  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 92.4k Views 37 Watching
    I used these https://www.aliexpress.com/item/5-pcs-LM393-Light-Sensor-Photosensitive-Sensitivity-light-Sensor-Module-For-Arduino-Smart-Car/1729424221.html
    • F
      F
      FullMetal
      Hello
      my skectch works very well, only I have a double pricing, I manage to recover the information. but I have to modify the code in order to have my exact consumption.
      but my code sends me information always on the same IDs.
      thank you
      • F FullMetal
        Hello
        thank you
        #163
        Hi @fullmetal, welcome to the forum :-)
        Could you explain what double pricing means?
        • F
          F
          FullMetal
          Thank you for your welcome @mfalkvidd
          Our electricity provider offers several rates.
          HP: Full time
          HC: off-peak time
          usually the HP/HC rate is programmed at night by the provider.
          As the consumption is saved by the arduino, I need two different IDs to trace the information to domotics
          • F
            F
            FullMetal
            Here is the modified code:
            #define MY_PARENT_NODE_ID 0                   // define if fixed parent
            #undef MY_REGISTRATION_FEATURE                  // sketch moves on if no registration
            #define MY_NODE_ID 2                     // fixed node number
            // Enable debug prints
            // Enable RS485 transport layer
            #define MY_RS485
            // Define this to enables DE-pin management on defined pin
            #define MY_RS485_DE_PIN 2
            // Set RS485 baud rate to use
            #define MY_RS485_BAUD_RATE 9600
            // Set blinking period
            // Flash leds on rx/tx/err
            #define MY_DEFAULT_ERR_LED_PIN 13  // Error led pin
            #define MY_DEFAULT_RX_LED_PIN  7  // Receive led pin
            #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
            //#define MY_RADIO_NRF24
            #include <Bounce2.h>
            #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
            #define DIGITAL_INPUT_HCHP 5
            #define PULSE_FACTOR 250       // Nummber of blinks per KWH of your meeter
            #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
            #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
            //#define CHILD_ID 2              // Id of the sensor child
            unsigned long SEND_FREQUENCY =
               20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
            double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
            bool pcReceived = false;
            volatile unsigned long pulseHpCount = 0;
            volatile unsigned long pulseHcCount = 0;
            unsigned long oldPulseHpCount = 0;
            volatile unsigned long watt = 0;
            unsigned long oldWatt = 0;
            double oldKwhHp;
            unsigned long oldPulseHcCount = 0;
            double oldKwhHc;
            unsigned long lastSend;
            Bounce debouncer = Bounce();
            int oldValue=-1;
            MyMessage wattMsg(1,V_WATT);
            MyMessage kwhHpMsg(3,V_KWH);
            MyMessage pcHpMsg(2,V_VAR1);
            MyMessage kwhHcMsg(5,V_KWH);
            MyMessage pcHcMsg(6,V_VAR1);
            MyMessage hchpMsg(7,V_VAR2);
            const int ledPin =  13;      // sortie digitale
               request(2, V_VAR1);
               request(6, V_VAR1);
               // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
               // If no pullup is used, the reported usage will be too high because of the floating pin
               pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
               pinMode(DIGITAL_INPUT_HCHP,INPUT_PULLUP);
               pinMode(ledPin, OUTPUT);
               attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
               lastSend=millis();
               debouncer.attach(DIGITAL_INPUT_HCHP);
               debouncer.interval(5);
               sendSketchInfo("Energy Meter", "2.0");
               present(1, S_POWER);
               present(2, S_POWER);
               present(3, S_POWER);
               present(5, S_POWER);
               present(6, S_POWER);
               present(7, S_POWER);
               unsigned long now = millis();
               if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ) {
               // LED Power On
               digitalWrite(ledPin, HIGH);
               // LED Power Off
               digitalWrite(ledPin, LOW);
             debouncer.update();
             // Get the update value
             int value = debouncer.read();
             Serial.println("");
             if (value != oldValue) {
                // Send in the new value
                send(hchpMsg.set(value==HIGH ? 1 : 0));
                oldValue = value;
               bool sendTime = now - lastSend > SEND_FREQUENCY;
               if (pcReceived && (SLEEP_MODE || sendTime)) {
                   // New watt value has been calculated
                   if (!SLEEP_MODE && watt != oldWatt) {
                       // Check that we dont get unresonable large watt value.
