  2. Announcements
  • P pandy
    Hi and sorry for the question..
    I have been trying to build a gateway with a raspberry pi 1 and a radio module nrf24 + for several days without success. .I am analyzing step by step what I can be wrong..
    You can kindly indicate the exact command syntax ./configure I have to give?
    thank you so much
    sineverba
    @pandy
    On pi1 I cannot get a stable and re-doable configuration. See some post before.
    I finally swith to Arduino connected via USB. WOrks like a charme. Probably an issue with PI1.
    • P pandy
      The result of the "make" command is very long ..
      P
      P
      pandy
      the result of sudo ./bin/mysgw -d is :
      mysgw: Starting gateway...
      mysgw: Protocol version - 2.2.0-beta
      and it blocks..
      gohanG S 2 Replies Last reply
      • P pandy
        and it blocks..
        @pandy that's definitely a problem. What linux are you using?
        • P pandy
          and it blocks..
          sineverba
          @pandy Same my problem.
          @gohan I did try also the DIETPI, how you did suggest to me some days ago. Only to say to @pandy let down the idea to use PI1. Use arduino usb/serial with your PI1.
          I did use several nights.... :(
          P 1 Reply Last reply
          • P
            P
            pandy
            Thanks to everyone for the answers and suggestions...
            At this point I think the problem is the raspberry type..
            I will try the suggested solution above otherwise I will be forced to change raspberry ..
            Thanks to everyone for help
            gohanG 1 Reply Last reply
            • S sineverba
              P
              P
              pandy
              @sineverba thank you for your suggestion..Do you have a link where I can find a tutorial for this system?
              thank you so much
              • P pandy
                @pandy go for a new rpi3 that works very well.
                • Velo17V
                  Velo17V
                  Velo17
                  Hello everyone!
                  I am trying to use a NRF24 module on the SPI1 of a Raspberry2 (so that I can also use a touch tft on SPI0).
                  I enabled it in the config.txt so that is lists under /dev/spidev1.0 - for conveniency I configured the CS0 to be at GPIO16=Pin36 (by using dtoverlay=spi1-1cs,cs0_pin=16).
                  I use the dev branch of MySensors.git as the master branch does not recognize my Pi. I used this configure line:
                  ./configure --my-rf24-channel=124 --my-rf24-irq-pin=29 --my-rf24-ce-pin=31 --my-rf24-cs-pin=36 --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev1.0
                  successful make
                  but when I run the gateway in the shell with sudo ./bin/mysgw -d, I get the following:
                   __  __       ____
                          |___/                      2.2.0-beta
                  mysgw: MCO:BGN:INIT CP=RNNG--Q-
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: pinMode: invalid pin: 29
                  mysgw: pinMode: invalid pin: 31
                  mysgw: pinMode: invalid pin: 36
                  mysgw: digitalWrite: invalid pin: 31
                  mysgw: digitalWrite: invalid pin: 36
                  mysgw: digitalPinToInterrupt: invalid pin: 29
                  Any ideas what I can do to make it work?
                  Velo17V 1 Reply Last reply
                  • Velo17V Velo17
                    Hello everyone!
                    successful make
                     __  __       ____
                            |___/                      2.2.0-beta
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    Velo17V
                    Velo17V
                    Velo17
                    wrote on last edited by Velo17
                    #549
                    I think I might have found the root of the problem. The ./configure detects my Rpi2 as such (rpi2) but in the RPi.cpp in line 26 there is the pin to GPIO translation array and it is lacking translations for the high pin numbers - which is obviously wrong as on the RPi2 you have the extended GPIO connector with 40 pins...
                    const static int pin_to_gpio_rev1[41] = {-1, -1, -1, 0, -1, 1, -1, 4, 14, -1, 15, 17, 18, 21, -1, 22, 23, -1, 24, 10, -1, 9, 25, 11, 8, -1, 7, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1 };
                    const static int pin_to_gpio_rev2[41] = {-1, -1, -1, 2, -1, 3, -1, 4, 14, -1, 15, 17, 18, 27, -1, 22, 23, -1, 24, 10, -1, 9, 25, 11, 8, -1, 7, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1 };
                    const static int pin_to_gpio_rev3[41] = {-1, -1, -1, 2, -1, 3, -1, 4, 14, -1, 15, 17, 18, 27, -1, 22, 23, -1, 24, 10, -1, 9, 25, 11, 8, -1, 7, -1, -1, 5, -1, 6, 12, 13, -1, 19, 16, 26, 20, -1, 21 };
                    I copied the rev3 array to the rev2 array and compiled this and it seems to work in my case!
