  2. Announcements
  3. 💬 Motion Sensor
💬 Motion Sensor
63 Posts 30 Posters 33.6k Views 31 Watching
    Just make sure the power source is stable otherwise you will end up with random triggers from pir sensor
    ben999B 1 Reply Last reply
      ben999B
      ben999B
      ben999
      @gohan @maghac
      From my little experience : when running from 2 AA batteries with sketch as it is I got random triggers continuousely
      Adding a delay() before entering sleep() sorted things out (something like 3 sec is necessary to get power stable again)
      Not sure it's the smartest way of doing it, but it works...
      Any comment on the security side of it? Could my node miss some action during these 3 sec ? Or the interrupt pin would still listen to the PIR sensor pin ?
        I think it will miss the pir trigger
          ben999B
          ben999B
          ben999
          @gohan
          Thank you for your reply
          Could you please explain a bit further ?
          Interrupt pin would still read the trigger during delay()?
          Data would be lost as the sketch is frozen during delay() ?
          Or data is saved in some buffer, ready to be used as soon as sketch comes back to life ?
          My view is that it shouldn't matter too much if i miss a trigger after a trigger : the first trigger will wake my node and transmit to gateway. So job done. Alarm goes off.
          On the other hand, I guess a millis() would be neater ?
          Thanks a lot for your input
            I am saying that during delay no code is executed and interrupt only attaches to pin when executing the sleep function, so if motion if triggered during the delay it will not be detected by interrupt; maybe it could detect the CHANGE when pir goes from high to low but it will then report "no motion" and it will not trigger alarm if it set to go off on "motion" only.
              ben999B
              ben999B
              ben999
              @gohan
              Thanks a lot
              Got it now
              delay() to be avoided then !
              I will have a look at millis() instead
                Delay is not bad, depends how you use it. Maybe you could use an if statement to check pin state is low before entering sleep
                • skywatchS
                  skywatchS
                  skywatch
                  Millis won't work with the SLEEP funtion either. REcently added to the API....
                  • siodS
                    siodS
                    siod
                    Hi, I´ve read this above
                    "however this sensor requires 5 VDC so you will need to use a step-up regulator if you are running the 3.3V version of the Arduino Pro Mini."
                    So I am using 3 V, could you propose a fitting step up regulator so I can use this PIR (best from ebay)? Thank you!
                    still learning...
                    maghacM 1 Reply Last reply
                    • siodS siod
                      maghacM
                      maghacM
                      maghac
                      @siod said in 💬 Motion Sensor:
                      a
                      You have a HC-SR501 sensor? I had that same question before and then I realized that the HC-SR501 actually has a 3.3 V regulator and if you bypass it you can run it on 3.3V.
                        If I wanted to add two PIRs to one sensor-node would this sketch work?
                         * Version 1.0 - Henrik Ekblad
                         * Motion Sensor example using HC-SR501
                         * http://www.mysensors.org/build/motion
                        // Enable debug prints
                        // #define MY_DEBUG
                        #define DIGITAL_INPUT_SENSOR_1 2
                        #define DIGITAL_INPUT_SENSOR_2 3  // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                        #define CHILD_ID_1 1   // Id of the sensor child
                        #define CHILD_ID_2 2   // Id of the sensor child
                        // Initialize motion message
                        MyMessage msg(CHILD_ID_1, V_TRIPPED);
                            pinMode(DIGITAL_INPUT_SENSOR_1, INPUT);      // sets the motion sensor digital pin as input
                            pinMode(DIGITAL_INPUT_SENSOR_2, INPUT);      // sets the motion sensor digital pin as input
                            sendSketchInfo("Motion Sensor_Dual", "1.0");
                            present(CHILD_ID_1, S_MOTION);
                            present(CHILD_ID_2, S_MOTION);
                            // Read digital motion value
                            bool tripped_1 = digitalRead(DIGITAL_INPUT_SENSOR_1) == HIGH;
                            bool tripped_2 = digitalRead(DIGITAL_INPUT_SENSOR_2) == HIGH;
                            Serial.println(tripped_1 || tripped_2);
                            if(tripped_1){
                            send(msg.set(tripped_1?"1":"0"));  // Send tripped value to gw
                            if(tripped_2){
                            send(msg.set(tripped_2?"1":"0"));  // Send tripped value to gw
                            sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_1 || DIGITAL_INPUT_SENSOR_1), CHANGE, SLEEP_TIME);
                        I know PIN 2 is supposed to be connected to the radio but I read somewhere that it is not used.
