  2. Announcements
  3. ๐Ÿ’ฌ Building a Raspberry Pi Gateway
    marceloaqno
    Code Contributor
    Support for RFM69 was added to the development branch (finally!).
    jirmJ 1 Reply Last reply
    • M marceloaqno
      jirmJ
      jirmJ
      jirm
      @marceloaqno
      Iยดm really happy ear that !
      RFM69 is one of best RF transceivers in these days for IoT.
      So good news I believe for Mysensors community.
      You know if are any hope that RFM69 will be added too to OPI boards support mysgw development ?
      Congratulations for that great work !
      M 1 Reply Last reply
      • jirmJ jirm
        @marceloaqno
        marceloaqno
        Code Contributor
        @jirm Support for RFM69 also applies to the OrangePi :wink:
        • M marceloaqno
          jirmJ
          jirmJ
          jirm
          wrote on last edited by jirm
          #424
          @marceloaqno
          Awesome !!!
          Thank you so much.
          Best regards
          • F
            F
            ftw64
            When I configure "MY_RFM69_MAX_POWER_LEVEL_DBM" in MyConfig.h, compiling fails.
            Perhaps you should change the code in ./drivers/RFM69/new/RFM69_new.h from:
            #define RFM69_MAX_POWER_LEVEL_DBM MY_RFM69_MAX_POWER_LEVEL_DBM //!< MY_RFM69_MAX_POWER_LEVEL_DBM
            to:
            #define RFM69_MAX_POWER_LEVEL_DBM ((rfm69_powerlevel_t)MY_RFM69_MAX_POWER_LEVEL_DBM) //!< MY_RFM69_MAX_POWER_LEVEL_DBM
            • F
              F
              ftw64
              I cannot get the RFM69(HW) working. When I start myswg in debug mode (-d), I see:
              mysgw: Starting gateway...
              mysgw: Protocol version - 2.2.0-beta
              mysgw: MCO:BGN:INIT GW,CP=RPNG----,VER=2.2.0-beta
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: RFM69:INIT
              mysgw: RFM69:INIT:PIN,CS=24,IQP=22,IQN=22
              mysgw: RFM69:PTX:LEVEL=5 dBm
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: Listening for connections on 0.0.0.0:5003
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              But I can see ('hear' with a radio on 868.000 MHz) no transmission of the RFM69. When I power up a node, the node does not connect to the gateway: "NO REPLY":+1:
              0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
              4 TSM:INIT
              4 TSF:WUR:MS=0
              8 TSM:INIT:TSP OK
              10 TSM:INIT:STATID=4
              12 TSF:SID:OK,ID=4
              14 TSM:FPAR
              274 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2281 !TSM:FPAR:NO REPLY
              2283 TSM:FPAR
              2562 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              4569 !TSM:FPAR:NO REPLY
              4571 TSM:FPAR
              4831 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              6838 !TSM:FPAR:NO REPLY
              6840 TSM:FPAR
              7100 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              9107 !TSM:FPAR:FAIL
              9109 TSM:FAIL:CNT=1
              9111 TSM:FAIL:PDT
              Is there any 'check' I can do to perform basic RFM69HW testing on my RPI?
                Was it working before on a normal Arduino gateway? How did you wire everything up?
                • F
                  F
                  ftw64
                  I'm pretty sure I wired up the RFM69 correctly.
                  However, I'm debugging. It seems we are stuck in "core/MyGatewayTransport.cpp":
                  inline void gatewayTransportProcess(void)
                    if (gatewayTransportAvailable()) {
                      // NEVER REACHED
                  I never seem to get pass gatewayTransportAvailable. I will continue debugging.
                  Disclaimer: I'm relatively new to MySensors and not really 'up to speed' with the source code :-).
                  F 1 Reply Last reply
                  • F ftw64
                        // NEVER REACHED
                    F
                    F
                    ftw64
                    @ftw64 Ok, this has to do with connecting an Ethernet client. When a client connects, this code works...
                    Any idea where to start debugging for incoming RFM69 messages?
                      Download myscontroller and connect it to the gateway, you can now see all messages from ethernet controller
                        F
                        F
                        ftw64
                        @gohan said in ๐Ÿ’ฌ Building a Raspberry Pi Gateway:
                        myscontroller
                        I just did. When I also have a Domoticz controller connected to the gateway:
                        2017-04-23 11:18:33	INFO	Connected to 192.168.10.24:5003
                        2017-04-23 11:18:33	CHILD	New child discovered, node id=0, child id=internal
                        2017-04-23 11:18:33	RX	0;255;3;0;14;Gateway startup complete.
