  2. Announcements
  3. 💬 Dimmable LED Actuator
59 Posts 27 Posters 31.0k Views 27 Watching
    @Creaky the dimmer uses PWM to control the light level, so the mosfet is always either in cutoff or fully saturated. So using IRLz44N with 5V will work just as well as 3.3V.
    C Offline
    C Offline
    Creaky
    @mfalkvidd Thanks for the reply!
      C Offline
      C Offline
      Creaky
      @mfalkvidd Just so you know, there is no PWM involved in this sketch. I've just build this setup/node and it works great. You can see that the LED are continuously fed and brightness is changed by changing the voltage to the LEDs through the MOSFET.
      • C Creaky
        mfalkviddM Online
        mfalkviddM Online
        #23
        @Creaky the sketch linked in the first post uses pwm. But you might be using some other sketch?
        C 1 Reply Last reply
        • riochickenR Offline
          riochickenR Offline
          riochicken
          It might be a very nice idea to use neopixels with this, a little expensive though when using a lot of LED's but still it's possible to dim them just by using code.. I am afraid I am not able to do that and it was just a small thought... :)
            C Offline
            C Offline
            Creaky
            wrote on last edited by Creaky
            #25
            @mfalkvidd Yikes, you're right! I drew my conclusion too soon and only by watching the LED strip at max brightness. At max brightness the switching frequency is so high it is no longer perceptible by the eye. Mea culpa...
            • C Creaky
              mfalkviddM Online
              mfalkviddM Online
              @Creaky yes the switching is pretty quick. I guess that's the whole idea :) I have noticed a refraction pattern in the kitchen sink when using a thin jet of water though.
              The analogWrite function in Arduino is very poorly named, since it doesn't really write an analog value. But I guess it is hard to change now.
              • A Offline
                A Offline
                antonholmstedt
                I plan to use a LED strip as a closet light, controlled by a magnetic door switch, and of course also controllable in Domoticz. What would be the right way to write the code, should the pro mini send the state of the magnetic switch to the controller and then let the controller turn on the light, or is it easier to let the pro mini turn on the light directly and then report the state back to the controller? Big difference in delay?
                • A Offline
                  A Offline
                  antonholmstedt
                  It's a closet with two sliding doors and therefore two magnetic switches, and I want the LED to turn on when opening one of the doors, but also be able to turn it off remotely if we forgot to close it when leaving our home.
                  • boblasureB Offline
                    boblasureB Offline
                    boblasure
                    I would like to use this with a 48 Watt led which uses a constant-current power supply 54 - 87 VDC 600 ma output. This mosfet isn't high enough voltage rating, the IRF630MFP is rated at 200V 9amp, however I have questions about if the uC output will power the gate. The gate-source voltage is +/- 20. The VGS(th) gate threshold voltage is 2 to 4 volts with typ 3V. I would cut the negative from the power supply and connect to source, then connect the Led negative to drain, and connect the drain to ground on the uC? I need a reality check- does this sound possible or will I fry something?
                    • WieselW Offline
                      WieselW Offline
                      Wiesel
                      I'm new in MySensors and build this Dimmer - LED with and without the rotary encoder which works fine.
                      Now I would like to decouple the rotary encoder as a battery powered "standalone" sensor which is (in best case) connected directly to the LED-Dimmer. Furthermore the decoupled rotary encoder should be always in sleep mode until the rotary encoder awake the arduino.
                      Is that possible ? I'm just stuck to seperate the code for the rotary encoder from the led-dimmer code.
                      Thank you in advance.
                      • J Offline
                        J Offline
                        joschre
                        hi, i used the example sketch. i also changed from "delay" to "wait" in fade section. The problem: i can change the percentage for example 8 times and then the gateway crashes and reboots. In a other case it works 12 times and then the gateway crashes. All other nodes (Temp, Hum) works fine all the time.
                        • J Offline
                          J Offline
                          joschre
                          oh, i use mysensors serial gateway connected to a raspberry with fhem running.
                          • J joschre
                            mfalkviddM Online
                            mfalkviddM Online
                            @joschre could you post the debug output from the node?
                            • J Offline
                              J Offline
                              joschre
                              Problem solved! The 3.3v Form arduino nano was too Bad for the nrf24l01j pa lna with PA_LEVEL MAX. NOW i usw an external regulator an everything is fine :-) sorry for this newbie fault :-D
                              • J joschre
                                mfalkviddM Online
                                mfalkviddM Online
                                @joschre great that you found a solution. Thank for reporting back.
                                • U Offline
                                  U Offline
                                  user2684
                                  Hi, I've noticed the V_DIMMER of the example is not (anymore?) available in https://www.mysensors.org/download/serial_api_20, am I wrong? Thanks
                                  • U user2684
                                    mfalkviddM Online
                                    mfalkviddM Online
                                    #37
                                    @user2684 you're right. I think it is supposed to be S_DIMMER (S_ is used for presentation)
                                    • LacesL Offline
                                      LacesL Offline
                                      Laces
                                      Dear Guys,
                                      How can I control an RGB ledstrip with this config may I add more MOSFAT or how ?
                                      Thank you very much.
                                      L
                                      K 1 Reply Last reply
                                      • LacesL Laces
                                        Dear Guys,
                                        L
                                        K Offline
                                        K Offline
                                        korttoma
                                        @Laces yes you can. The principal is the same, just one mosfet per channel.
                                        Search the forum for RGB or RGBW and you sould be able to find some examples.
                                        • Tomas
                                        • PlantexP Offline
                                          PlantexP Offline
                                          Plantex
                                          This post is deleted!
