[Solved] MySensors 2.0 Ethernet gateway (ENC28J60) restart / IP issue
I have just found this thread and are having the exact same problem. Arduino nano and en enc28j60 shield.
I don't think its a supply problem.
I had to drive the radio with softspi to get that working only to get the "reboot" issue.
I put this in the setup section of the sketch to catch whats reseting the mcu:
Serial.println(MCUSR); MCUSR=0;This produces this result:
0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0) 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:RADIO:OK 0;255;3;0;9;TSM:GW MODE 0;255;3;0;9;TSM:READY IP: 192.168.0.72 2 <------------ this is when I push the reset button 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0) 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:RADIO:OK 0;255;3;0;9;TSM:GW MODE 0;255;3;0;9;TSM:READY IP: 192.168.0.72 0 <------------ this is the cpu restarting the sketch because of something unknown 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0) 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:RADIO:OK 0;255;3;0;9;TSM:GW MODE 0;255;3;0;9;TSM:READY IP: 192.168.0.72 0 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0) 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:RADIO:OK 0;255;3;0;9;TSM:GW MODE 0;255;3;0;9;TSM:READY IP: 192.168.0.72 0So it seems its not the mcu thats resets. The mcu either executes the nops inte unused flash space and wraps around to adress $0000 and starts over again, or there is a bug in the mysensors or the uipethernet files.
Any thoughts on this?
This is the complete sketch,
/** * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0 - Henrik EKblad * Contribution by a-lurker and Anticimex, * Contribution by Norbert Truchsess <norbert.truchsess@t-online.de> * Contribution by Tomas Hozza <thozza@gmail.com> * * * DESCRIPTION * The EthernetGateway sends data received from sensors to the ethernet link. * The gateway also accepts input on ethernet interface, which is then sent out to the radio network. * * The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program. * * LED purposes: * - To use the feature, uncomment WITH_LEDS_BLINKING in MyConfig.h * - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly * - ERR (red) - fast blink on error during transmission error or recieve crc error * * See http://www.mysensors.org/build/ethernet_gateway for wiring instructions. * */ // Enable debug prints to serial monitor #define MY_DEBUG #define MY_RF24_CHANNEL 1 // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 // Enable gateway ethernet module type #define MY_GATEWAY_ENC28J60 // W5100 Ethernet module SPI enable (optional if using a shield/module that manages SPI_EN signal) //#define MY_W5100_SPI_EN 4 // Enable Soft SPI for NRF radio (note different radio wiring is required) // The W5100 ethernet module seems to have a hard time co-operate with // radio on the same spi bus. #define MY_SOFTSPI #define MY_SOFT_SPI_SCK_PIN 7 #define MY_SOFT_SPI_MISO_PIN 8 #define MY_SOFT_SPI_MOSI_PIN 9 // When W5100 is connected we have to move CE/CSN pins for NRF radio #ifndef MY_RF24_CE_PIN #define MY_RF24_CE_PIN 5 #endif #ifndef MY_RF24_CS_PIN #define MY_RF24_CS_PIN 6 #endif // Enable to UDP //#define MY_USE_UDP #define MY_IP_ADDRESS 192,168,0,72 // If this is disabled, DHCP is used to retrieve address // Renewal period if using DHCP //#define MY_IP_RENEWAL_INTERVAL 60000 // The port to keep open on node server mode / or port to contact in client mode #define MY_PORT 5003 // Controller ip address. Enables client mode (default is "server" mode). // Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere. //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254 // The MAC address can be anything you want but should be unique on your network. // Newer boards have a MAC address printed on the underside of the PCB, which you can (optionally) use. // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address. #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xDD // Flash leds on rx/tx/err //#define MY_LEDS_BLINKING_FEATURE // Set blinking period //#define MY_DEFAULT_LED_BLINK_PERIOD 300 // Enable inclusion mode //#define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway //#define MY_INCLUSION_BUTTON_FEATURE // Set inclusion mode duration (in seconds) //#define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button //#define MY_INCLUSION_MODE_BUTTON_PIN 3 // Uncomment to override default HW configurations //#define MY_DEFAULT_ERR_LED_PIN 7 // Error led pin //#define MY_DEFAULT_RX_LED_PIN 8 // Receive led pin //#define MY_DEFAULT_TX_LED_PIN 9 // the PCB, on board LED #include <SPI.h> #if defined(MY_USE_UDP) #include <EthernetUdp.h> #endif //#include <Ethernet.h> #include <UIPEthernet.h> #include <MySensors.h> void setup() { Serial.println(MCUSR); MCUSR=0; } void loop() { } -
@tekka Don't know. Cheap chinese clone of arduino nano
How do I check?
This is what the arduino IDE spits out when uploading to the nano:avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf" Using Port : COM6 Using Programmer : arduino Overriding Baud Rate : 57600 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : Arduino Description : Arduino Hardware Version: 2 Firmware Version: 1.16 Vtarget : 0.0 V Varef : 0.0 V Oscillator : Off SCK period : 0.1 us avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e950f avrdude: reading input file "C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex" avrdude: writing flash (26964 bytes): Writing | ################################################## | 100% 7.51s avrdude: 26964 bytes of flash written avrdude: verifying flash memory against C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex: avrdude: load data flash data from input file C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex: avrdude: input file C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex contains 26964 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 5.58s avrdude: verifying ... avrdude: 26964 bytes of flash verified avrdude done. Thank you. -
How do I check?
@kk02067 The reason why I'm asking is that you got MCUSR=2 using the reset button - optiboot clears MCUSR:
https://github.com/Optiboot/optiboot/blob/master/optiboot/bootloaders/optiboot/optiboot.c#L479
@tekka I found a sketch that identify the bootloader when googleing a bit. It reports bootloader as:
CRC 2048b @ 0x7800 = 489C
Boot loader: Duemilanove@kk02067 Ok, I rebuilt your setup and could reproduce the rebooting issue. The problem seems AVR board defs > 1.6.11 related, try downgrading to 1.6.11 and comment MY_DEBUG - this is how it works for me:
UIPEthernet 1.09
AVR Board defs 1.6.11
Arduino IDE 1.6.11
MySensors 2.0.0 -
UIPEthernet 1.09
Arduino IDE 1.6.11
MySensors 2.0.0@tekka Updated arduino to latest version 1.6.11 and downgraded to boarddefs 1.6.11 and now it seems fixed, at least with softspi for the radio.
I have to try it with hwspi some other day. Have to stop for today.The version of arduino 1.6.9 would not let me downgrade to boarddefs 1.6.11, thats why it did not work when I tryed it before.
Thanks for all your help.