                        sellierS
                        sellierS
                        sellier
                        wrote on last edited by gohan
                        #51
                        @Cliff-Karlsson
                        For dual Sensors
                        one error is present on the line sleep:
                        it is not : sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_1 || DIGITAL_INPUT_SENSOR_1), CHANGE, SLEEP_TIME);
                        but : sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_1 )|| digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_2), CHANGE, SLEEP_TIME);
                          MCF
                          hi,
                          i want to ad a motion sensor to my project (3 dimmers on a arduino uno using nrf24).
                          My first problem is that the 2 and 3 pins are not available (nrf24 and pwm dimmer), so i will take the pin 1 for testing
                          second is the sleeping time during i can't send any light message to my dimmers...
                            MCF
                            this is my code
                             * Version 1.0 - February 15, 2014 - Bruce Lacey
                             * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
                             * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
                             * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
                             * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
                             * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
                             * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
                             * to the LED negative terminal and the MOSFET Source pin is connected to ground.
                             * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
                             * http://www.mysensors.org/build/dimmer
                             * LISTE DE POINTS:
                             * D0  DISPO
                             * D1  MOTION
                             * D2  IRQ NRF
                             * D3  LED1
                             * D4  DISPO
                             * D5  LED2
                             * D6  LED3
                             * D7  DISPO
                             * D8  DISPO
                             * D9  CE NRF
                             * D10 CSN/CS NRF
                             * D11 MOSI NRF
                             * D12 MISO NRF
                             * D13 SCK NRF
                             * D14 DISPO
                            //#define MY_NODE_ID 153
                            #define SN "BUREAU PARENTS"
                            #define SV "1.2"
                            #define noLEDs 3
                            const int LED_Pin[] = {3, 5, 6};
                            #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                            static int currentLevel1 = 0;  // Current dim level...
                            static int currentLevel2 = 0;  // Current dim level...
                            static int currentLevel3 = 0;  // Current dim level...
                            MyMessage dimmer1Msg(1, V_DIMMER);
                            MyMessage light1Msg(1, V_LIGHT);
                            MyMessage dimmer2Msg(2, V_DIMMER);
                            MyMessage light2Msg(2, V_LIGHT);
                            MyMessage dimmer3Msg(3, V_DIMMER);
                            MyMessage light3Msg(3, V_LIGHT);
                            // MOTION SENSOR
                            uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                            #define DIGITAL_INPUT_SENSOR 1   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                            #define CHILD_ID 4   // Id of the sensor child
                             * Dimmable LED initialization method
                              // LEDS
                              // Pull the gateway's current dim level - restore light level upon sendor node power-up
                            for (int sensor=1; sensor<=noLEDs; sensor++){
                              request( sensor, V_DIMMER );
                             // MOTION
                            void presentation() {
                             present(sensor, S_DIMMER);
                             wait(2);
                              // MOTION
                              present(CHILD_ID, S_MOTION);
                              sendSketchInfo(SN, SV);
                             *  Dimmable LED main processing loop
                                bool tripped = digitalRead(DIGITAL_INPUT_SENSOR)== HIGH;
                                Serial.println("coucou");
                                Serial.println(tripped);
                                send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                                sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                              if (message.type == V_LIGHT || message.type == V_DIMMER) {
                                if (message.sensor == 1) {
                                int requestedLevel1 = atoi( message.data );
                                requestedLevel1 *= ( message.type == V_LIGHT ? 100 : 1 );
                                // Clip incoming level to valid range of 0 to 100
                                requestedLevel1 = requestedLevel1 > 100 ? 100 : requestedLevel1;
                                requestedLevel1 = requestedLevel1 < 0   ? 0   : requestedLevel1;
                                 fadeToLevel1( requestedLevel1, message.sensor );
                                send(light1Msg.set(currentLevel1 > 0 ? 1 : 0));
                                send(dimmer1Msg.set(currentLevel1) );}