                       // could hapen when long wraps or false interrupt triggered
                       if (watt<((unsigned long)MAX_WATT)) {
                           send(wattMsg.set(watt));  // Send watt value to gw
                       Serial.print("Watt:");
                       Serial.println(watt);
                       oldWatt = watt;
               /////HP
                     if (digitalRead(DIGITAL_INPUT_SENSOR) == HIGH ) {
                   // Pulse cout has changed
                      if (pulseHpCount != oldPulseHpCount) {
                       send(pcHpMsg.set(pulseHpCount));  // Send pulse count value to gw
                       double kwhHp = ((double)pulseHpCount/((double)PULSE_FACTOR));
                       oldPulseHpCount = pulseHpCount;
                       if (kwhHp != oldKwhHp) {
                           send(kwhHpMsg.set(kwhHp, 4));  // Send kwh value to gw
                           oldKwhHp = kwhHp;
                   lastSend = now;
                  }else if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ){
                  if (pulseHcCount != oldPulseHcCount) {
                       send(pcHcMsg.set(pulseHcCount));  // Send pulse count value to gw
                       double kwhHc = ((double)pulseHcCount/((double)PULSE_FACTOR));
                       oldPulseHcCount = pulseHcCount;
                       if (kwhHc != oldKwhHc) {
                           send(kwhHcMsg.set(kwhHc, 4));  // Send kwh value to gw
                           oldKwhHc = kwhHc;
                   lastSend = now;
               }else if (sendTime && !pcReceived) {
                   // No count received. Try requesting it again
                   request(2, V_VAR1);
                   request(6, V_VAR1);
                   lastSend=now;
               if (SLEEP_MODE) {
                   sleep(SEND_FREQUENCY);
              /////HP
               if (message.type==V_VAR1) {
                   pulseHpCount = oldPulseHpCount = message.getLong();
                   Serial.println(pulseHpCount);
                   pcReceived = true;
               /////HC
                   pulseHcCount = oldPulseHcCount = message.getLong();
                   Serial.println(pulseHcCount);
                   pcReceived = true;
            void onPulse()
               /////HP
               if (!SLEEP_MODE) {
                   unsigned long interval = newBlink-lastBlink;
                   if (interval<10000L) { // Sometimes we get interrupt on RISING
                       return;
                   watt = (3600000000.0 /interval) / ppwh;
                   lastBlink = newBlink;
               pulseHpCount++;
               /////HC
               else if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ) {
                 if (!SLEEP_MODE) {
                       return;
               pulseHcCount++;
            • F FullMetal
              #define MY_RS485
              double oldKwhHp;
              double oldKwhHc;
              int oldValue=-1;
                 request(2, V_VAR1);
                 request(6, V_VAR1);
                 lastSend=millis();
                 // LED Power On
                 // LED Power Off
               debouncer.update();
               Serial.println("");
                  oldValue = value;
                         oldWatt = watt;
                 /////HP
                             oldKwhHp = kwhHp;
                     lastSend = now;
                             oldKwhHc = kwhHc;
                     lastSend = now;
                     request(2, V_VAR1);
                     request(6, V_VAR1);
                     lastSend=now;
                 if (SLEEP_MODE) {
                /////HP
                     pcReceived = true;
                 /////HC
                     pcReceived = true;
              void onPulse()
                 /////HP
                 if (!SLEEP_MODE) {
                         return;
                 pulseHpCount++;
                 /////HC
                   if (!SLEEP_MODE) {
                         return;
                 pulseHcCount++;
              @fullmetal cool. Thanks for explaining, and for sharing your sketch.
              F 1 Reply Last reply
                F
                F
                FullMetal
                In fact, my code does not work as I would like, HC information systematically go back to the HP ID.
                Can you help me
                • C
                  C
                  cstewy
                  Update: Running for over 12 months on 2 regular AA batteries using the method I described above. Basically rather than powering the tsl257 constantly, I wake up every 125ms then send power to the tsl257, check if there has been a state change in the power meter light then go back to sleep.
                    This thread contains comments for the article "Power Meter Pulse Sensor" posted on MySensors.org.
                    I
                    I
                    it-slav
                    wrote on last edited by it-slav
                    #169
                    Hi
                    My heat exchanger does only give one pulse / kWh which results in that there can be hours between the pulses. When doing the watt calculation micros are used and that counter overflow after 70minutes. See: https://www.arduino.cc/reference/en/language/functions/time/micros/
                    I have modified the sketch to use millis instead of micros when the time between the pulses are above one hour and micros if it is less than an hour.
                    I hope I did it correct ;-)
                    Best regards
                    Peter Andersson
                     * Version 1.0 - Henrik Ekblad
                     * Version 1.1 - Peter Andersson added millis watt calculation if time between pulses > 1h
                     * This sketch provides an example how to implement a LM393 PCB
                     * Use this sensor to measure kWh and Watt of your house meter
                     * You need to set the correct pulsefactor of your meter (blinks per kWh).
