  2. Announcements
  • C
    C
    ccy
    wrote on last edited by ccy
    #381
    @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
    [root@alarmpi bin]# ./mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=3
    mysgw: TSM:FAIL:PDT
    mysgw: Received SIGINT
    Here is my /boot/config.txt:
    gpu_mem=64
    initramfs initramfs-linux.img followkernel
    dtparam=spi=on
    and the spi dev:
    # ls /dev/spidev0.*
    /dev/spidev0.0  /dev/spidev0.1
    I am using ArchLinuxARM:
    # uname -a
    Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
    I only wiring 7 pins (1-7) on NRF24l01+.
    Raspberry Pi 2 hardware information:
    # cat /proc/cpuinfo
    processor       : 0
    model name      : ARMv7 Processor rev 5 (v7l)
    BogoMIPS        : 38.40
    Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xc07
    CPU revision    : 5
    processor       : 1
    BogoMIPS        : 38.40
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xc07
    CPU revision    : 5
    processor       : 2
    BogoMIPS        : 38.40
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xc07
    CPU revision    : 5
    processor       : 3
    BogoMIPS        : 38.40
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xc07
    CPU revision    : 5
    Hardware        : BCM2835
    Revision        : a21041
    Serial          : 00000000475d18a4
    # cat /sys/firmware/devicetree/base/model
    Raspberry Pi 2 Model B Rev 1.1
    Output from MySensors configure:
    # ./configure
    [SECTION] Detecting target machine.
    ./configure: line 111: warning: command substitution: ignored null byte in input
      [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l.
    [SECTION] Checking GPIO Sysfs.
      [OK] /sys/class/gpio/export found
    [SECTION] Detecting SPI driver.
      [OK] SPI driver detected:SPIDEV.
    [SECTION] Detecting init system.
      [OK] init system detected: systemd.
    [SECTION] Saving configuration.
    [SECTION] Cleaning previous builds.
    [OK] Finished.
    I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
    function detect_machine {
        case $hardware in
        BCM2835)
            soc="BCM2835"
            if [[ $machine == "Raspberry"* ]]; then
                local rev=($(detect_rpi_revision))
                if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                    tp="RPi3"
                else
                    tp="Rpi2"
                fi
            fi
    make mysgw again, and I get this finally:
    # ./mysgw -d
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Listening for connections on 0.0.0.0:5003
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    enloE J 2 Replies Last reply
    • C
      C
      ccy
      #382
      I can run mysgw. But what can I use it for? I want to make it control my light with 2.4G RF. But I don't know what to do next. Please advice Thank you.
      gohanG 1 Reply Last reply
      • C ccy
        @ccy
        You need to provide some more details about your hw and general setup, what have you done so far, log messages, etc.
        C 1 Reply Last reply
          @ccy
          C
          C
          ccy
          @gohan Sorry for my typo mistake. I can now run mysgw. But what can I use it for? I am trying to control my light with 2.4G RF.
            Do you mean your light has already 2.4G RF or do you need to make a relay node with NRF24 that can switch on and of that light? But this is going a little OT in this thread.
              C
              C
              ccy
              @gohan Yes. I want to do that. I am sure my LED controller is 2.4G RF. But I can't detect any signal yet from my nrf24l01+ on raspberry pi. I am not sure what's wrong. Still trying now...
              • C ccy
                @ccy
                Being 2.4G RF doesn't mean it is NRF24L01 compatible also without knowing what channel is using will make it even more difficult. So, unless you want to make a Mysensors LED Controller, I think you are out of luck if you want to directly control your existing one with a RPI and the mysensors gateway. Either way this is OT.
                  @ccy
                  C
                  C
                  ccy
                  @gohan Is there a way to know the channel by doing some sort of scan? If the channel is known, what are the setting to fix the channel for mysgw?
                  • Velo17V
                    Velo17V
                    Velo17
                    Hello everyone!
                    I'm using a Rasp2 (with the 40 pins GPIO header)
                    Has anyone experience with using the NRF module on different pins than default? I'm asking because I wonder if I can connect a GPIO-connected touch TFT (which would use the 2 CE lines for the touch and display interfaces) together with the NRF - by hooking the MISO/MOSI/SCLK to the default pins (and thus sharing them between the TFT and NRF) and defining free pins for the CE and CS lines in the ./configure script when compiling the gateway code...?!
                    Or maybe using the SPI1 by first enabling it as laid out in this blog post - but how to proceed from there? (How to tell the gateway code to use SPI1?)
                      marceloaqno
                      Code Contributor
                      @Velo17
                      ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev1.0
                      (replace the /dev/spidev1.0 with the one you enabled in /boot/config.txt)
                      • engyE
                        engyE
                        engy
                        Hello Masters,
                        Could you please help me with setting up virtual serial port?
                        I can't see the interface created under /dev.
                        I'm using the instructions and finish with the setup with the following command:
                        pi@raspberrypi:/tmp/MySensors $ ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                          [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l.
                          [OK] SPI driver detected:BCM.
                        [OK] Finished.
                        pi@raspberrypi:/ $ sudo /usr/local/bin/mysgw -d
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        Everything seems to be OK. However, when I check /dev directory, the interface is not created.
                        What could be an issue?
                        Thank you in advacne!
                          Why don't you compile it as ethernet gateway?
                          engyE 1 Reply Last reply
                            engyE
                            engyE
                            engy
                            @gohan Etherner Gareway is not supported by OpenHab MySensors binding.
                              Mqtt? 😀
                                Mqtt? 😀
                                engyE
                                engyE
                                engy
                                @gohan I'm sorry, MQTT is not supported by OpenHab MySensors binding. Ethernet Gateway is not supported on Raspberry PI.
                                M 1 Reply Last reply
                                • engyE engy
                                  marceloaqno
                                  Code Contributor
                                  #396
                                  @engy OpenHab2 supports mysensors serial and ethernet gateways:
                                  https://github.com/tobof/openhab2-addons/wiki
                                  Maybe the build guide may have given you that impression, but ethernet Gateway is supported on Raspberry PI:
                                  ./configure --my-gateway=ethernet
                                    @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
                                    keldandorinK
                                    keldandorinK
                                    keldandorin
                                    @gohan Solved the problem with radio...Thx
                                    • M marceloaqno
                                      engyE
                                      engyE
                                      engy
                                      Thank you guys for prompt reaction. Indeed, Ethernet GW works flawlessly!
                                      • T
                                        TommiP
                                        Hi
                                        Is anyone else having this same problem on Rpi3?: Gateway works ok after "sudo make install" with openHAB. With "sudo ./bin/mysgw -d" I can get debug log visible and log works ok.
                                        But if I run "sudo systemctl enable mysgw.service" after "sudo make install", debug log start showing endlessly "mysgw: accept: Bad file descriptor". So debug log function gets destroyed and it can't be used anymore. I have made several clean installations and every time this same happens.
                                        Br
                                        Tommi
                                        • T TommiP
                                          Hi
                                          Br
                                          Tommi
                                          marceloaqno
                                          Code Contributor
                                          @TommiP What I think is happening is that you are running two instances of the gateway.
                                          If you need to get the debug logs, first stop the mysgw service:
                                          sudo systemctl stop mysgw.service
                                          T 1 Reply Last reply
