  2. Announcements
  3. 💬 Using Arduino
💬 Using Arduino
27 Posts 15 Posters 19.7k Views 15 Watching
  • B benji_lb
    @benji_lb
    Fixed. I noticed I was running an older version of the software. Uninstalled completely and reinstalled, worked fine.
    Where would be the best place for an Arduino newbie to post to get some assistance? I'm looking at Gateways and i'm unsure which direction to take, and where would be best to post. Would this be OK? https://forum.mysensors.org/category/13/development
    @benji_lb great, thanks for reporting back.
    The development category will be good. Big welcome to the MySensors community :)
    • rejoe2R
      rejoe2R
      rejoe2
      Today, the "Basic Structure" section contains just a "normal" Arduino structure.
      Wouldn't it be useful to also add a slightly extended version mentioning the split of the original Arduino-setup() to begin()->presentation()->setup() when using recent MySenors libs (since 2.1.0)?
      This is not very transparent to quite a few users, and yet some of our examples do either not mention "before()" at all or do not make use of the new logical execution time of setup(), even if this would be helpful (!pcReceived in WaterMeter-Sketch, getControllerConfig(), for metric in Temperature, just to mention some examples) .
      Also the text order of setup() still beeing above presentation() in at least some examples may be technically irrelevant but nevertheless misleading to some extend.
      • rejoe2R rejoe2
        @rejoe2 great feedback, thanks! For the examples, I have created https://github.com/mysensors/MySensors/issues/927
        I have updated the "Using Arduino " page. I am not 100% sure I got it right and easy to understand so feedback is very welcome.
        rejoe2R 1 Reply Last reply
          rejoe2R
          rejoe2R
          rejoe2
          @mfalkvidd
          Your understanding of my suggestion seems to be 100% correct. I will add some additional comments and some (too complicated but working examples) as links at the github page.
            3nibble
            Hi there,
            I am on Linux - exclusively! Does that mean I am out even before I started?
            3nibble (puzzled)
            • N
              N
              napo7
              You're not !
              I'm also exclusively on linux, and I use MySensors !
              I was using Arduino IDE, and now I'm using atom.io, but both are working on linux !
              • K
                K
                kayani009
                hi i am using Lora SX1276 as simple transmitter and receiver.
                is there any library for sending and receiving the data no gateway involved only simple data transmission and reception.
