  3. HTU21D Humidity/Temperature Sensor
8 Posts 7 Posters 6.7k Views 7 Watching
  • TaliskerT
    TaliskerT
    Talisker
    I've tried the new humidity/temperature sensor HTU21D from sparkfun and really like this little breakout board.
    It is a much better replacement for the slow und sometimes unreliable DHTxx sensors. Because of the I2C interface wiring and programming is very easy.
    Here is my adapted version of the MySensors humidity sketch (you need the HTU21D library from sparkfun):
    #include <Wire.h>
    #include <HTU21D.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    //Create an instance of the object
    HTU21D myHumidity;
    boolean metric = true;
      gw.begin();
      gw.sendSketchInfo("Humidity", "2.0");
      myHumidity.begin();
      float temperature = myHumidity.readTemperature();
      if (!metric) {
          temperature = (temperature * 1.8) + 32.0;
      float humidity = myHumidity.readHumidity();
      gw.sleep(SLEEP_TIME); //sleep a bit
    cheers
    YveauxY hekH 2 Replies Last reply
    • TaliskerT Talisker
      #include <Wire.h>
      #include <HTU21D.h>
      HTU21D myHumidity;
        gw.begin();
        myHumidity.begin();
        if (!metric) {
      cheers
      YveauxY
      YveauxY
      @Talisker This is a cheaper version of the Sensirion temp/humidity sensors.
      I have very good experience with Sensirion devices -- I have one measuring temp/humidity levels outside for over a year now so I find them very reliable.
      You could also have a look at silicon labs SI702x devices. They're also compatible.
        #include <Wire.h>
        #include <HTU21D.h>
        HTU21D myHumidity;
          gw.begin();
          myHumidity.begin();
          if (!metric) {
        cheers
        @Talisker
        Welcome, and thanks for the sketch!
        • alexsh1A
          alexsh1A
          alexsh1
          I know this is an old topic, but having recently purchased HTU21D i2c sensor, I have taken the sensebender code and adapted it for this sensor. It is less versatile than Si7021.
          The code reports temperature, humidity and battery voltage.
           * Version 1.0 - Henrik Ekblad
           * Version 1.1 - Alexander Shestakovsky adopted for HTU21D
           * Temperature and humidity HTU21D sensor module
           * http://www.mysensors.org/build/pressure
          #include <Wire.h>
          #include <HTU21D.h>
          #include <avr/power.h>
          #define NODE_ADDRESS   5
          #define RELEASE "1.1"
          #define CHILD_ID_TEMP 0
          #define CHILD_ID_HUM 1
          #define BATT_SENSOR 2
          // Sleep time between reads (in seconds).
          #define MEASURE_INTERVAL 60000
          #define FORCE_TRANSMIT_INTERVAL 30
          #define HUMI_TRANSMIT_THRESHOLD 0.3
          #define TEMP_TRANSMIT_THRESHOLD 0.3
          HTU21D humiditySensor;
          // Sensor messages
          MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
          // Pins
          #define LED_PIN 8
          // Global settings
          int measureCount = 0;
          int sendBattery = 0;
          boolean isMetric = true;
          boolean highfreq = true;
          // Storage of old measurements
          float lastTemperature = -100;
          float lastHumidity = -100;
          long lastBattery = -100;
            pinMode(LED_PIN, OUTPUT);
            digitalWrite(LED_PIN, LOW);
            Serial.begin(115200);
            Serial.print(F("HTU21D Sensor"));
            Serial.print(RELEASE);
            Serial.flush();
            digitalWrite(LED_PIN, HIGH);
            gw.begin(NULL, NODE_ADDRESS, false);
            humiditySensor.begin();
            gw.sendSketchInfo("Temp/Hum Sensor - HTU21D", RELEASE);
            Serial.flush();
            Serial.println(F(" - Online!"));
            // Register sensors to gw (they will be created as child devices)
            gw.present(BATT_SENSOR, S_POWER);
            isMetric = gw.getConfig().isMetric;
            Serial.print(F("isMetric: ")); Serial.println(isMetric);
            sendTempHumidityMeasurements(false);
            sendBattLevel(false);
            measureCount ++;
            sendBattery ++;
            bool forceTransmit = false;
            if ((measureCount == 5) && highfreq)
              clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
              highfreq = false;
            if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
              forceTransmit = true;
              measureCount = 0;
            gw.process();
            delay(50);
            if (sendBattery > 60)
               sendBattLevel(forceTransmit); // Not needed to send battery info that often
               sendBattery = 0;
            gw.sleep(MEASURE_INTERVAL);
           * Sends temperature and humidity from Si7021 sensor
           * Parameters
           * - force : Forces transmission of a value (even if it's the same as previous measurement)
          void sendTempHumidityMeasurements(bool force)
            bool tx = force;
          float temperature = humiditySensor.readTemperature();
          float humidity = humiditySensor.readHumidity();
           float diffTemp = abs(lastTemperature - temperature);
           float diffHum = abs(lastHumidity - humidity);