                    W 1 Reply Last reply
                    • Velo17V Velo17
                      W
                      W
                      wergeld
                      @Velo17 Thank you! I had been pulling my hair out over this issue on installing a new RPi2 setup.
                        Adding link to the github issue (thanks for creating!) for future reference
                        https://github.com/mysensors/MySensors/issues/895
                        • Velo17V
                          Velo17V
                          Velo17
                          I just noticed that mysgw is constantly consuming 95-100% CPU here. This even happens when I unplug the NRF24 module so that after starting mysgw basically nothing happens. Running development branch. Hmmmm. Any idea what to check?
                          • Velo17V Velo17
                            #553
                            @Velo17 strace might be able to help:
                            sudo strace ./bin/mysgw -d
                            Could you post your configure command? I'd like to try to reproduce the problem. I have a gateway with development from git as of about 2 weeks ago (a9418271) but I'm not using the nrf24. That gateway uses about 2% cpu on my Raspberry Pi 1. There have only been 6 commits since I built my gateway but I can update it and see if it starts acting up.
                            On my gateway, strace outputs loads and loads of these:
                            gettimeofday({1501098316, 668956}, NULL) = 0
                            ioctl(6, FIONREAD, [0])                 = 0
                            gettimeofday({1501098316, 671383}, NULL) = 0
                            gettimeofday({1501098316, 672447}, NULL) = 0
                            gettimeofday({1501098316, 673818}, NULL) = 0
                            nanosleep({0, 10000000}, NULL)          = 0
                            gettimeofday({1501098316, 685602}, NULL) = 0
                            getsockopt(6, SOL_TCP, TCP_INFO, "\1\0\0\0\0\7g\1P4\3\0@\234\0\0\250\5\0\0\30\2\0\0\0\0\0\0\0\0\0\0"..., [104]) = 0
                            gettimeofday({1501098316, 689179}, NULL) = 0
                            Also, which git hash are you using? (git log -1)
                            Another thing to try could be to enable all the debug flags in MyConfig.h and see if they give you something interesting.
                              I updated my gateway to 10ef623 (latest from git). Still works ok.
                                Velo17V
                                Velo17V
                                Velo17
                                @mfalkvidd I make / make install a couple of times and maybe did a git pull inbetween as well - now everything is back to normal again. Thank you for giving me some dbug tips for the next issue :-)
                                My strace output looks similiar.
                                My configure line is
                                ./configure --my-rf24-channel=124 --my-rf24-irq-pin=29 --my-rf24-ce-pin=31 --my-rf24-cs-pin=36 --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev1.0 --my-debug=disable
                                • Sergio RiusS
                                  Sergio RiusS
                                  Sergio Rius
                                  Should be possible to connect two radio modules and run two instances at the same time?
                                  It could be interesting to have a hat with nrf+rfm, all in one.
                                  • Sergio RiusS Sergio Rius
                                    #557
                                    @Sergio-Rius it would be great if you could contribute to making that a reality.
                                    An earlier discussion on the same topic: https://forum.mysensors.org/topic/4151/nrf24l01-and-rfm69-on-one-gw/
                                    So far, people have found it easier to add a separate gateway for each transport.
                                    Sergio RiusS 1 Reply Last reply
                                      Sergio RiusS
                                      Sergio RiusS
                                      Sergio Rius
                                      wrote on last edited by Sergio Rius
                                      #558
                                      @mfalkvidd thanks for guiding me on the starting point. Perhaps the raspberry can break the doble transport limitation.
                                      I'll investigate in how to install two services at once. But it'll would be nice any advice on the device virtualization part.
                                        Another thread: https://forum.mysensors.org/topic/2331/gateway-with-both-rfm69-and-nrf24l01/
                                          Maybe it could be as simple as running two instances of mysgw, using different pins for the nrf and the rfm?
