  3. [Solved] MySensors 2.0 Ethernet gateway (ENC28J60) restart / IP issue
49 Posts 9 Posters 28.6k Views 8 Watching
  • GizMoCuzG GizMoCuz
    @tekka said:
    @GizMoCuz did you uncomment
    as suggested above?
    Yep, see three posts up (If i disable debug, it is logging the IP Address over and over again (each second), connection is reset at that moment)
    And unfortunately does not explain why version 1.5 is running (but missing important features/fixes)
    tekkaT
    tekkaT
    tekka
    @GizMoCuz I cannot reproduce your observation with a UNO and W5100 shield. How about power-supply, SPI settings/pins in yor setup?
      Maks_K
      I have the same problem:
      Mega 2560+ w5100
      Lib 1.5.4 all good
      Lib 2.0 restart again and again
      tekkaT 1 Reply Last reply
      • M Maks_K
        Mega 2560+ w5100
        Lib 1.5.4 all good
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #35
        @Maks_K @GizMoCuz see here for a solution: https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/3
        • tekkaT tekka
          @intellium Sounds good - fyi, I'm using both, W5100 and ESP8266-based GWs, w/o issues.
          intelliumI
          intelliumI
          intellium
          @tekka After my original report that the serial gateway worked through the night, I have had to reset it every ~24 hours. Somewhere around that timeframe, the serial gateway just doesn't respond anymore. Restarting the controller doesn't help. When I reset the serial gateway, it instantly works again and continues to do so for around 24 hours. So it seems that although the serial gateway works longer, it eventually also suffers the same issue.... Is this some kind of memory leak perhaps ?
          sundberg84S YveauxY 2 Replies Last reply
          • intelliumI intellium
            sundberg84S
            sundberg84S
            @intellium - as said before, I strongly as well suspect power issues. I would try out different power supplies and try changing out different parts in your setup.
            intelliumI 1 Reply Last reply
            • sundberg84S sundberg84
              intelliumI
              intelliumI
              intellium
              @sundberg84 I've tried different power supplies already with the same problem.
              I'll source some more components from different shops and will build another gateway to test. Will report back once done.
                Getting into a 'reboot loop' and 'no longer responding' are probably two different things. We should be careful not to mix things up!
                • kk02067K
                  kk02067K
                  kk02067
                  I have just found this thread and are having the exact same problem. Arduino nano and en enc28j60 shield.
                  I don't think its a supply problem.
                  I had to drive the radio with softspi to get that working only to get the "reboot" issue.
                  I put this in the setup section of the sketch to catch whats reseting the mcu:
                   Serial.println(MCUSR);
                   MCUSR=0;
                  This produces this result:
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:RADIO:OK
                  0;255;3;0;9;TSM:GW MODE
                  0;255;3;0;9;TSM:READY
                  IP: 192.168.0.72
                  2        <------------ this is when I push the reset button
                  IP: 192.168.0.72
                  0        <------------  this is the cpu restarting the sketch because of something unknown
                  IP: 192.168.0.72
                  IP: 192.168.0.72
                  So it seems its not the mcu thats resets. The mcu either executes the nops inte unused flash space and wraps around to adress $0000 and starts over again, or there is a bug in the mysensors or the uipethernet files.
                  Any thoughts on this?
                  This is the complete sketch,
                   * Version 1.0 - Henrik EKblad
                   * LED purposes:
                  #define MY_RF24_CHANNEL 1
                  #define MY_GATEWAY_ENC28J60
                  //#define MY_W5100_SPI_EN 4
                  // radio on the same spi bus.
                    #define MY_SOFTSPI
                    #define MY_SOFT_SPI_SCK_PIN 7
                    #define MY_SOFT_SPI_MISO_PIN 8
                    #define MY_SOFT_SPI_MOSI_PIN 9
                  #ifndef MY_RF24_CE_PIN
                    #define MY_RF24_CE_PIN 5
                  #ifndef MY_RF24_CS_PIN
                    #define MY_RF24_CS_PIN 6
                  // Enable to UDP
                  //#define MY_USE_UDP
                  #define MY_IP_ADDRESS 192,168,0,72   // If this is disabled, DHCP is used to retrieve address
                  #define MY_PORT 5003
                  #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xDD
                  // Flash leds on rx/tx/err
                  //#define MY_LEDS_BLINKING_FEATURE
                  // Set blinking period
                  // Enable inclusion mode
                  //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                  #if defined(MY_USE_UDP)
                    #include <EthernetUdp.h>
                  //#include <Ethernet.h>
                  #include <UIPEthernet.h>
                    MCUSR=0;
                  • kk02067K kk02067
                     MCUSR=0;
                    IP: 192.168.0.72
                    IP: 192.168.0.72
                    IP: 192.168.0.72
                    IP: 192.168.0.72
                     * LED purposes:
                      #define MY_SOFTSPI
                    // Enable to UDP
                      MCUSR=0;
                    tekkaT
                    tekkaT
                    tekka
                    @kk02067 What bootloader are you running?
