  2. Announcements
  3. 💬 Building a MQTT Gateway
81 Posts 30 Posters 49.7k Views 28 Watching
  • S Samuel235
    My gateway seems to be constantly repeating the following on the serial monitor:
    IP: 192.168.0.22
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: Gateway1-out/0/255/0/0/18
    0;255;3;0;9;Message arrived on topic: Gateway1-in/4/1/1/0/2
    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    IP: 192.168.0.22
    IP: 192.168.0.22
    Does this look like its in a reset loop or would you say there is some other issue going on?
    If needed, my config is a Arduino Mega 2560 witha w5100 shield on top. I have specified the IP address of itself, the subnet, gateway, mqtt client IP (Controller), the mqtt topics, port, changed my LED pins.
    I have a node with a button next to me, when i press it the message is picked up by the gateway. Below is what happens in the serial monitor when i press the node button.
    IP: 192.168.0.22
    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=3,c=1,t=2,pt=2,l=2,sg=0:1
    0;255;3;0;9;Sending message on topic: Gateway1-out/3/3/1/0/2
    I'm a little confused at what point to troubleshoot here because I seem to think that for some reason it keeps refreshing its connection to the MQTT server. Not too sure why it is pushing a message to the topic of "Gateway1-out/0/255/0/0/18" either.
    @Samuel235 see if the solution suggested by tekka in https://forum.mysensors.org/post/47225 can help (downgrade board definitions to 1.6.11)
    • S Samuel235
      IP: 192.168.0.22
      IP: 192.168.0.22
      IP: 192.168.0.22
      IP: 192.168.0.22
      In case anyone needs to know where to downgrade: Tools -> Boards ->Boards Manager -> Select version for Arduini AVR Boards.
      S 1 Reply Last reply
        Samuel235
        @mfalkvidd - It is still seeming to repeatedly reconnect to the MQTT server. I've issued a ping command to the arduino from the mqtt server and its constantly pinging without an issue, even while the serial monitor shows that its reconnecting. I'de be interested to know if anyone else is running the MQTT client gateway with MySensors V2.1. I used to run it when it was first introduced into the development environment in 1.6 and its been fine for over a year, but i upgraded to V2.1 and now i get this. So, i don't actually know if it is supposed to keep reconnecting to the MQTT server. I have read somewhere here that it sends a wake/refresh packet/message to the mqtt server just to keep it alive, but they said that was every 15 seconds by default. This is happening every 5/6 seconds.
        IP: 192.168.0.22
        IP: 192.168.0.22
        IP: 192.168.0.22
        MySensors 2.1.1
          i think you need to post your code just to make more complete info.
            Samuel235
            I would like to know if anyone else's MQTT Gateway does this?
            If this is the normal procedure I can carry on with config work for the nodes. Its pretty weird, the serial monitor is showing this but the gateway seems to be functioning. Nodes are talking to it. I'm not sure on that output topic though, why would it be sending something to Gateway1-out/0/255/0/0/18?
            MySensors 2.1.1
              Samuel235
              #33
              @gohan - I have not touched the MySensors.h or MyConfig.h but the sketch is below:
               * Version 1.0 - Henrik Ekblad
               * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
               * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
               * LED purposes:
               * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
               * nRF24L01+  ESP8266
               * VCC        VCC
               * CE         GPIO4
               * CSN/CS     GPIO15
               * SCK        GPIO14
               * MISO       GPIO12
               * MOSI       GPIO13
                * Inclusion mode button:
              #define MY_MQTT_PUBLISH_TOPIC_PREFIX "Gateway1-out"
              #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "Gateway1-in"
              // Set MQTT client id
              //#define MY_W5100_SPI_EN 4
              // radio on the same spi bus.
              #define MY_SOFTSPI
              #ifndef MY_RF24_CE_PIN
              #define MY_RF24_CE_PIN 5
              #ifndef MY_RF24_CS_PIN
              #define MY_RF24_CS_PIN 6
              #define MY_IP_ADDRESS 192,168,0,22
              #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 21
              #define MY_PORT 1883
              // Enable inclusion mode
              // Set blinking period
              // Flash leds on rx/tx/err
              #define MY_DEFAULT_ERR_LED_PIN 11  // Error led pin
              #define MY_DEFAULT_RX_LED_PIN  12  // Receive led pin
              #define MY_DEFAULT_TX_LED_PIN  13  // the PCB, on board LED
              #include <Ethernet.h>
              EDIT: My issue was resting on the MQTT Server, had OpenHAB and MySensors gateway using same ClientID.