                     * The sensor starts by fetching current kWh value from gateway.
                     * Reports both kWh and Watt back to gateway.
                     * Unfortunately millis() won't increment when the Arduino is in
                     * sleepmode. So we cannot make this sensor sleep if we also want
                     * to calculate/report watt value.
                     * http://www.mysensors.org/build/pulse_power
                    #define MY_REPEATER_FEATURE    //Added
                    #define MY_RADIO_RF24
                    //#define MY_RADIO_NRF5_ESB
                    //#define MY_RADIO_RFM95
                    #define PULSE_FACTOR 1       // Number of blinks per of your meter. Normally 1000
                    #define SLEEP_MODE false        // Watt value can only be reported when sleep mode is false.
                    #define MAX_WATT 100000          // Max watt value to report. This filters outliers. Normally 10000
                    #define CHILD_ID 1              // Id of the sensor child
                    uint32_t SEND_FREQUENCY =
                        20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                    volatile uint32_t pulseCount = 0;
                    volatile uint32_t lastBlinkmicros = 0;
                    volatile uint32_t lastBlinkmillis = 0;
                    volatile uint32_t watt = 0;
                    uint32_t oldPulseCount = 0;
                    uint32_t oldWatt = 0;
                    double oldkWh;
                    uint32_t lastSend;
                    MyMessage wattMsg(CHILD_ID,V_WATT);
                    MyMessage kWhMsg(CHILD_ID,V_KWH);
                        request(CHILD_ID, V_VAR1);
                        lastSend=millis();
                        sendSketchInfo("Energy Meter", "1.0");
                        present(CHILD_ID, S_POWER);
                        uint32_t now = millis();
                                // Check that we don't get unreasonable large watt value.
                                // could happen when long wraps or false interrupt triggered
                                if (watt<((uint32_t)MAX_WATT)) {
                                oldWatt = watt;
                            // Pulse count value has changed
                            if (pulseCount != oldPulseCount) {
                                send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                double kWh = ((double)pulseCount/((double)PULSE_FACTOR));
                                oldPulseCount = pulseCount;
                                if (kWh != oldkWh) {
                                    send(kWhMsg.set(kWh, 4));  // Send kWh value to gw
                                    oldkWh = kWh;
                            lastSend = now;
                        } else if (sendTime && !pcReceived) {
                            // No pulse count value received. Try requesting it again
                            lastSend=now;
                        if (SLEEP_MODE) {
                            Serial.print("Received last pulse count value from gw:");
                            Serial.println(pulseCount);
                            pcReceived = true;
                    void onPulse()
                        if (!SLEEP_MODE) {
                            uint32_t newBlinkmicros = micros();
                            uint32_t newBlinkmillis = millis();
                            uint32_t intervalmicros = newBlinkmicros-lastBlinkmicros;
                            uint32_t intervalmillis = newBlinkmillis-lastBlinkmillis;
                            if (intervalmicros<10000L && intervalmillis<10L) { // Sometimes we get interrupt on RISING
                                return;
                            if (intervalmillis<360000) { //Less then an hour since last pulse, use microseconds
                               watt = (3600000000.0 /intervalmicros) / ppwh;
                            } else {
                               watt = (3600000.0 /intervalmillis) / ppwh; //more then an hour since last pulse, use milliseconds as micros will overflow after 70min
                            lastBlinkmicros = newBlinkmicros;
                            lastBlinkmillis = newBlinkmillis;
                        pulseCount++;
                    • I it-slav
                      Hi
                      Best regards
                      Peter Andersson
                      double oldkWh;
                      uint32_t lastSend;
                          lastSend=millis();
                                  oldWatt = watt;
                                      oldkWh = kWh;
                              lastSend = now;
                              lastSend=now;
                          if (SLEEP_MODE) {
                              pcReceived = true;
                      void onPulse()
                          if (!SLEEP_MODE) {
                                  return;
                              } else {
                          pulseCount++;
                      #170
                      Thanks @it-slav
                      I have created a pull request based on your sketch.
                      https://github.com/mysensors/MySensors/pull/1306
                      There were some merge problems, but I think I got them all ironed out.
                      • butalukB
                        butalukB
                        butaluk
                        Hello everyone.
                        Is it possible to evaluate two electricity meter signals with one sensor?
                        Thank you!
                        • butalukB butaluk
                          Hello everyone.
                          Thank you!