                    kk02067K 1 Reply Last reply
                    • tekkaT tekka
                      kk02067K
                      kk02067K
                      kk02067
                      @tekka Don't know. Cheap chinese clone of arduino nano
                      How do I check?
                      This is what the arduino IDE spits out when uploading to the nano:
                               Using Port                    : COM6
                               Overriding Baud Rate          : 57600
                               Programmer Type : Arduino
                               Description     : Arduino
                               Hardware Version: 2
                               Firmware Version: 1.16
                               Vtarget         : 0.0 V
                               Varef           : 0.0 V
                               Oscillator      : Off
                               SCK period      : 0.1 us
                      avrdude: reading input file "C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex"
                      avrdude: writing flash (26964 bytes):
                      Writing | ################################################## | 100% 7.51s
                      avrdude: 26964 bytes of flash written
                      avrdude: verifying flash memory against C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex:
                      avrdude: load data flash data from input file C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex:
                      avrdude: input file C:\Users\Tony\AppData\Local\Temp\build12bf64d7a85151b4ee71a15dfecff5f5.tmp/GatewayW5100.ino.hex contains 26964 bytes
                      Reading | ################################################## | 100% 5.58s
                      avrdude: verifying ...
                      avrdude: 26964 bytes of flash verified
                      avrdude done.  Thank you.
                      • kk02067K kk02067
                        How do I check?
                                 Using Port                    : COM6
                                 Hardware Version: 2
                                 Vtarget         : 0.0 V
                                 Varef           : 0.0 V
                                 Oscillator      : Off
                                 SCK period      : 0.1 us
                        tekkaT
                        tekkaT
                        tekka
                        @kk02067 The reason why I'm asking is that you got MCUSR=2 using the reset button - optiboot clears MCUSR:
                        https://github.com/Optiboot/optiboot/blob/master/optiboot/bootloaders/optiboot/optiboot.c#L479
                        • tekkaT tekka
                          kk02067K
                          kk02067K
                          kk02067
                          @tekka I found a sketch that identify the bootloader when googleing a bit. It reports bootloader as:
                          CRC 2048b @ 0x7800 = 489C
                          Boot loader: Duemilanove
                          • kk02067K kk02067
                            tekkaT
                            tekkaT
                            tekka
                            #45
                            @kk02067 Ok, I rebuilt your setup and could reproduce the rebooting issue. The problem seems AVR board defs > 1.6.11 related, try downgrading to 1.6.11 and comment MY_DEBUG - this is how it works for me:
                            UIPEthernet 1.09
                            AVR Board defs 1.6.11
                            Arduino IDE 1.6.11
                            MySensors 2.0.0
                            • tekkaT tekka
                              UIPEthernet 1.09
                              Arduino IDE 1.6.11
                              MySensors 2.0.0
                              kk02067K
                              kk02067K
                              kk02067
                              @tekka Updated arduino to latest version 1.6.11 and downgraded to boarddefs 1.6.11 and now it seems fixed, at least with softspi for the radio.
                              I have to try it with hwspi some other day. Have to stop for today.
                              The version of arduino 1.6.9 would not let me downgrade to boarddefs 1.6.11, thats why it did not work when I tryed it before.
                              Thanks for all your help.
                              • kk02067K kk02067
                                tekkaT
                                tekkaT
                                tekka
                                @kk02067 Perfect! ;)
                                • cadetC
                                  cadetC
                                  cadet
                                  Please provide wiring for this hardware.
                                  UNO + enc28-shield + NRF24
                                  Andrey
                                  • cadetC
                                    cadetC
                                    cadet
                                    Hi again
                                    I have enc28j60 shield
                                    UNO
                                    Mysensors 2.1.1
                                    avr 1.6.11
                                    and code above
                                    I was change ip address
                                    BUT no ping
                                    comment debug
                                    and if I comment NRF24
                                    I have ping
                                    Any ideas??
                                    Andrey
