  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 92.4k Views 37 Watching
  • asgardroA asgardro
    Done that... reset everything..still the same
    here is my code
    #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your light sensor. (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 1000 // Nummber of blinks per KWH of your meeter
    #define SLEEP_MODE false // Watt-value can only be reported when sleep mode is false.
    #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers.
    #define CHILD_ID 1 // Id of the sensor child
    unsigned long SEND_FREQUENCY = 5000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    bool pcReceived = true;
    volatile unsigned long watt = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    request(CHILD_ID, V_VAR1);
    // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
    // If no pullup is used, the reported usage will be too high because of the floating pin
    pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
    lastSend=millis();
    void presentation() {
    sendSketchInfo("Energy Meter", "1.0");
    present(CHILD_ID, S_POWER);
    unsigned long now = millis();
    bool sendTime = now - lastSend > SEND_FREQUENCY;
    if (pcReceived && (SLEEP_MODE || sendTime)) {
    // New watt value has been calculated
    if (!SLEEP_MODE && watt != oldWatt) {
    // Check that we dont get unresonable large watt value.
    // could hapen when long wraps or false interrupt triggered
    if (watt<((unsigned long)MAX_WATT)) {
    send(wattMsg.set(watt)); // Send watt value to gw
    Serial.print("Watt:");
    Serial.println(watt);
    oldWatt = watt;
    // Pulse cout has changed
    if (pulseCount != oldPulseCount) {
      send(pcMsg.set(pulseCount));  // Send pulse count value to gw
      double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
      oldPulseCount = pulseCount;
      if (kwh != oldKwh) {
        send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
        oldKwh = kwh;
    lastSend = now;
    } else if (sendTime && !pcReceived) {
    // No count received. Try requesting it again
    lastSend=now;
    if (SLEEP_MODE) {
    sleep(SEND_FREQUENCY);
    if (message.type==V_VAR1) {
    Serial.println(pulseCount);
    pcReceived = true;
    void onPulse()
    if (!SLEEP_MODE) {
    unsigned long interval = newBlink-lastBlink;
    if (interval<10000L) { // Sometimes we get interrupt on RISING
    return;
    watt = (3600000000.0 /interval) / ppwh;
    lastBlink = newBlink;
    pulseCount++;
    V
    V
    voxeg hult
    Banned
    @asgardro Thanks for your nice prompt feedback.
    • R
      R
      ramisthand76
      Banned
      Pulse Power Measurement: Measuring Instantaneous Power of a Short Pulse. ... Thermopile sensors are often used to measure single shot pulse energy;
      • K keithellis
        I've been building one of these pulse meters up, it seems to be working on the bench very nice. Just got to build a case and get a power supply of the Arduino. But I have designed a case to hold the LM393 sensor onto the meter. I removed the light sensor and re-soldered it flush to the board making it easier to mount on the meter. Its a simple box but works quite well.
        The files are on thingiverse here
        Hope this is useful.
        F
        F
        FredC
        @keithellis Lovely idea.
        I've followed suit and knocked up one but with the sensor facing the other way, so that it faces the meter, and the preset pot is and LEDs are facing away from the meter.
        That way the sensor side of the case can be stuck to the face of the meter, and the pot adjusted without removing it from the meter. The flashing light on DO flashes in sync with the LED on the meter. Theres a little ring that holds the sensor flush with the face of the case so it can lie flat on the front of the meter.
        Also, its a good idea to use black / dark coloured PLA so as to block out the any stray light that may illuminate the sensor (such as when the meter man comes to read it and shines a bright torch to see the dials).
