  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 92.4k Views 37 Watching
    If you send the watt reading faster it updates like the switch, anyway I need the watt values for node-red also
      Could it be the Light sensor is triggering more interrupts from each pulse?
      • NiklasON NiklasO
        Just changed from 1-wire counter to MySensors for logging my power consumption. Using the same LED detector as I did when using 1-wire. Also changed watt limit to 20 000 (my heat pump likes to use 9-10kW sometimes). The wires from the old 1-wire net now provide power for the new MySensors-sensor. I have 10 000 led blinks per kWh. Had som crazy counter values with 1-wire that totally messed up the graphs and haven't seen anything like that with this sketch. Let's hope it stays that way. ;) Dumping data to Domoticz. This sensor gives me higher resolution as a bonus. The 1-wire counter was read every minute, this every 20-sec. ;-)
        My old 1-wire counter with one crazy value messing upp all the graphs:
        I know that you can hold shift and click the value that is crazy to make the graphs show up good but you loose the data for the full day. That's not good. ;-)
        henninneH
        henninneH
        henninne
        @niklaso
        Hi Niklas,
        I know this is a very old post, but its worth a try. How did you get out the daily Kwh usage? As default my sensor only gives Watts and Kwh (accumulated from start), I have tried to run a Scene in Vera UI7 where there are a function in the sensor called resetKWh(), but it looks like it doesn't do anything. Any tips would be great, thanks.
        Henning
        • sundberg84S sundberg84
          @gohan - is Domoticz updating anything (except switches) faster than 5 min? I dont think so...
          smilvert
          @gohan I think it is a little tricky to update domoticz every minute but try update the sql-file, see the domoticz forum
          https://www.domoticz.com/forum/viewtopic.php?t=10183
            The main issue is the fact that the sensor is not calculating the instant power correctly
            xydixX 1 Reply Last reply
            • D
              D
              DaTim69
              I created this kWh sensor with the TCRT5000 IR Barrier Line Track Sensor.
              My powermeter is a ferarrismeter with 375 rotations per kWh.
              I also had the problem with spikes in the power usage. But after long...too long investigation I solved the problem.
              At my config it was a double issue.
              Issue 1.
              The problem is the pulse width of the rotation.
              The pulse are at night ( low power) much wider that during the day when more power is consumed. At night the spikes in power usage where huge.
              Issue 2.
              Switching on/off the halogen light causes spikes and related to also strange power measurement.
              Solution:
              I added a second arduino mini pro as a pulse regulator between the TCRT5000 and the power meter arduino.
              this arduino triggers on Rising and will always give a 100ms puls. Als debounce is handled (spikes).
              I don't upload the sketch here, I'm a beginning programmer on arduino. It's made on " trail and error" but it functions as it supposed to do.
              If someone wants a copy feel free to contact mee
                xydixX
                xydixX
                xydix
                @gohan Did you solve this?
                I get very high watt usage as well. Sometimes like 40 000 - 130 000 watt if I check the serial monitor.
                Of course, those values will never be sent to the controler.
                  Nope, I am looking at other things now. Very little time available for too many things. I'm looking at buying CT clamp and do a more direct measurement.
                  • xydixX
                    xydixX
                    xydix
                    wrote on last edited by xydix
                    #129
                    Okay. Really annoying. Check this.
                    Received last pulse count from gw:2527
                    Watt:121065
                    22235 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2539
                    22246 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5390
                    Watt:121621
                    42238 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2551
                    42250 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5510
                    Watt:121342
                    62239 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2563
                    62251 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5630
                    Watt:121539
                    82240 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2575
                    82251 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5750
                    Watt:121951
                    102239 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2589
                    102250 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.5890
                    Watt:122067
                    122243 TSF:MSG:SEND,78-78-0-0,s=3,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:2601
                    122254 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:2.6010
                    The plus count seems OK, right?
                    My energy meter is 1000 pluses /kwh
                    Here is my sketch. I use Home assistant so i created three sensors for this as I don't think V_VAR1 is supported with S_POWER.
                    Otherwise it is the standard example.
                     * Version 1.0 - Henrik EKblad
                     * This sketch provides an example how to implement a distance sensor using HC-SR04
                     * Use this sensor to measure KWH and Watt of your house meeter
                     * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                     * The sensor starts by fetching current KWH value from gateway.
                     * Reports both KWH and Watt back to gateway.
                     * Unfortunately millis() won't increment when the Arduino is in
                     * sleepmode. So we cannot make this sensor sleep if we also want
                     * to calculate/report watt-number.
                     * http://www.mysensors.org/build/pulse_power
                    // Enable debug prints
                    #define MY_NODE_ID 78
                    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                    #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
                    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                    #define MAX_WATT 20000          // Max watt value to report. This filetrs outliers.