            Serial.print(F("TempDiff :"));Serial.println(diffTemp);
            Serial.print(F("HumDiff  :"));Serial.println(diffHum);
            if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
            if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
            if (tx) {
              measureCount = 0;
              Serial.print("T: ");Serial.println(temperature);
              Serial.print("H: ");Serial.println(humidity);
              gw.send(msgTemp.set(temperature,1));
              gw.send(msgHum.set(humidity,1));
              lastTemperature = temperature;
              lastHumidity = humidity;
           * Sends battery information (battery percentage)
           * Parameters
          void sendBattLevel(bool force)
            if (force) lastBattery = -1;
            long vcc = readVcc();
            if (vcc != lastBattery) {
              lastBattery = vcc;
          #ifdef BATT_SENSOR
              float Volt = vcc / 1000.0;
              gw.send(msgBatt.set(Volt,2));
              // Calculate percentage
              vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
              long percent = vcc / 14.0;
              gw.sendBatteryLevel(percent);
           * Internal battery ADC measuring
          long readVcc() {
            #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
              ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
            #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
              ADMUX = _BV(MUX5) | _BV(MUX0);
            #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
              ADcdMUX = _BV(MUX3) | _BV(MUX2);
            #else
            long result = (high<<8) | low;
          • L
            L
            LastSamurai
            We did just do the same here.
            alexsh1A 1 Reply Last reply
            • L LastSamurai
              alexsh1A
              alexsh1A
              alexsh1
              @LastSamurai Damn! I should have done a better search on the forum. Anyway, thanks for bringing it up. HTU21D is a good inexpensive sensor so I wonder why we have not had anything done with it before
                maddhin
                Hi, I have built a Slim Node (see https://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example/137?_=1619862122302) but it seems most of the sketch examples here do not work with mysensors.h (I think the v2 of MySensors).
                Does anybody have a working sketch for mysensors.h for the HTU21D with battery monitoring?
                Alternatively: can anybody point me in the right direction on how to "convert" v1 skteches to v2?
                Thanks a bunch!
                skywatchS 1 Reply Last reply
                • M maddhin
                  Thanks a bunch!
                  skywatchS
                  skywatchS
                  skywatch
                  @maddhin Any version 2 sketch with HTU21D should work as slim node is atmgea328 based. I use adafruit lib for mine and it works well. To conserve battery energy follow all the steps on the battery power page in here and send data as infrequently as you can for your needs.
                  here is the code I use to test with - you can safely remove all the "force n updates" to reduce memory use ( I always do). It also only send if the temp or hum has changed since last reading to further reduce battery consumption....
                   * Version 1.0: Andrew Sutcliffe
                   * sensor using a HTU21DF Sensor.
                   * Connect Vin to 3-5VDC
                   * Connect GND to ground
                   * Connect SCL to I2C clock pin (A5 on UNO)
                   * Connect SDA to I2C data pin (A4 on UNO)
                  // Enable debug prints
                  //#define MY_RS485
                  #include <Wire.h>
                  #include "Adafruit_HTU21DF.h"
                  Adafruit_HTU21DF htu = Adafruit_HTU21DF();
                  #define SENSOR_TEMP_OFFSET 0
                  static const uint64_t UPDATE_INTERVAL = 15*60000;
                  float lastTemp;
                  float lastHum;
                  uint8_t nNoUpdatesTemp;
                  uint8_t nNoUpdatesHum;
                  bool metric = true;
                    sendSketchInfo("HTU21DF-TemperatureAndHumidity", "1.0");
                    Serial.begin(9600);
                    Serial.println("HTU21D-F test");
                    if (!htu.begin()) {
                      Serial.println("Couldn't find sensor!");
                      while (1);
                  void loop(){
                    // Get temperature from HTU21DF library
                    float temperature = (htu.readTemperature());
                   if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
                      lastTemp = temperature;
                      // Reset no updates counter
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                    else {
                      nNoUpdatesTemp++;
                    // Get humidity from HTU21DF library
                    float humidity = (htu.readHumidity());
                    if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                    else {
                      nNoUpdatesHum++;
                    sleep(UPDATE_INTERVAL);
                  Hope it helps you get up and running.
