  3. [Solved] MySensors 2.0 Ethernet gateway (ENC28J60) restart / IP issue
49 Posts 9 Posters 28.1k Views 8 Watching
  • intelliumI intellium
    The next run it only took 20 mins. before the gateway stopped responding....
    tekkaT
    tekkaT
    tekka
    @intellium Issues with ENC: https://forum.arduino.cc/index.php?topic=398258.0
    sounds pretty much the same...
    intelliumI 1 Reply Last reply
    • tekkaT tekka
      intelliumI
      intelliumI
      intellium
      @tekka Yeah, I was afraid of that....
      I think I might just build a serial gateway and use that for Domoticz as those seem a lot more stable. Then when I find a good source for a w5100 module, I'll get some of those for building an ethernet gateway.
      • intelliumI
        intelliumI
        intellium
        Just a little update:
        I build a serial gateway and attached it to Domoticz. Been working ever since, even during the night. Guess this is the way to go for now.
        tekkaT 1 Reply Last reply
          tekkaT
          tekkaT
          tekka
          @intellium Sounds good - fyi, I'm using both, W5100 and ESP8266-based GWs, w/o issues.
          intelliumI 2 Replies Last reply
          • tekkaT tekka
            intelliumI
            intelliumI
            intellium
            @tekka I've got a bunch of esp8266 modules laying around. Maybe I'll just search how to wire those up to my nano's and find some code to run it as a dedicated gateway / sensor node. I've noticed the site uses a NodeMCU board for this instead of an Arduino (Nano) ?
            • GizMoCuzG
              GizMoCuzG
              GizMoCuz
              wrote on last edited by GizMoCuz
              #26
              Having the exact issue as the OP, but then with a W5100 shield and a NRF24.
              Reverting back to MySensors 1.5.4 solves the problem.
              Now i was on a beta of 2.0 that i uploaded to the gateway quite some time ago, and this worked without issues
              Something has changed in the final 2.0 release... and i want to revert that change ;)
              • GizMoCuzG GizMoCuz
                tekkaT
                tekkaT
                tekka
                @GizMoCuz You mean W5100 freezes and MCU remains responsive? SoftSPI?
                • GizMoCuzG
                  GizMoCuzG
                  GizMoCuz
                  No, the Node is resetting itself with the messages in the first post.
                  If i disable debug, it is logging the IP Address over and over again (each second), connection is reset at that moment
                    tekkaT
                    tekkaT
                    tekka
                    @GizMoCuz Please upload your sketch and describe your configuration, I will try to reproduce with my HW.
                    • GizMoCuzG
                      GizMoCuzG
                      GizMoCuz
                      #30
                      The sketch is 99,999% the same as 'GatewayW5100' except i changed:
                      #define MY_IP_ADDRESS 192,168,0,50
                      The default Arduino ethernet server examples work perfectly
                      Thanks in advance !
                        Thanks in advance !
                        tekkaT
                        tekkaT
                        tekka
                        @GizMoCuz did you uncomment
                        as suggested above?
                        GizMoCuzG 1 Reply Last reply
                        • tekkaT tekka
                          as suggested above?
                          GizMoCuzG
                          GizMoCuzG
                          GizMoCuz
                          #32
                          as suggested above?
                          Yep, see three posts up (If i disable debug, it is logging the IP Address over and over again (each second), connection is reset at that moment)
                          And unfortunately does not explain why version 1.5 is running (but missing important features/fixes)
                            as suggested above?
                            tekkaT
                            tekkaT
                            tekka
                            @GizMoCuz I cannot reproduce your observation with a UNO and W5100 shield. How about power-supply, SPI settings/pins in yor setup?