                        2017-04-23 11:18:33	DEBUG	Update child id=255, type=ARDUINO_RELAY
                        2017-04-23 11:18:33	RX	0;255;0;0;18;2.2.0-beta
                        2017-04-23 11:18:33	RX	0;255;3;0;22;208103
                        2017-04-23 11:18:33	RX	0;255;3;0;2;2.2.0-beta
                        2017-04-23 11:18:43	RX	0;255;3;0;22;218106
                        2017-04-23 11:18:53	RX	0;255;3;0;22;228110
                        2017-04-23 11:19:03	RX	0;255;3;0;22;238101
                        2017-04-23 11:19:13	RX	0;255;3;0;22;248104
                        2017-04-23 11:19:23	RX	0;255;3;0;22;258110
                        2017-04-23 11:19:33	RX	0;255;3;0;22;268107
                        2017-04-23 11:19:43	RX	0;255;3;0;22;278106
                        2017-04-23 11:19:53	RX	0;255;3;0;22;288110
                        2017-04-23 11:20:03	RX	0;255;3;0;22;298116
                        However, I found out that the DI00 (=IRQ) on the RFM69 never gives a rising edge...
                        I'm suspecting that the RFM69 is not being initialised properly... I added some debugging in the RFM69 code to see what registers are being written and read:
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: RFM69:INIT
                        mysgw: FtW:RFM69:write register, reg=0x01, value=4
                        mysgw: FtW:RFM69:write register, reg=0x02, value=0
                        mysgw: FtW:RFM69:write register, reg=0x03, value=2
                        mysgw: FtW:RFM69:write register, reg=0x04, value=64
                        mysgw: FtW:RFM69:write register, reg=0x05, value=3
                        mysgw: FtW:RFM69:write register, reg=0x06, value=51
                        mysgw: FtW:RFM69:write register, reg=0x18, value=136
                        mysgw: FtW:RFM69:write register, reg=0x19, value=66
                        mysgw: FtW:RFM69:write register, reg=0x26, value=7
                        mysgw: FtW:RFM69:write register, reg=0x28, value=16
                        mysgw: FtW:RFM69:write register, reg=0x29, value=220
                        mysgw: FtW:RFM69:write register, reg=0x2c, value=0
                        mysgw: FtW:RFM69:write register, reg=0x2d, value=3
                        mysgw: FtW:RFM69:write register, reg=0x2e, value=136
                        mysgw: FtW:RFM69:write register, reg=0x2f, value=45
                        mysgw: FtW:RFM69:write register, reg=0x30, value=101
                        mysgw: FtW:RFM69:write register, reg=0x37, value=212
                        mysgw: FtW:RFM69:write register, reg=0x38, value=66
                        mysgw: FtW:RFM69:write register, reg=0x39, value=255
                        mysgw: FtW:RFM69:write register, reg=0x3a, value=255
                        mysgw: FtW:RFM69:write register, reg=0x3c, value=5
                        mysgw: FtW:RFM69:write register, reg=0x3d, value=16
                        mysgw: FtW:RFM69:write register, reg=0x6f, value=48
                        mysgw: FtW:RFM69:write register, reg=0x07, value=217
                        mysgw: FtW:RFM69:write register, reg=0x08, value=0
                        mysgw: FtW:RFM69:write register, reg=0x09, value=0
                        mysgw: FtW:RFM69:read register, reg=0x27, value=128
                        mysgw: FtW:RFM69:read register, reg=0x3d, value=16
                        mysgw: FtW:RFM69:write register, reg=0x11, value=87
                        mysgw: FtW:RFM69:read register, reg=0x02, value=0
                        mysgw: FtW:RFM69:read register, reg=0x03, value=2
                        mysgw: FtW:RFM69:read register, reg=0x04, value=64
                        mysgw: FtW:RFM69:read register, reg=0x05, value=3
                        mysgw: FtW:RFM69:read register, reg=0x06, value=51
                        mysgw: FtW:RFM69:read register, reg=0x30, value=101
                        mysgw: FTW attachInterrupt: gpioPin=25 mode=3
                        mysgw: FtW:RFM69:write register, reg=0x39, value=0
                        mysgw: FtW:RFM69:write register, reg=0x25, value=64
                        mysgw: FtW:RFM69:write register, reg=0x13, value=26
                        mysgw: FtW:RFM69:write register, reg=0x5a, value=85
                        mysgw: FtW:RFM69:write register, reg=0x5c, value=112
                        mysgw: FtW:RFM69:write register, reg=0x3d, value=20
                        mysgw: FtW:RFM69:write register, reg=0x01, value=16
                        mysgw: MCO:BGN:STP
                        mysgw: New connection from 127.0.0.1
                        mysgw: Client 0 connected
                        mysgw: Client 0: 0;0;3;0;2;
                        mysgw: gatewayTransportAvailable
                        mysgw: Client 0: 0;0;3;0;2;Get Version
                        mysgw: Client 0: 0;0;3;0;18;PING
                        • F
                          F
                          ftw64
                          Can't get the RFM69HW to work on RPI. I tried the following:
