  2. Announcements
  • Richard van der PlasR
    Damn, just connected as in manual, but gives an error : mysgw: !TSM:INIT:TSP FAIL
    Double checked the GPIO pins (except 15 cannot find that one) but seems ok
      NM, used GPIO numbers instead of Pin numbers RTFM :)
        A Former User
        wrote on last edited by [[global:former-user]]
        #463
        I always have a mysgw: accept: Bad file descriptor error when I launch a new ./bin/mysgw -d Exact problem is the following:
        mysgw: bind: Address already in use
        mysgw: Failed to bind!
        And I always need to kill the process first. Is this normal ? (I'm in LAN GW)
        Thanks!
          If you already installed mysgw as service to start at boot, it is normal that you can not run another process in debug mode and it conflicts
            A Former User
            @gohan said in 💬 Building a Raspberry Pi Gateway:
            Oh, Ok. Thanks.
            Another thing is that when i close PuTTY, the gateway doesn't retrieve anymore the data...
              You need to install it as service so it always runs in background
                A Former User
                Is it this process :
                1421 ?        Rs    40:25 /usr/local/bin/mysgw
                Seems it runs for 40 minutes, but no the gateway sees no data...
                  what gateway did you compile? What option in ./configure did you use?
                    A Former User
                    #469
                    First of all : thanks for helping !
                    I compiled an Ethernet gateway
                    The options are the following:
                    ./configure --my-gateway=ethernet --my-port=5003 --my-rf24-irq-pin=15 --my-transport=nrf24
                    The only way I make the GW working is through the debug mode (by switching off the service process)
                      A Former User
                      Hello, it seems I found the problem: Complete newbie thing: :beginner:
                      sudo ./bin/mysgw -h worked, but /usr/local/bin/mysgw didn't
                      I just gave the right to the folder, and now it's working.
                      Thanks for taking time to help beginners !
                      cadetC 1 Reply Last reply
                      • S
                        sillicius
                        @Richard van der Plas : i was have the same error with my raspberry zero. I have succed with the devellopement branch version...
                        • G
                          G
                          gdekeijzer
                          Trying to setup a Rpi1, as i got one lying around here.
                          All work untill i want to 'make'
                          Generates an error:
                          pi@mysgw:~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-irq-pin=15
                          [SECTION] Detecting target machine.
                            [OK] machine detected: SoC=BCM2835, Type=rpi1, CPU=armv6l.
                          [SECTION] Detecting SPI driver.
                            [OK] SPI driver detected:BCM.
                          [SECTION] Detecting init system.
                            [OK] init system detected: systemd.
                          [SECTION] Saving configuration.
                          [SECTION] Cleaning previous builds.
                          [OK] Finished.
                          pi@mysgw:~/MySensors $ make
                          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                          g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                          g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                          g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                          g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                          g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                          g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                          g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                          g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                          g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                          g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                          g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                          g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                          g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi1\" -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                          In file included from ./MySensors.h:109:0,
                                           from examples_linux/mysgw.cpp:83:
                          ./hal/architecture/MyHwLinuxGeneric.cpp: In function ‘ssize_t hwGetentropy(void*, size_t)’:
                          ./hal/architecture/MyHwLinuxGeneric.cpp:79:17: error: ‘SYS_getrandom’ was not declared in this scope
                            return syscall(SYS_getrandom, __buffer, __length, GRND_NONBLOCK);
                          ./hal/architecture/MyHwLinuxGeneric.cpp:79:52: error: ‘GRND_NONBLOCK’ was not declared in this scope
                          ./hal/architecture/MyHwLinuxGeneric.cpp:80:1: warning: control reaches end of non-void function [-Wreturn-type]
                          Makefile:98: recipe for target 'build/examples_linux/mysgw.o' failed
                          make: *** [build/examples_linux/mysgw.o] Error 1
                          Has this to do with a limitation of Rpi being v1?