                              Maks_K
                              I have the same problem:
                              Mega 2560+ w5100
                              Lib 1.5.4 all good
                              Lib 2.0 restart again and again
                              • M Maks_K
                                Mega 2560+ w5100
                                Lib 1.5.4 all good
                                tekkaT
                                tekkaT
                                tekka
                                wrote on last edited by tekka
                                #35
                                @Maks_K @GizMoCuz see here for a solution: https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/3
                                • tekkaT tekka
                                  intelliumI
                                  intelliumI
                                  intellium
                                  @tekka After my original report that the serial gateway worked through the night, I have had to reset it every ~24 hours. Somewhere around that timeframe, the serial gateway just doesn't respond anymore. Restarting the controller doesn't help. When I reset the serial gateway, it instantly works again and continues to do so for around 24 hours. So it seems that although the serial gateway works longer, it eventually also suffers the same issue.... Is this some kind of memory leak perhaps ?
                                  sundberg84S YveauxY 2 Replies Last reply
                                    @intellium - as said before, I strongly as well suspect power issues. I would try out different power supplies and try changing out different parts in your setup.
                                    • sundberg84S sundberg84
                                      intelliumI
                                      intelliumI
                                      intellium
                                      @sundberg84 I've tried different power supplies already with the same problem.
                                      I'll source some more components from different shops and will build another gateway to test. Will report back once done.
                                        YveauxY
                                        YveauxY
                                        Getting into a 'reboot loop' and 'no longer responding' are probably two different things. We should be careful not to mix things up!
                                        • kk02067K
                                          kk02067K
                                          kk02067
                                          I have just found this thread and are having the exact same problem. Arduino nano and en enc28j60 shield.
                                          I don't think its a supply problem.
                                          I had to drive the radio with softspi to get that working only to get the "reboot" issue.
                                          I put this in the setup section of the sketch to catch whats reseting the mcu:
                                           Serial.println(MCUSR);
                                           MCUSR=0;
                                          This produces this result:
                                          0;255;3;0;9;TSM:INIT
                                          0;255;3;0;9;TSM:RADIO:OK
                                          0;255;3;0;9;TSM:GW MODE
                                          0;255;3;0;9;TSM:READY
                                          IP: 192.168.0.72
                                          2        <------------ this is when I push the reset button
                                          IP: 192.168.0.72
                                          0        <------------  this is the cpu restarting the sketch because of something unknown
                                          IP: 192.168.0.72
                                          IP: 192.168.0.72
                                          So it seems its not the mcu thats resets. The mcu either executes the nops inte unused flash space and wraps around to adress $0000 and starts over again, or there is a bug in the mysensors or the uipethernet files.
                                          Any thoughts on this?
                                          This is the complete sketch,
                                           * Version 1.0 - Henrik EKblad
                                           * Contribution by Tomas Hozza <thozza@gmail.com>
                                           * LED purposes:
                                          #define MY_RF24_CHANNEL 1
                                          #define MY_GATEWAY_ENC28J60
                                          //#define MY_W5100_SPI_EN 4
                                          // radio on the same spi bus.
                                            #define MY_SOFTSPI
                                            #define MY_SOFT_SPI_SCK_PIN 7
                                            #define MY_SOFT_SPI_MISO_PIN 8
                                            #define MY_SOFT_SPI_MOSI_PIN 9
                                          #ifndef MY_RF24_CE_PIN
                                            #define MY_RF24_CE_PIN 5
                                          #ifndef MY_RF24_CS_PIN
                                            #define MY_RF24_CS_PIN 6
                                          // Enable to UDP
                                          //#define MY_USE_UDP
                                          #define MY_IP_ADDRESS 192,168,0,72   // If this is disabled, DHCP is used to retrieve address
                                          #define MY_PORT 5003
                                          //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                                          #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xDD
                                          // Flash leds on rx/tx/err
                                          //#define MY_LEDS_BLINKING_FEATURE
                                          // Set blinking period
                                          //#define MY_DEFAULT_LED_BLINK_PERIOD 300
                                          // Enable inclusion mode
                                          //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                                          //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                                          //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                                          #if defined(MY_USE_UDP)
                                            #include <EthernetUdp.h>
                                          //#include <Ethernet.h>
                                          #include <UIPEthernet.h>
                                            MCUSR=0;