                          @butaluk yes, as long as they are not too far apart to run the cables
                          butalukB 1 Reply Last reply
                            butalukB
                            butalukB
                            butaluk
                            @mfalkvidd Thank you. no, the counters are in one place. Do you have an example code for me?
                            • sundberg84S
                              #174
                              Hi! I have just revised my pulse sensor and have a few suggestions to the code. I have mentioned this before but there can be issues when requesting V_VAR1.
                              In current code we request V_VAR1 one time and then goes to sleep, and if you like me have a 10 minute sleep period it can take along time to get V_VAR1 if you have a radio on the outside of your GW range.
                              I would suggest adding:
                              } else if (now - lastSend > 5000 && !pcReceived) {
                                  // No pulse count value received from controller. Try requesting it again.
                                  recrequestcount = recrequestcount + 1;
                              #ifdef MY_DEBUG
                                  Serial.println("Req p-cnt");
                                  lastSend = now;
                                  return;
                              and before sleep:
                              else if (!pcReceived) {
                                  //We dont want to sleep if !pcRecieved. Return and wait 5 sec to request a new value.
                                  return;
                              In HomeAssisant you also have the specific problem that if V_VAR1 isnt stored, the controller will not answer - so you can keep asking for a pulsecount forever without an reply. To avoid this the first time I have added:
                              else if (recrequestcount == 5 && !pcReceived) {
                                  //For some controllers, if you dont have any V_VAR1 stored node will not get an answer.
                                  //Try 5 times, then set V_VAR1 to 0 and update controller
                              #ifdef MY_DEBUG
                                  Serial.println("Set p-cnt and update controller");
                                  pcReceived = true;
                                  recrequestcount = 0;
                                  send(pcMsg.set(pulseCount));  // Send pulse count 0 value to gw
                                  double kWh = ((double)pulseCount / ((double)PULSE_FACTOR));
                                  send(kWhMsg.set(kWh, 4));  // Send kWh value 0 to gw
                                  lastSend = now;
                              This setup works great for me, but I dont have the bigger picture - might break something else.
                              I can add a pull request if you think this should fit.
                              Here is my full code (but It includes battery measurments)
                              https://github.com/sundberg84/HomeAutomation/blob/master/Ver 2.X/2.3/EnergyMeterPulseSensor_Feb2020/EnergyMeterPulseSensor_Feb2020.ino
                              Also there is a strange error with SEND_FREQUENCY / timer when you have this interrupt. Works great if you dont have any interrupts but as soon as you get pulses the timer gets about 4 times as fast as it should be - I have added a correction to this, but I dont know whats causing this.
                              uint32_t SEND_FREQUENCY = 4*60000*15; // Minimum time between send (in milliseconds). We don't want to spam the gateway. (Corr * 60sek * minutes)
                              K 1 Reply Last reply
                              • S
                                snady
                                Hi
                                I have done search of this thread and no one seems to have mentioned latency.
                                I have a test setup using a LM393 running on a particle photon with a sketch that also runs a flashing led. I have tested this with various led flash lengths and intervals, the highest rate being a 10ms flash with 10ms interval . I have a consistent precise reading of pulse interval and number but have identified that there is a 1ms delay between the flash and the start of the interrupt function. This latency is consistent, whatever the interval between and I can only assume it is a result of latency caused by LM393 and interrupt, though I find it strange that the latency is exactly 1millisecond even when measured in micros. Under low meter loads this discrepancy would most likely go unnoticed but with high loads of 72kWs it results in a significant error when calculating the instant power.
                                Has anyone else noticed this or can give another reason for this that I am missing?
                                A subtraction of the identified latency from the pulse interval reading, calibrates the setup and produces exact readings
                                • F
                                  F
                                  frydrik
                                  Hello, this sensor can be adapted for 2-4 meters ?
                                  • K
                                    K
                                    keithellis
                                    I've been building one of these pulse meters up, it seems to be working on the bench very nice. Just got to build a case and get a power supply of the Arduino. But I have designed a case to hold the LM393 sensor onto the meter. I removed the light sensor and re-soldered it flush to the board making it easier to mount on the meter. Its a simple box but works quite well.
                                    The files are on thingiverse here
                                    Hope this is useful.
                                    • sundberg84S sundberg84
                                      #ifdef MY_DEBUG
                                          lastSend = now;
                                          return;
                                      and before sleep:
                                          return;
                                      #ifdef MY_DEBUG
                                          pcReceived = true;
                                          lastSend = now;
                                      K
                                      K
                                      keithellis
                                      @sundberg84 Thanks very much for this post. I was struggling to get the sensor appear in Home-Assistant. Your note on the fact that HA never returns V_VAR1 on first use was very useful and pointed me in the right direction.