                               if (message.sensor == 2) {
                                int requestedLevel2 = atoi( message.data );
                                requestedLevel2 *= ( message.type == V_LIGHT ? 100 : 1 );
                                requestedLevel2 = requestedLevel2 > 100 ? 100 : requestedLevel2;
                                requestedLevel2 = requestedLevel2 < 0   ? 0   : requestedLevel2;
                                fadeToLevel2( requestedLevel2, message.sensor );
                                send(light2Msg.set(currentLevel2 > 0 ? 1 : 0));
                                send(dimmer2Msg.set(currentLevel2) );}
                                if (message.sensor == 3) {
                                int requestedLevel3 = atoi( message.data );
                                requestedLevel3 *= ( message.type == V_LIGHT ? 100 : 1 );
                                requestedLevel3 = requestedLevel3 > 100 ? 100 : requestedLevel3;
                                requestedLevel3 = requestedLevel3 < 0   ? 0   : requestedLevel3;
                                 fadeToLevel3( requestedLevel3, message.sensor );
                                send(light3Msg.set(currentLevel3 > 0 ? 1 : 0));
                                send(dimmer3Msg.set(currentLevel3) );}
                             *  This method provides a graceful fade up/down effect
                            void fadeToLevel1( int toLevel1, int ledid1 ) {
                              int delta1 = ( toLevel1 - currentLevel1 ) < 0 ? -1 : 1;
                              while ( currentLevel1 != toLevel1 ) {
                                currentLevel1 += delta1;
                                analogWrite(LED_Pin[ledid1-1], (int)(currentLevel1 / 100. * 255) );
                                wait( FADE_DELAY );
                            void fadeToLevel2( int toLevel2, int ledid2 ) {
                              int delta2 = ( toLevel2 - currentLevel2 ) < 0 ? -1 : 1;
                              while ( currentLevel2 != toLevel2 ) {
                                currentLevel2 += delta2;
                                analogWrite(LED_Pin[ledid2-1], (int)(currentLevel2 / 100. * 255) );
                                wait( FADE_DELAY );
                            void fadeToLevel3( int toLevel3, int ledid3 ) {
                              int delta3 = ( toLevel3 - currentLevel3 ) < 0 ? -1 : 1;
                              while ( currentLevel3 != toLevel3 ) {
                                currentLevel3 += delta3;
                                analogWrite(LED_Pin[ledid3-1], (int)(currentLevel3 / 100. * 255) );
                                wait( FADE_DELAY );
                              Since it is a powered node, you don't need to put it to sleep. As for the pir you can do as you like: check pin status during loop, use an attach interrupt function on pin change, etc
                                MCF
                                @gohan ok thank you for answering. if i do this:
                                    //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                                the node never stop to send message to the gateway. i would like to send something only if D1 goes to high, is that possible ? (i'm starting combinating exemple and i want to understand what i do now!!)
                                • wesW
                                  wesW
                                  wes
                                  @siod The HC-SR501 actually runs on 3.3VDC but has a 5VDC-3.3VDC regulator on board.
                                  There are several ways to bypass this regulator, but the easiest is to connect your 3.3VDC supply to pin 3 of JP3 (the one marked "H").
                                  You must make sure that your 3.3VDC supply is very stable, otherwise you will get false activations.
                                  See:
                                  https://randomnerdtutorials.com/modifying-cheap-pir-motion-sensor-to-work-at-3-3v/
                                  https://www.youtube.com/watch?v=5jhTQAV-hg0
                                  https://www.mpja.com/download/31227sc.pdf
                                  Blog: https://www.wes.id.au/
                                  Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                                  Gateway & Controller: Raspberry Pi 3 + Home Assistant
                                  • joaoabsJ
                                    joaoabsJ
                                    joaoabs
                                    The code
                                    doesn't need a ISR (Interrupt Service Routine) function? Should we assume that if no ISR is defined, the node will wake in the loop function?
                                      Yes, it will wake and run the loop once
                                      • P
                                        P
                                        patrikr76
                                        So i was testing out the motionsensor sketch and it kept giving me "!TSF:MSG:SEND" after the initial 0 had been sent.
                                        Finding no answers on here i tested loads of things until i tried a delay after the sleep command.
                                        Running fine now with a 5msec delay.
                                        Just thought i would share.
                                          mitsured
                                          I connected a 12v DC input and no matter what I do the output always shows 12V. It never goes to a "low" 0V output. From what I read these can use between a 5v and 20v input so I'm assuming a 12v input should not be an issue and still produce a High when triggered and Low 0V when not triggered output. What am I doing wrong?