              MySensors 2.1.1
              • Mountek AngelM Mountek Angel
                Hi, is it possible to configure the MQTT gateway to let me in to port 5003 via telnet and read the communication message (not MQTT payloads) there also?
                mlava
                @Gabor-Bognar I also need to be able to do this.
                Is there a solution to have a port 1883 for MQTT and port 5003 for telnet?
                • G
                  G
                  Gefkuz
                  There is a missing parameter in your sketch :
                  // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                  #define MY_MAC_ADDRESS 0x90, 0xA2, 0xDA, 0x10, 0xEB, 0x1D
                  In normal way, this line is note really important.
                  But if you want to use two separate MQTT on the same network, you should add this line and modify the mac adress on the two MQTT...
                  Bye
                    scottdube
                    Is it possible to have a single device acting as a ethernet gateway and an mqtt gateway?
                      No, but if you really really need the 2 connections you could use node-red to read data from the ethernet gateway and mirror them to mqtt
                        scottdube
                        I am wondering why you cannot built the ethernet gateway and combine the mqtt client sketch into it? I am trying to shift towards mqtt (experiment) while still having sensors available in Vera. I have the MQTT plugin on vera but have not yet figured out how to use the child device to control devices via MQTT. It seems like a waste to control the MQTT device only through Vera and I would never be able to shift away from vera that way. I'm new to this so I am still trying to understand the entire picture.
                        • S scottdube
                          #39
                          @scottdube my guess is that nobody with sufficient knowledge has had enough motivation and time to see if it can be done - especially since other solutions (nodered, myscontroller) already exist.
                            scottdube
                            @mfalkvidd I am missing something, the reason I want it to do both is that I want the flexibility to use Node Red and my Vera controller. I was thinking that as I built new sensors they would run through node red but be available to vera as well. I'm sure I just don't yet understand how people are designing their hybrid systems yet. My solution was to have the mysensors gateway also put the sensors values out to the mqtt broker and vice versa but there must be another way I am not seeing yet...
                              maybe it is time to switch away from Vera to something else that still uses zwave?
                                scottdube
                                @gohan Maybe that is the answer, I'll research that a bit... That was what I was hoping to do over time with my strategy...
                                • S scottdube
                                  #43
                                  @scottdube you can let Vera connect to Nodered.
                                  See these threads for some ideas on what other people have done
                                  https://forum.mysensors.org/topic/3891/2-controllers-and-1-gateway-expected-behavior/5
                                  https://forum.mysensors.org/topic/4792/node-red/2
                                  https://forum.mysensors.org/topic/9106/new-node-red-contrib-mysensors-out/2
                                  • joaoabsJ
                                    joaoabsJ
                                    joaoabs
                                    I'd like to have a very simple (intra-home) web page in my raspberry PI that would be updated with all of my nodes information and that could also turn on/off nodes with actuators (basically I don't want to have a fancy controller).
                                    If I understood correctly, with this MQTT Ethernet Gateway I could implement this by running Mosquito that would subscribe information from each node, through this MQTT gateway.
                                    Does this mean I can avoid having a controller?
                                    Cheers,
                                      Technically speaking yes but I don't see the point in reinventing the wheel
                                      • ร
                                        ร
                                        รอเรือ
                                        I rebuilt my serial gateway to a MQTT gateway. FWIW I had to connect 5V to my WizNET (W5100) Ethernet module (3.3V did not work) I couldn't make DHCP work so I used a fixed IP. Finally I had to replace the capacitor over the radio power feed from 4.7 uF capacitor to a 100 uF capacitor (That made a big difference!). Works great now.
                                        • G
                                          G
                                          Guillermo Schimmel
                                          It should have:
                                          sendSketchInfo("Gateway node", "1.0");
                                          In order to show the right topology in some tools, i.e. mycontroller.org
