  2. Announcements
  3. 💬 Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 71.7k Views 51 Watching
  • rejoe2R
    rejoe2R
    rejoe2
    Use this syntax instead:
    #define SN "GatewayESP8266OTA_v3"
    #define SV "1.01"
    sendSketchInfo(SN, SV);
    • Fat FlyF Fat Fly
      Small question. How to connect this gw to Domoticz ? Over lan and in Domoticz ?
      B
      B
      billcrps32
      @Fat-Fly i also want the answer of this question
      • Bogusz JagodaB
        Bogusz JagodaB
        Bogusz Jagoda
        Worth noting - use MY_RFM69_NEW_DRIVER define... (2.3.2+)
        #ifdef ESP8266
            // For RFM69
            #define MY_RADIO_RFM69
        	#define MY_RFM69_NEW_DRIVER
            #define MY_RFM69_FREQUENCY  RFM69_868MHZ // Set your frequency here
            #define MY_IS_RFM69HW                    // Omit if your RFM is not "H"
            #define MY_RFM69_IRQ_PIN    D1
            #define MY_RFM69_IRQ_NUM    digitalPinToInterrupt(MY_RFM69_IRQ_PIN)
            #define MY_RFM69_CS_PIN     D8           // NSS. Use MY_RFM69_SPI_CS for older versions (before 2.2.0)
        • H
          H
          HoseArkadio
          I'm having trouble compiling the ESP gate code. Can you help me?
          In file included from c:\Users\Arkadiusz_Dziura\Documents\Arduino\libraries\MySensors/MySensors.h:441,
          from C:\Users\Arkadiusz_Dziura\Documents\Arduino_OLD\Domoticz_BRAMA_ESP\Domoticz_BRAMA_ESP.ino:61:
          c:\Users\Arkadiusz_Dziura\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: In function 'bool can_yield()':
          c:\Users\Arkadiusz_Dziura\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:95:9: error: 'cont_can_yield' was not declared in this scope; did you mean 'can_yield'?
          95 | return cont_can_yield(g_pcont);
          | can_yield
          c:\Users\Arkadiusz_Dziura\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: In function 'void esp_yield_within_cont()':
          c:\Users\Arkadiusz_Dziura\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:101:2: error: 'cont_yield' was not declared in this scope; did you mean 'can_yield'?
          101 | cont_yield(g_pcont);
          | can_yield
          c:\Users\Arkadiusz_Dziura\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: In function 'void loop_task(ETSEvent*)':
          c:\Users\Arkadiusz_Dziura\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:199:26: error: invalid operands of types 'void' and 'int' to binary 'operator!='
          199 | if (cont_check(g_pcont) != 0) {
          | void int
          exit status 1
          Compilation error: exit status 1
          • V
            V
            veris25
            I join the question, I have exactly the same problem: .../MyMainESP8266.cpp:95:9: error: 'cont_can_yield' was not declared in this scope; did you mean 'can_yield'?
            i found a reference #include "cont.h" in MyMainESP8266.cpp but i can't find 'cont.h'
            M 1 Reply Last reply
            • V veris25
              Msmax
              @veris25
              I installed an older ESP8266 lib v3.0.0 to compile without errors.
              • electrikE
                electrikE
                electrik
                You should try downgrading the ESP version below 3.0
                • H
                  H
                  HoseArkadio
                  elektryk ....I do not really understand.
                  • electrikE
                    electrikE
                    electrik
                    I mean the ESP framework version, selected by the board version
                    https://arduino.esp8266.com/Arduino/versions/2.0.0/doc/installing.html#:~:text=Open Boards Manager from Tools,from a drop-down box.