                          Regards
                          Gerwin
                          M 1 Reply Last reply
                          • G gdekeijzer
                            Generates an error:
                            [OK] Finished.
                            Regards
                            Gerwin
                            marceloaqno
                            Code Contributor
                            #473
                            @gdekeijzer There was a recent update on the random number generator for the RPi port, but unfortunately not all linux versions support the new method. @d00616 is working on a solution to this problem #856. Please use the master branch for the time being.
                            • G
                              G
                              gdekeijzer
                              Ah great. Thanx for the response. I'll go try that for now.
                              • G
                                G
                                gdekeijzer
                                Installed master branche. That did the job. Thanx.
                                • Luc3asL
                                  Luc3asL
                                  Luc3as
                                  wrote on last edited by Luc3as
                                  #476
                                  Hello, did anyone tried gateway on pi with RS485 wired network ? It looks like node with ID set is looking for parrent and gateway does not respond to the node and therefore there is no succesfull presentation.
                                  example from GW mysgw:
                                  TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:MSG:FPAR REQ,ID=5
                                  mysgw: TSF:PNG:SEND,TO=0
                                  mysgw: TSF:CKU:OK
                                  mysgw: TSF:MSG:GWL OK
                                  mysgw: TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:CKU:OK,FCTRL
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:MSG:BC
                                  and from node :
                                  0 MCO:BGN:INIT NODE,CP=RSNNA--,VER=2.1.1
                                  3 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  5 TSM:INIT:TSP OK
                                  7 TSM:INIT:STATID=5
                                  9 TSF:SID:OK,ID=5
                                  10 TSM:FPAR
                                  27 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2035 !TSM:FPAR:NO REPLY
                                  2037 TSM:FPAR
                                  2055 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  4063 !TSM:FPAR:NO REPLY
                                  4065 TSM:FPAR
                                  4082 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  6090 !TSM:FPAR:NO REPLY
                                  6092 TSM:FPAR
                                  6110 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  8118 !TSM:FPAR:FAIL
                                  8119 TSM:FAIL:CNT=1
                                  Luc3asL 1 Reply Last reply
                                  • Luc3asL Luc3as
                                    mysgw: TSF:MSG:BC
                                    mysgw: TSF:CKU:OK
                                    mysgw: TSF:MSG:BC
                                    mysgw: TSF:MSG:BC
                                    mysgw: TSF:MSG:BC
                                    and from node :
                                    3 TSM:INIT
                                    4 TSF:WUR:MS=0
                                    5 TSM:INIT:TSP OK
                                    7 TSM:INIT:STATID=5
                                    9 TSF:SID:OK,ID=5
                                    10 TSM:FPAR
                                    2037 TSM:FPAR
                                    4065 TSM:FPAR
                                    6092 TSM:FPAR
                                    8118 !TSM:FPAR:FAIL
                                    8119 TSM:FAIL:CNT=1
                                    Luc3asL
                                    Luc3asL
                                    Luc3as
                                    @Luc3as Okay, Again I found answer while after asking, I used dev branch of mysensors and it is working like a charm.
                                    • Z
                                      Z
                                      zavracky
                                      I am a novice, trying to get the raspberry pi gateway to work. I did get it to work on one pi, but while installing it on the second, it produces the following error:
                                      In file included from examples_linux/mysgw.cpp:74:0:
                                      ./MySensors.h:254:2: error: #error No support for nRF24 radio on this platform
                                      In file included from ./drivers/RF24/RF24.cpp:23:0,
                                      from ./MySensors.h:290,
                                      ./drivers/RF24/RF24.h:52:17: fatal error: SPI.h: No such file or directory
                                      I can see that the SPI.h library is among the files downloaded.
                                      Any ideas?
                                      Paul
                                        what raspberry version is that? What library version did you download?
                                        Z 1 Reply Last reply
                                        • Luc3asL
                                          Luc3asL
                                          Luc3as
                                          do you have SPI enabled through raspi-config ?