                                      My modifications looked like this:
                                          retryCount++;
                                      		lastSend = now;
                                      	} else if (retryCount >= 5 && !pcReceived) {
                                          pcReceived = true;
                                          retryCount = 0;
                                          lastSend = now;
                                      The whole sketch is here:
                                         The MySensors Arduino library handles the wireless radio link and protocol
                                         between your home built sensors/actuators and HA controller of choice.
                                         The sensors forms a self healing radio network with optional repeaters. Each
                                         repeater and gateway builds a routing tables in EEPROM which keeps track of the
                                         network topology allowing messages to be routed to nodes.
                                         Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
                                         Documentation: http://www.mysensors.org
                                         Support Forum: http://forum.mysensors.org
                                         This program is free software; you can redistribute it and/or
                                         modify it under the terms of the GNU General Public License
                                         version 2 as published by the Free Software Foundation.
                                         REVISION HISTORY
                                         DESCRIPTION
                                      #define PULSE_FACTOR 1000       // Number of blinks per kWh of your meter. Normally 1000.
                                      #define MAX_WATT 10000          // Max watt value to report. This filters outliers.
                                      double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour
                                      uint32_t retryCount = 0;  //If value not being returned from controller, increment this counter
                                      double oldkWh;
                                      uint32_t lastSend;
                                      MyMessage wattMsg(CHILD_ID, V_WATT);
                                      MyMessage kWhMsg(CHILD_ID, V_KWH);
                                      MyMessage pcMsg(CHILD_ID, V_VAR1);
                                      #if defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32)
                                      #define IRQ_HANDLER_ATTR ICACHE_RAM_ATTR
                                      #else
                                      void IRQ_HANDLER_ATTR onPulse()
                                      	if (!SLEEP_MODE) {
                                      		uint32_t intervalmicros = newBlinkmicros - lastBlinkmicros;
                                      		uint32_t intervalmillis = newBlinkmillis - lastBlinkmillis;
                                      		if (intervalmicros < 10000L && intervalmillis < 10L) { // Sometimes we get interrupt on RISING
                                      			return;
                                      		if (intervalmillis < 360000) { // Less than an hour since last pulse, use microseconds
                                      			watt = (3600000000.0 / intervalmicros) / ppwh;
                                      		} else {
                                      			watt = (3600000.0 / intervalmillis) /
                                      			       ppwh; // more thAn an hour since last pulse, use milliseconds as micros will overflow after 70min
                                      	pulseCount++;
                                      	pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
                                      	lastSend = millis();
                                      	sendSketchInfo(F("Energy Meter"), F("1.1"));
                                      			// Check that we don't get unreasonable large watt value, which
                                      			if (watt < ((uint32_t)MAX_WATT)) {
                                      			oldWatt = watt;
                                      				oldkWh = kWh;
                                      		lastSend = now;
                                          retryCount++;
                                      		lastSend = now;
                                          pcReceived = true;
                                          retryCount = 0;
                                          lastSend = now;
                                      	if (SLEEP_MODE) {
                                      		sleep(SEND_FREQUENCY, false);
                                      	if (message.getType()==V_VAR1) {
                                      		pcReceived = true;
                                      • K
                                        K
                                        keithellis
                                        Got this sensor up and running now. Comparing it to my old clamp meter the kWh reading was reading 2-3 times higher, the Watts was about right. I added a 0.1uF capacity across the ground and data pins of the sensor and it is working well now.
                                        The graph below shows the comparison of my two sensors. the old clamp meter is Energy previous hour, the new pulse sensor is Temp energy previous hour
                                        You can see they are not aligned, until about 20:00 when I added the capacitor and they drop in line.Screenshot 2021-09-25 at 22.18.27.png
                                        • OlmoO
                                          OlmoO
                                          Olmo
                                          Hi everyone, I just implemented this energy meter and it's working quite good. Thanks for all the help.
                                          I have 1 question, however. Since my sensors runs on batteries, it sometimes dies. I then need to replace the batteries and "restart" the counting. It's not ideal, but I have no way of plugin the sensor to power next to the meter.
                                          When the sensor dies, I read the kWh reading of the meter manually and store it in an input variable. How can I use this to set the kWh value of the mysensor variable at initialization?
                                          I see this line: request(PC_CHILD_ID, V_VAR1);, however it's never running for me. Somehow it does not work properly with home assistant.
                                          Would request(KWH_CHILD_ID, V_KWH); do the trick? (provided that I store the kWh value from the meter in the same state created by the mysensor S0 pulse counter)
                                          thanks a lot
