  3. How to downgrade library update
4 Posts 2 Posters 2.5k Views 2 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    @mfalkvidd
    Re: Dallas Temperature Sensor - compiling error
    I did this and now I have version 2.0, I thought I could select version but it seems not be possible. It will force to use latest version.
    I don't want to run version 2.0 yet and I cant find Dallas example anymore.
    How can I downgrade to 1.5.1?
    • D
      D
      Drcashman
      All of the examples have been moved to a separate repository.
      https://github.com/mysensors/MySensorsArduinoExamples
      F 1 Reply Last reply
      • D Drcashman
        F
        F
        flopp
        @Drcashman
        Thanks. I found Dallas there.
        I had some files in MySensors that seems to be deleted.
        I had also had a copy of MyConfig.h for my default settings and now I cant find it.
        Is there anyway to downgrade the update I did or can I find the files somewhere maybe?
        • F
          F
          flopp
          I maybe found the solution.
          Download the version you had from here
          https://github.com/mysensors/MySensors/releases
          then copy Library folder from file to your Arduino installation.
          I should be great if you can add a text on the page https://www.mysensors.org/about/arduino#installing-the-sensor-libraries that the user is recommended to make a copy before you updating library