                          1. I installed on an old RPI1 (clean Rasbian install). Same results as on my Domoticz RPI-3.
                          2. Setup the original RPI3 as a node, using the 2.2.0-beta code. I verified that in this case the RFM69HW actually transmits (I can hear it burst on 868.000 MHz). However, it is unable to connect to an existing Arduino 2.1.1 gateway.
                          3. I built an Arduino 2.2.0-beta serial gateway. Even then, the RPI as a node fails to connect to the 2.2.0-beta serial gateway.
                          4. I built an Arduino 2.2.0-beta node. This node is able to connect to the above gateway.
                          There seems to be something different in the radio network between the RFM69HW on the RPI and the RFM69HW on the Arduino. But I'm unable to find out what the difference is :-(.
                          The RPI RFM69HW will not communicate with the Arduino RFM69HW. When the RPI is a gateway, the RFM69HW will not physically interrupt when another node is trying to connect. When the RPI is a node, the RFM69HW on the ARduino does not interrupt either.
                          Did anyone get the RFM69HW working on the RPI? I'd really like to get this beautiful piece of code working!
                            I have to ask a stupid question : did you use a logic converter between rpi and rfm69 radio?
                              F
                              F
                              ftw64
                              @gohan There are no stupid questions, right :-)? But perhaps a stupid answer: no, I did not use any logic convertors. The RFM69 is 3.3V and as far as I know, so are the GPIO pins on the RPI. But I might be mistaken, of course... Should I use logic convertors?
                              At the moment I have no idea where it fails. Perhaps I need to give it a rest for a couple of days to think it over...
                              I followed the steps as given on the web site (git branch development). Connected the RFM radio (7 wires: Vcc, GND, MOSI, MISO, SCK, NSS, DI00). Only modified MyConfig.h with regard to the NETWORKID (100 --> 101; my 'production' MySensors runs at 100) and enabling "MY_DEBUG_VERBOSE_RFM69". I configured with:
                              % ./configure --my-debug=enable --my-config-file=/usr/local/etc/mysensors.dat --my-gateway=ethernet --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw
                              % make -j 4
                              % sudo bin/mysgw -d
                                The gpio pins on raspberry pi are 3.3V. https://raspberrypi.stackexchange.com/questions/3209/what-are-the-min-max-voltage-current-values-the-gpio-pins-can-handle
                                • F ftw64
                                  % make -j 4
                                  % sudo bin/mysgw -d
                                  #436
                                  @ftw64 that configure command looks like an ethernet gateway. Could you post the configure command for your "RPI as a node" as well?
                                    marceloaqno
                                    Code Contributor
                                    I forgot to mention in the guide:
                                    To communicate with the RPi using the RFM69 radio, all of your nodes need to use the new RFM69 driver available in the development branch.
                                    To make the change, add the following line to the node sketch:
                                    #define MY_RFM69_NEW_DRIVER
                                    gohanG 1 Reply Last reply
                                    • M marceloaqno
                                      @marceloaqno you forgot just a little little insignificant detail ๐Ÿ˜‚
                                        marceloaqno
                                        Code Contributor
                                        @gohan @ftw64 sorry for all the trouble
                                          It's OK, don't worry. We need to update the guide with the new instructions ๐Ÿ˜€
                                          With your input, this post could be even better ๐Ÿ’—
