  2. Announcements
    @ccy
    You need to provide some more details about your hw and general setup, what have you done so far, log messages, etc.
    C
    C
    ccy
    @gohan Sorry for my typo mistake. I can now run mysgw. But what can I use it for? I am trying to control my light with 2.4G RF.
      Do you mean your light has already 2.4G RF or do you need to make a relay node with NRF24 that can switch on and of that light? But this is going a little OT in this thread.
      C 1 Reply Last reply
        C
        C
        ccy
        @gohan Yes. I want to do that. I am sure my LED controller is 2.4G RF. But I can't detect any signal yet from my nrf24l01+ on raspberry pi. I am not sure what's wrong. Still trying now...
        gohanG 1 Reply Last reply
        • C ccy
          @ccy
          Being 2.4G RF doesn't mean it is NRF24L01 compatible also without knowing what channel is using will make it even more difficult. So, unless you want to make a Mysensors LED Controller, I think you are out of luck if you want to directly control your existing one with a RPI and the mysensors gateway. Either way this is OT.
            @ccy
            C
            C
            ccy
            @gohan Is there a way to know the channel by doing some sort of scan? If the channel is known, what are the setting to fix the channel for mysgw?
            • Velo17V
              Velo17V
              Velo17
              Hello everyone!
              I'm using a Rasp2 (with the 40 pins GPIO header)
              Has anyone experience with using the NRF module on different pins than default? I'm asking because I wonder if I can connect a GPIO-connected touch TFT (which would use the 2 CE lines for the touch and display interfaces) together with the NRF - by hooking the MISO/MOSI/SCLK to the default pins (and thus sharing them between the TFT and NRF) and defining free pins for the CE and CS lines in the ./configure script when compiling the gateway code...?!
              Or maybe using the SPI1 by first enabling it as laid out in this blog post - but how to proceed from there? (How to tell the gateway code to use SPI1?)
                marceloaqno
                Code Contributor
                @Velo17
                ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev1.0
                (replace the /dev/spidev1.0 with the one you enabled in /boot/config.txt)
                • engyE
                  engyE
                  engy
                  Hello Masters,
                  Could you please help me with setting up virtual serial port?
                  I can't see the interface created under /dev.
                  I'm using the instructions and finish with the setup with the following command:
                  pi@raspberrypi:/tmp/MySensors $ ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                    [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l.
                    [OK] SPI driver detected:BCM.
                  [OK] Finished.
                  pi@raspberrypi:/ $ sudo /usr/local/bin/mysgw -d
                  mysgw: Starting gateway...
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:INIT:TSP OK
                  mysgw: TSM:INIT:GW MODE
                  mysgw: MCO:REG:NOT NEEDED
                  mysgw: MCO:BGN:STP
                  mysgw: MCO:BGN:INIT OK,TSP=1
                  Everything seems to be OK. However, when I check /dev directory, the interface is not created.
                  What could be an issue?
                  Thank you in advacne!
                    Why don't you compile it as ethernet gateway?
                    engyE 1 Reply Last reply
                      engyE
                      engyE
                      engy
                      @gohan Etherner Gareway is not supported by OpenHab MySensors binding.
                        Mqtt? 😀
                          Mqtt? 😀
                          engyE
                          engyE
                          engy
                          @gohan I'm sorry, MQTT is not supported by OpenHab MySensors binding. Ethernet Gateway is not supported on Raspberry PI.
                          • engyE engy
                            marceloaqno
                            Code Contributor
                            wrote on last edited by marceloaqno
                            #396
                            @engy OpenHab2 supports mysensors serial and ethernet gateways:
                            https://github.com/tobof/openhab2-addons/wiki
                            Maybe the build guide may have given you that impression, but ethernet Gateway is supported on Raspberry PI:
                              @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
                              keldandorinK
                              keldandorinK
                              keldandorin
                              @gohan Solved the problem with radio...Thx
                              • M marceloaqno
                                engyE
                                engyE
                                engy
                                Thank you guys for prompt reaction. Indeed, Ethernet GW works flawlessly!
                                • T
                                  TommiP
                                  Hi
                                  Is anyone else having this same problem on Rpi3?: Gateway works ok after "sudo make install" with openHAB. With "sudo ./bin/mysgw -d" I can get debug log visible and log works ok.
                                  But if I run "sudo systemctl enable mysgw.service" after "sudo make install", debug log start showing endlessly "mysgw: accept: Bad file descriptor". So debug log function gets destroyed and it can't be used anymore. I have made several clean installations and every time this same happens.
                                  Br
                                  Tommi
                                  • T TommiP
                                    Hi
                                    Br
                                    Tommi
                                    marceloaqno
                                    Code Contributor
                                    @TommiP What I think is happening is that you are running two instances of the gateway.
                                    If you need to get the debug logs, first stop the mysgw service:
                                    sudo systemctl stop mysgw.service
                                    • M marceloaqno
                                      TommiP
                                      @marceloaqno
                                      Ok, now I understand what happened, thanks.
                                      • R
                                        R
                                        romeo01
                                        Re: 💬 Building a Raspberry Pi Gateway
                                        Silly questions, I'm a little bit confuse.
                                        I have a serial Gateway running with arduino nano + nrf24 and a raspberry pi with domoticz on board. The link between domoticz & Gateway is done via USB <=> serial port (/dev/ttyUSB0). This setup runs like a charm.
                                        Now, I would like to access to my Gateway via the network because I would like to use "Over The Air " functionnality with MYSController.
                                        Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb ?? For the moment, I can not use GPIO port.
                                        If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:
                                        ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
                                        [OK] machine detected: SoC=BCM2836, Type=RPi3, CPU=armv7l.
                                        [OK] Finished.
                                        make
                                        ./bin/mysgw -d
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: !TSM:INIT:TSP FAIL
                                        mysgw: TSM:FAIL:CNT=1
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:FAIL:RE-INIT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:CNT=2
                                        mysgw: TSM:FAIL:PDT
                                        Where is my mistake ??
                                        Again, Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb or I must connected the nrf24 directly with GPIO on the Rasp ??
                                        Thanks in advance for your reply.
                                        Romeo
                                        • R romeo01
                                          [OK] Finished.
                                          make
                                          ./bin/mysgw -d
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          Romeo
                                          @romeo01 I think that connecting nrf24 directly to arduino and compile mysgw as ethernet gateway is the cleanest solution (I have it as MQTT and it is working fine, but ethernet is the same). Keep in mind that you'd better use one of those adapters 5v-3.3v for nrf24 chips + capacitor because the 3v output of raspberry isn't very suited for the task.