                    #define WATT_CHILD_ID 1              // Id of the sensor child
                    #define KWH_CHILD_ID 2
                    #define PC_CHILD_ID 3
                    unsigned long SEND_FREQUENCY =
                        20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                    bool pcReceived = false;
                    volatile unsigned long watt = 0;
                    unsigned long oldWatt = 0;
                    double oldKwh;
                    unsigned long lastSend;
                    MyMessage wattMsg(WATT_CHILD_ID,V_WATT);
                    MyMessage kwhMsg(KWH_CHILD_ID,V_KWH);
                    MyMessage pcMsg(PC_CHILD_ID,V_VAR1);
                      request(PC_CHILD_ID, V_VAR1);
                      // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
                      // If no pullup is used, the reported usage will be too high because of the floating pin
                      pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                      lastSend=millis();
                      sendSketchInfo("Energy Meter", "1.0");
                      present(WATT_CHILD_ID, S_POWER);
                      present(KWH_CHILD_ID, S_POWER);
                      present(PC_CHILD_ID, S_CUSTOM);
                      unsigned long now = millis();
                      bool sendTime = now - lastSend > SEND_FREQUENCY;
                      if (pcReceived && (SLEEP_MODE || sendTime)) {
                        // New watt value has been calculated
                        if (!SLEEP_MODE && watt != oldWatt) {
                          // Check that we dont get unresonable large watt value.
                          // could hapen when long wraps or false interrupt triggered
                          if (watt<((unsigned long)MAX_WATT)) {
                            send(wattMsg.set(watt));  // Send watt value to gw
                          Serial.print("Watt:");
                          Serial.println(watt);
                          oldWatt = watt;
                        // Pulse cout has changed
                        if (pulseCount != oldPulseCount) {
                          send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                          oldPulseCount = pulseCount;
                          if (kwh != oldKwh) {
                            send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                            oldKwh = kwh;
                        lastSend = now;
                      } else if (sendTime && !pcReceived) {
                        // No count received. Try requesting it again
                        lastSend=now;
                      if (SLEEP_MODE) {
                        sleep(SEND_FREQUENCY);
                      if (message.type==V_VAR1) {
                        Serial.println(pulseCount);
                        pcReceived = true;
                    void onPulse()
                      if (!SLEEP_MODE) {
                        unsigned long interval = newBlink-lastBlink;
                        if (interval<10000L) { // Sometimes we get interrupt on RISING
                          return;
                        watt = (3600000000.0 /interval) / ppwh;
                        lastBlink = newBlink;
                      pulseCount++;
                    Anyone got any ideas?
                    BTW. First i tried the original example sketch, unmodified, with the same result.
                      That's pretty much the same problem as I have
                      • xydixX
                        xydixX
                        xydix
                        I think i solved this.
                        I don't know if it is a good solution.
                        Maybe it is possible to solve in the code?
                        I added a 0,1uf ceramic capacitor between DO and GND on the LM393.
                        Then i tuned the LM393 until i had it blink as expected.
                        I think, in my case the LED pulse from my meeter was to short, it gives a very short blink.
                        Anyway.
                        I tested it all day and it seems fine now.
                          Are you getting instant power measurements correct?
                          • xydixX
                            xydixX
                            xydix
                            #133
                            Yes. I guess.
                            I don't have anything to compare with but i think it is accurate.
                            I have a 1000blink/kwh
                            Example:
                            Node send state every 20 sec.
                            pulsecount: 8 pulses every 20 sec.
                            Instant power in W is about 1400W
                            8 pulses x 3 = pulses /minute =24
                            24 pulses x 60 min = pulses /hour = 1440.
                            Edit.
                            Now I get a new value every 20 sec, before I didn't get any value (W) from the node at all because it was too high. I only received pulse count and kWh earlier.
                              Besides the cap, what exactly did you do?
                              • xydixX
                                xydixX
                                xydix
                                Nothing more.
                                I use the same arduino, haven't uploaded anything new to it since i tried it last time.
                                What I had to do was lower the sensitivity on the LM393 because at first the signal-LED glowed a bit but when i adjusted it to lower sensitivity and closed the door to get it totaly dark the led blinked exactly as the meeter.
                                I have it on a bredboard and connected the cap between GND and to pin 3 so it is connected close to the arduino but i guess it shouldn't matter.
                                Have you tried it?
                                  I can't believe it, IT WORKS!!!!! I added the cap directly under the pins of the LM939 board. Thanks man!
                                  • xydixX
                                    xydixX
                                    xydix
                                    I am glad to hear it works for you too.
                                      There is probably a sw way to correct this problem, I'll think about it
                                      • xydixX
                                        xydixX
                                        xydix
                                        #139
                                        It waswhat I thought too.
                                        As I said earlier, when I tested this my conclusion was, short blink, almost a flash will counted as a pulse (kWh) but it does something wrong with the calculation of instant power usage.
                                        A slower blink will correct this.
                                        My meeter gives a very short blink.
                                          wrote on last edited by gohan
                                          #140
                                          Yes, could be that a simple debounce could do the trick but I'll have to look deeper into it. @Yveaux what do you think?
