON_PIN 4
        MyHwATMega328 hw;
        Bounce debouncer = Bounce();
        int oldValue=0;
        bool state;
        MyMessage msg(CHILD_ID_RELAY,V_LIGHT);
        DHT dht;
        float lastTemp;
        float lastHum;
          pinMode(BUTTON_PIN,INPUT);
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          state = gw.loadState(CHILD_ID_RELAY);
          gw.process();
          debouncer.update();
          int value = debouncer.read();
          if (value != oldValue && value==0) {
              gw.send(msg.set(state?false:true), true); // Send new state and request ack back
          oldValue = value;
            if (!metric)
            lastHum = humidity;
        With this sketch i can control the relay with domoticz, but i can only activate the relay, not deactivate.
        I connected the button to GND pin and PIN4 on the Arduino.
        • theckoT thecko
          #include <DHT.h>
          #define NODE_ID 1
          #define RELAY_PIN 3
          MyHwATMega328 hw;
          DHT dht;
          float lastTemp;
          float lastHum;
            gw.process();
              if (!metric)
              lastHum = humidity;
          T Offline
          T Offline
          TheoL
          @thecko Great to hear that you've got it working. The answer to your question is: Yet that's possible.
          What you need for it?
          1. Include Bounce2.h
          2. declare a bounce object in your setup
          3. do the following in your loop()
            a. read the debounced value of your switch
            b. if value changes, than invert current relay value
          With the Bounce library comes an Update-example which shows how you can do the above pseudo code.
          Hope it helps you.
          • B Offline
            B Offline
            BartE
            wrote on last edited by BartE
            @thecko said:
            The problem is in the "state" variable, you use the state variable to toggle but never save changed value
            so change this code snippet
               debouncer.update();
               oldValue = value;
            to
               debouncer.update();
                   gw.send(msg.set(gw.loadState(1)?false:true), true); // Send new state and request ack back
               oldValue = value;
            and remove the state variable at all.
            Even better also remove the "oldValue" and "value" variables (the bounce2 library keeps the old value for you and debouncer.update(); returns true when the value was toggled )
               if (debouncer.update() && debouncer.read() == 0) {
            • theckoT Offline
              theckoT Offline
              thecko
              Hi, thank you for the suggestions, its working now!
              The final code looks like this:
              #include <DHT.h>
              #define NODE_ID 1
              #define RELAY_PIN 3
              MyHwATMega328 hw;
              int oldValue=0;
              bool state;
              DHT dht;
              float lastTemp;
              float lastHum;
                gw.process();
                 debouncer.update();
                 oldValue = value;
                  if (!metric)
                  lastHum = humidity;
              The only thing that remains is that the button needs to be pressed for about 2 secs to actuate. When measured with a multimeter, it takes about 2 secs to get from 1 to 0. Tried inserting a 4.7k resistor between PIN4 and the button, but still 2 sec for the button to actuate.
              B 1 Reply Last reply
              • theckoT thecko
                #include <DHT.h>
                #define NODE_ID 1
                #define RELAY_PIN 3
                MyHwATMega328 hw;
                int oldValue=0;
                bool state;
                DHT dht;
                float lastTemp;
                float lastHum;
                  gw.process();
                   debouncer.update();
                   oldValue = value;
                    if (!metric)
                    lastHum = humidity;
                B Offline
                B Offline
                BartE
                @thecko the button should connect pin D4 to ground when pressed and there should be no resistor needed since your sketch activates the internal pull up resistor with this line:
                theckoT 1 Reply Last reply
                • B BartE
                  theckoT Offline
                  theckoT Offline
                  thecko
                  @BartE Is there any way to decrease the amount of time the button needs to be pushed ? Maybe my choice of the button is not good, will try another button when i come home?
                  • theckoT thecko
                    B Offline
                    B Offline
                    BartE
                    @thecko the amount of time you have to wait is the result of this line
                    Your sketch has to pass 5 times time delay (set by this line debouncer.interval(5);)
                    before a button press is detected.
                    Better use a while loop without a delay some something like this
                    unsigned long lastCheckTimestamp = 0;
                    // setup stuff
                    void loop ()
                        gw.process();
                        // Check if the minimal sample period has been passed
                        if ((lastCheckTimestamp < (millis() - dht.getMinimumSamplingPeriod()) ) || lastCheckTimestamp > millis())
                    	  lastCheckTimestamp  = millis();
                    	  // do the normal stuff after the delay
                    	    if (!metric)
                    	    lastHum = humidity;
                    • theckoT Offline
                      theckoT Offline
                      thecko
                      When i try your sketch in this format:
                      #include <DHT.h>
                      #define NODE_ID 1
                      #define RELAY_PIN 3
                      MyHwATMega328 hw;
                      int oldValue=0;
                      bool state;
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      // setup stuff
                          gw.process();
                              if (!metric)
                              lastHum = humidity;
                      Forumhlp.ino: In function 'void setup()':
                      Forumhlp:44: error: 'incomingMessage' was not declared in this scope
                      Seems something is not right, tried deleting incomingMessage line, but no dice.
                      • theckoT thecko
                        #include <DHT.h>
                        #define NODE_ID 1
                        #define RELAY_PIN 3
                        MyHwATMega328 hw;
                        int oldValue=0;
                        bool state;
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        // setup stuff
                            gw.process();
                                if (!metric)
                                lastHum = humidity;
                        B Offline
                        B Offline
                        BartE
                        @thecko said:
                        You have to add you original setup and incomingMessage function, i just was explaning how to alter the loop function.
                        • B BartE
                          theckoT Offline
                          theckoT Offline
                          thecko
                          @BartE Adding the extra code done the job, now its working great. Thank you for your help!
                          The final working code if someone wonders is:
                          #include <DHT.h>
                          #define NODE_ID 1
                          #define RELAY_PIN 3
                          MyHwATMega328 hw;
                          int oldValue=0;
                          bool state;
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                          // setup stuff
                              gw.process();
                                  if (!metric)
                                  lastHum = humidity;
                          12.1k
